Results 1 to 18 of 18
Nice Score Today
Hybrid View
AuntieCake Nice Score Today 09-18-2012, 06:55 PM
Bear What kinda camera is it... 09-18-2012, 07:05 PM
AuntieCake Sanyo vcp-s770pu For some... 09-18-2012, 07:19 PM
ScrapYaHerd That is a real good first! 09-18-2012, 07:08 PM
Bear you should be able to get a... 09-18-2012, 07:30 PM
AuntieCake Never used the delayed snap... 09-18-2012, 07:39 PM
Bear ohno auntie! I'll send you... 09-18-2012, 08:07 PM
Bear ok, that -90, that's a 90 mhz... 09-18-2012, 07:34 PM
Mechanic688 While your looking at the... 09-18-2012, 08:13 PM
Bear it also doesn't hurt to fire... 09-18-2012, 08:20 PM
Bear if you find those ending with... 09-18-2012, 07:36 PM
AuntieCake BTW Thanks for all the info... 09-18-2012, 07:51 PM
Bear there might be better than... 09-18-2012, 07:20 PM
AuntieCake a4481383ca a4 509 ae... 09-18-2012, 07:24 PM
Bear The computer is probably just... 09-18-2012, 08:04 PM
BRASSCATCHER Congrats on your first gold... 09-18-2012, 08:37 PM
BarrenRealms007 The SX957 would have been a... 09-18-2012, 08:53 PM
parrothead Nice find. Grats. If it had a... 09-18-2012, 09:07 PM
    AuntieCake is offline Metal Recycling Entrepreneur
    AuntieCake started this thread.
    AuntieCake's Avatar
    By Saginaw, Michigan
    140
    114
    Nice Score Today
    Got a tad bit excited while curb shopping today. First when I picked the kid up earlier I filled my truck on the way home and I only went 2 miles. Then tonight me the other kid and his friend went for a run w/the trailer and got an excellent haul, lots of good money makers. Then I found a bit of an older computer and found this... my first gold one out of a computer.
    Sorry about the crappy pictures, my camera isn't so great. But I was excited and wanted to share.
  2. The Following 2 Users say Thank You for This Post by AuntieCake:
    6,810
    What kinda camera is it Auntie, you got a model number?
    AuntieCake's Avatar
    140
    114
    Sanyo vcp-s770pu
    For some reason it's been blurring or just not taking good photos if I try to get closer than about 3ft.
    Central Florida
    629
    115
  6. The Following User Says Thank You to ScrapYaHerd for This Post:
    6,810
    you should be able to get a pretty decent picture with it Auntie. For close ups do you put it on the flower icon setting? Do you ever use the delayed snap? It's a simple setting that you set just prior to the snap, most i've seen have a 2 second and a 10 second delay, i generally use the 2 second because it's plenty of time to steady it up for the snap. Does wonders on close-ups and long zoom shots. Also you can just stand back a bit and use the regular(not close-up) setting, it's probably on that when you turn it on. Then use the optical zoom to bring it a bit closer. I seldom go past the optical zoom because digital zoom looses clarity.
  8. The Following User Says Thank You to Bear for This Post:
    AuntieCake's Avatar
    140
    114
    Never used the delayed snap or the flower icon. I just turn it on and push the button when I'm ready, and I don't use the zoom because for pictures that I've wanted to have printed it distorts them. Never thought about it for things like this. Thanks Bear, I'll play around with a bit and see if it works better trying those things.
    ***The computer that CPU came out of was a Dell 1994 Optiplex xm590 model no.DPM
    Not only was it my 1st gold cpu, it was the first time I had a computer that big to take apart, needless to say I saw the "intel pentium inside" sticker on the outside so I just opened it and lifted the heat sink to see what it looked like...the rest is still on the floor.
    6,810
    ohno auntie! I'll send you some thick insulated coveralls if you want em, thick insulated gloves, insulated boots, a hard hat, and safety glasses too! sleep tight ; )
    6,810
    ok, that -90, that's a 90 mhz CPU, probably not real vintage, still wouldn't hurt to google the motherboard numbers to see if any are listed for sale. If you have the motherboard fairly well emptied for a good look at the board, you should find either a brand and number, or just a number. It can be as simple as AOpen AX6BC, or more complicated, but it should be clearly visible on the board
    While your looking at the board check for any leaking/blown/bulged can caps on the board. If there's any then it's scrap
    6,810
    it also doesn't hurt to fire em up before you tear em down ; )
    it also might have an ancient hard drive
    6,810
    if you find those ending with a -20, -25 etc, be sure to research everything in it for better than scrap
    AuntieCake's Avatar
    140
    114
    BTW Thanks for all the info Bear, I've wrote it all down for future reference! I'll check on that motherboard tomorrow, I swore I was not working on a Wed. anymore but I sliced my leg open earlier today (No stitches either, I used those steri-strip things to tape it closed then gauze and paper tape to cover it up) so I guess my injuries are not exclusive to Wed. anymore lmao So I may as well do my morning curb shopping since it's normally my best day. I'll let you know what I come up with on the motherboard. Again Thanks for all the info.
    Sorry for all the rambling, way past my bedtime.
    6,810
    there might be better than scrap parts in there. Wish I could see the numbers on that cpu. On the bottom (pin side) do any of those rows of numbers end with a dash, followed by a number? (such as -25, -66, -90 etc)
    AuntieCake's Avatar
    140
    114
    a4481383ca
    a4 509 ae
    intel mc92,93
    a80502-90
    sx957
    When you asked about the camera where you talking about the model # of the camera or computer????? Anyhow those are all the #'s off the pin side of the CPU
    6,810
    The computer is probably just scrappable, unless maybe it has an interesting board in it, video, soundcard etc, just look for a name on it and a number and google it, usually the results will have a couple ebay links to look at, and you can do further searches from there.
    As long as you stay within your optical zoom, it shouldn't distort, it's the digital zoom that does that. If you'll watch the slider as you're zooming in, it will reach a point where it reaches the end of it's optical range and switches over to digital, just stop zooming when you reach that point, or before. Optical is using lenses, much like pulling a magnifying glass up for a larger view. Digital zoom is like stretching a balloon, that's why it distorts. It does enlarge it, but at the cost of clarity
    And the 2 second delay does wonders for closeups, I use it on almost all still shots. It gives you a chance to steady up before the snap, and isn't busy taking a shot while i'm busy trying to push the button
  19. #16
    3,419
    Congrats on your first gold cap. They are gettin rare to find.
  20. The Following User Says Thank You to BRASSCATCHER for This Post:
  21. #17
    BarrenRealms007's Avatar
    Arkansas
    397
    180
    The SX957 would have been a good collector chip. But since most of the name on the chip is missing it is not worth keeping.
  22. #18
    2,417
    664
    Nice find. Grats. If it had a 5.25 disc drive that is worth some money as well.
