Results 1 to 20 of 24
    ITSANSS started this thread.
    16
    Estimated price for the steel I-Beam I have...?
    Just finished dismantling a mobile home trailer that was on my property. It was QUITE a task. I've scrapped everything except for the i beam rails and the axles. A friend of a friend said that the axles were the "old kind" and weren't really sought after and not worth much more than scrap or possibly ONLY worth scrap. Well, I'm gonna' list the axles and the rails on craigslist to see if any local farmers could put it to good use. I figured I'd ask $20 each for the axles or $50 for all three. But I'm not sure what to price my i beams at as I've never had any dealings with i beam before. Hopefully ya'll can help me out!
    I have two i beams. They are both 65' long, 10" tall, and 1/8" thick and they are HEAVY! I imagine that to buy i beam at a metal place it would cost by the foot, right? What do ya'll figure I could get? I live in southwest Oklahoma, by the way.
    Thanks!
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Gravitar's Avatar
    Central Texas
    1,086
    1,258
    The I beam should go for Iron price, which is a little more than shred.
    6,815
    if you have some way to cut those beams you might do better having 3-20(+/-) footers than one 65 ft long. Six 20 ft beams could easily be used to build a good sized light roofing system
  4. The Following User Says Thank You to Bear for This Post:
    Henderson nc
    246
    With prices being so low right now im afraid to guess.
    Abraham Lincoln
    16
    Quote Originally Posted by Gravitar View Post
    So you think I'd be better off just scrapping it? I have to admit that it crossed my mind....
    I thought about that. I was wondering how a person, if I could sell them, would haul them. Even a semi trailer is generally only 53' long. I had a feeling they would need to be cut. When dismantling the trailer house, I used some heavy duty reciprocating saw blades to cut these rails (there are two, keep in mind!) from the tongue. It cut surprisingly easily. However, I won't say that it wasn't still a lot of work to cut these suckers. It would probably take an entire evening to cut both rails down to a more manageable size. But I reckon that would be worth it if I could sell these for more than scrap value.... Wish I had a cutting torch! lol
    Quote Originally Posted by Ptscrapper View Post
    I understand. I was a bit disappointed when I took the metal from the trailer house to the scrap yard a couple days ago. ~$340 for everything. I scrapped every possible thing that I could, except for the copper wiring (gonna' strip it first), the axles, and the i beam rails. I guess the prices are down...? :-(
    Thanks thus far, ya'll
    admin's Avatar
    684
    336
    Those axles, if I'm not mistaken, are mobile home axles. So advertise them as such when you hit craigslist. And pop those caps off the end and check the grease in there, make sure they're good to go. If not, try greasing them up first and mention that in your ad as well.
  8. The Following 3 Users say Thank You for This Post by admin:
    chrisc's Avatar
    ct
    251
    201
    Those axles look for tag on them should tell you weight but looking at them they should be 3-5k worth way more than scrap,there used in campers mine say 3500lb which look the same and why there is 3 of them. but can be used to build alot they will sell ...If your were close id buy i have the old style 4 lug those are newer 5 lug ..
    4,985
    1,257
    I have that type of axle on my trailer.........I will haul quite a bit........I have hauled 9 gaylords full of electronics on those axles so they have more value than scrap
  11. The Following User Says Thank You to mikeinreco for This Post:
    Gravitar's Avatar
    Central Texas
    1,086
    1,258
    [QUOTE=ITSANSS;105386]So you think I'd be better off just scrapping it? I have to admit that it crossed my mind....
    Well, you asked how much it was worth. So I gave you my answer.
    chrisc's Avatar
    ct
    251
    201
    what you could do is make 1 sick 3 axle trailer you have the most expensive pieces ,i would make double frame trailer it would take 10 k all day long just another option or can make 2 trailer sell one pay enough to make a nice 2 axle trailer for yourself.
    1,209
    If the backing plates for the brake shoes are welded on then the axles you have are only good for farm or off road use. Welded backing plates no longer D.O.T. approved for highway use.
    Libertytow's Avatar
    Silverton NJ
    562
    64
    10" i beam goes for $53 a foot @ fazios sell it opnline for $26 those axles bring about $200 a set here on cl you should try builder forums of modular homes builders they would scoop it all up for the right price
    Liberty Towing & Recycling
    (732)279-8599
    Cleaning up NJ 1 LB at a time!
    Certified Mobile Scales
    Fully Insured Carrier usdot # 1802487
    WWW.LibertyTowing.Webs.Com
    WWW.TRRecycles.Webs.com
  16. The Following User Says Thank You to Libertytow for This Post:
    6,815
    you said the beams are 1/8" thick, but what I'm seeing looks like at least 1/4"
    Germany
    57
    According to Libertytow:: 130 ft. of 10 inch I-beam at 26$ per foot = 3,380 dollars!! I think that's just a tad bit more than scrap value..... as for axles, I have no clue.
    metal Detect around the tree before you Pee.!!!
    York, PA
    45
    19
    Based on your dimensions given and guessing the rest from the pictures. ( 10" x 3" flange?...plus if your web thickness is thicker than .125" then your weight and scrap value go up) I calculated 1560 cubic inches of metal, multiply by the density of .283 of steel. You have 441# per ibeam. Multiply that by what you would get at your yard. So, anything higher than your answer is better than taking it to a scrap yard. At 0.10 per pound, thats only 44 bucks per beam plus they probably would want you to cut it. Sell on craigslist for $100 a beam would be a steal for anyone.
  20. #16
    jghilino's Avatar
    KANSAS CITY
    2,672
    1,429
    i think those beams would work great to cross the gap between 2 shipping containers to make a roof system, for about 5k you could have 2 40' containers and a 15ft wide covered area between them, just a thought, perfect setup for scrapping/ workshop, ive been to a couple auctions in the last year where shipping containers are selling at or below there scrap value
  21. #17
    Quote Originally Posted by jghilino View Post
    I've seen a few farmers use mobile home frames to build a bridge across a creek to drive farm equipment across back in their fields.
  22. The Following 2 Users say Thank You for This Post by Mechanic688:
  23. #18
    6,815
    got a photo of one ? how much weight would they hold up ?
  24. #19
    From what I was reading it needs a little extra work (bracing) to support a farm tractor, but they use them all the time for ATV, foot traffic, lawn mower. Just add wood planks to the top layer.
    https://www.google.com/search?q=mobile%20home%20frame%20for%20a%20bridge& ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-USfficial&client=firefox-a&source=hp&channel=np
  25. The Following User Says Thank You to Mechanic688 for This Post:
  26. #20
    auminer's Avatar
    Allen, TX
    1,233
    579
    Quote Originally Posted by metalheap View Post
    Hey you can sell your used metals like beams on metalheap.com. They have registered and genuine buyers all over the world .
    If he's been holding on to them for over seven years since this thread was last active, then he probably isn't selling.
    Unless you just bumped this thread with your first ever post just to get a plug in for a website that just so happens to be the same as your user name... ie: an unpaid advertisement.
    You're so sneaky!!!!
  27. The Following User Says Thank You to auminer for This Post:
    1. Spring steel/couch springs - Worth more than regular steel?
      By Sagan in forum Scrap Metal Questions and Answers
      Last Post: 05-30-2015, 02:43 AM
    2. Prepared steel advantage price wise?
      By IRIDEOLDSCHOOL in forum Scrap Metal Tips and Advice
      Last Post: 01-22-2012, 09:35 PM
    3. Price for 18 SR Stainless Steel
      By jimcro55 in forum Scrap Metal Prices
      Last Post: 01-13-2012, 08:44 PM
    4. ?? about rotor ''steel'' vs. other heavy steel
      By newattitude in forum Scrap Metal Questions and Answers
      Last Post: 08-28-2011, 09:00 PM
