Originally Posted by
Mechanic688
You might consider taking the
freon course and pick up a used reclaimer for your problem, and make money doing it for the other scrappers also.
I am a certified HVAC tech. Mechanic posted the best solution to your problem.
You can go here:
EPA Certification by Mainstream Engineering
And take the test ONLINE to get your EPA certification to handle refrigerants in appliances and small (window)
A/C. It should cost you about 20.00 then you can stamp your own fridges.
This license ALSO allows you to buy and sell
refrigerant. Many HVAC warehouses won't sell to any homeowners because of liability reasons. With this license you can deal with the warehouses. You can build a relationship with the smaller stores. When a compressor fails you would return it to the warehouse for a warranty replacement. Most of these are not sent back and are just thrown away. I have had very good luck with getting compressors and fan motors from the warehouses.
It's a good old boys network. For 20.00 bucks you can be part of the club.
Without discussing the ethics of this, when you go to the EPA test website there is a practice test program. These are the same questions as the test you take online, just in a different order. You can click for the practice test to show the correct answer. You could be looking at the practice test, keep skipping questions until you find the one you are trying to answer on the REAL test and find the answers.
