Results 1 to 11 of 11
Relays on low grade boards
    Otto is offline Metal Recycling Entrepreneur
    Otto started this thread.
    Otto's Avatar
    Ottawa, Ontario
    335
    494
    The other night, while I was turning on my TV with my remote, the click I heard made me realize that this sound was from a relay. (For those of you that don't know what a relay is, it's an electro-mechanical switching component. For the most part, it consists of an electro-magnet and contacts. The electro-magnet is made from wire coiled on a steel core.) Up to now, I have been overlooking relays while harvesting copper bearing components from low grade boards. The pictures below show what a typical relay from these boards looks like. It's not a lot of copper, but if you're pulling this stuff off anyways, you might as well take these too. I figure I should be able to pull 50 or more from my pile of low grade boards that I've already processed. Like they say, better than a poke in the eye with a sharp stick. The contacts also contain silver (for those of you that save this).
  2. The Following User Says Thank You to Otto for This Post:
    telecomguy is offline Metal Recycling Entrepreneur
    North Texas
    97
    Thanks, I'll have to go look at my stash. Ran across a few inductors/coils recently that had shrink tubing over them that made them look like capacitors. Only thing that tipped me off is they weren't smooth cylinders. The sides were a little wavy. Just something else to watch for. Looked similar to this:
    Washington state
    17
    SILVER CONTACTS??? I have been throwing these into the bin with the brass or stainless. I will have to be a little more careful. Can you post a pic of what part is actually the silver plated part please. I will be saving these to precess them. I love precious metals for free!!
    Gravitar's Avatar
    Central Texas
    1,086
    1,258
    Quote Originally Posted by Storedaddy View Post
    They look like little silver disks on the thin copper plates. I don't pull them, but thats a personal preference. Keep in mind it will take you a few thousand relays to get an amount that would be reasonable to send to a refiner.
  6. The Following User Says Thank You to Gravitar for This Post:
    Otto's Avatar
    Ottawa, Ontario
    335
    494
    Quote Originally Posted by Gravitar View Post
    Thanks Gravitar. That's a much better picture than my camera will take.
    Washington state
    17
    this year a few thousand next year maybe a few hundred. as i am sure we all know the metals market can jump or drop at anytime.
    happyisthealero's Avatar
    michigan
    529
    439
    and these contacts are found where and on what before the look like the above pic.
    etack's Avatar
    Buying Tantalum capacitors
    United States ohio
    503
    437
    The relay contacts in the above pic look like they come from Ice breaker relays.
    The contacts on the relays the OP are talking about look like thin pieces of square wire. Or a small rounded square pad.
    Eric
    It will take a lot to make any meaningful amount of silver.
    2,529
    2,906
    I have been saving up contacts from relays for about 6 months. So far I have over two ounces of silver contacts, 4 of silver/copper & 1 of silver/magnetic.
    I guess that the silver/magnetic are either cheaper, or more valueable than the others, depending on the individual contact.
    In the pic above, you can see the contacts, they are all silver/copper contacts. Normally the centre contact is all silver (because it contacts on both sides), just depending on the manufacturer.
    The little relays you find in microwaves are easy to pick apart & they are all different deon their use.
    The one I have in my pocket I just found in a washing machine, it has a silver bar on each contact surface.
    The teflonny looking relay I found had three nice solid silver contatcs. Most of those relays will have silver/copper contacts.
    The better contacts will be in, expensive industrial equiptment (sometimes gold), often opened & closed switches - clothes dryers - washing machines.
  12. The Following 4 Users say Thank You for This Post by eesakiwi:
    Gravitar's Avatar
    Central Texas
    1,086
    1,258
    Quote Originally Posted by happyisthealero View Post
    I have no idea where these came from because I just embedded a picture link from Google. Look at eesakiwi's picture.
    michigan
    529
    439
    Hrm need more pics of them before and after dis assembly to understand fully thanks for posting pics anyway Eesakiwi
    1. removing copper from low grade boards
      By geravega77 in forum Scrap Metal Videos
      Last Post: 10-24-2014, 05:15 PM
    2. Looking for buyer of low grade boards in New Hampshire
      By bpatnoe in forum Low-Grade Electronics Recycling
      Last Post: 09-08-2013, 04:35 AM
    3. Anyone sold low grade boards latley
      By hammerdown in forum Low-Grade Electronics Recycling
      Last Post: 11-06-2012, 04:35 AM
    4. Low-Grade Circuit Boards
      By axiomrenovations in forum Low-Grade Electronics Recycling
      Last Post: 12-01-2011, 02:56 PM
