Results 1 to 20 of 23
    BurlyGuys started this thread.
    BurlyGuys's Avatar
    Waterford Michigan
    1,591
    1,109
    How big a winch do I need for my car dolly?
    So Harbor Freight has a 2000 lb. winch on sale for sixty bucks this week.
    Is that big enough to pull cars onto the tow dolly I just bought?
    I know the cars WEIGH more than 2000 pounds, but since the winch isn't
    actually LIFTING all that weight, is is sufficient for the task?
    Thanks!
    John Terrell (248) 224-2188
    Burly Guys Junk Removal LLC
    http://www.burlyguys.com
    New Hampshire
    Rule of thumb here for stuff like this is always go a bit bigger than what you need. You might not need it, but I'd bet ya $5 you won't regret it. I personally wouldn't jump on something like that just because it's cheap, I'm sure you will get what you pay for.
  3. The Following 2 Users say Thank You for This Post by AAElectronicsRecycling:
    You'll need more than the weight due to resistance.
    JohnC4X4's Avatar
    South East Ma
    986
    162
    If the car you are picking up is a rolling load
    The 2K might work because you are not pulling a long distance or up a steep grade
    BUT
    Most of the cars I pick up have a couple flat tires, OR rear brakes locked up, OR trans locked up, OR tires missing
    and so on and so and so on
    So unless you are loading a nice rolling load
    I don't think a 2K will cut it
    6,815
    depending on the speed it turns, you could put a snatch block on there and double it
    I'm inclined to agree with the others tho about tough jobs
    MattInTheHat's Avatar
    rock hill, sc
    1,464
    1,142
    you never know what you will want to try to move with it. and I don't think a disposable winch from harbor freight is a good idea.
    246
    21
    Nothing wrong with Harbor Freight winches. I know a lot of guys that 4 wheel with them. I'm got an old Ramseys, but when it dies, I'm going with a Harbor Freight rig. The guys with the Harbor Freight winches take a little longer than the guys running Warns, but that just gives you more time to shoot the ****.
    2000# is probably a little on the light side though. If the car has 4 tires that are properly inflated and it rolls nice, you'd be fine. But the first time you pull something up on flats, or with the brakes locked up you'll be wishing you have bought something with a little more oomph.
    Something else to thing about is a monsterous come along/cable puller. I bought my last one from harbor freight, and have loaded dead cars very fast. Plus I can use it in my garage if need be for lifting, moving stuff around, as an impromptu sheet metal puller on my derby cars, etc.
    New Hampshire
    The biggest winch they had at Harbor Freight (we use HF too for everything), was a 12,000lb winch, that's the one we bought. I'll tell ya there hasn't been a time that it let us down. I'm not sure of the brand, I'll get back and let you know if you want. I believe it was somewhere between $300 - $400, but it's awesome. You can pull a full size truck out of the woods with flat tires, stuck in the mud, over tree stumps, 25-30 feet away with that thing... LOL I'm speaking from experience, done it. Get a bad ass winch you will not regret it.
  10. The Following User Says Thank You to AAElectronicsRecycling for This Post:
    246
    21
    Quote Originally Posted by AAElectronicsRecycling View Post
    The 12,000 is the badlands brand, they sell for $399.99, but if you get a coupon out of the back of a magazine, you can save 20%, so knock it down to $320. And then laugh at all the guys that spent big bucks on the warns lol.
    3,400
    1,004
    2k shoud be fine for what your doing. I think everyone talking about flats locked up brakes and what not forget that your talking about a tow dolly not a trailer. Your not going to tow anything with flats or locked up breaks with a tow dolly. At least I hope not. If all your loads have good tires and are rolling 2k shoudl be enuff unless your parked on a san fransisco hill.
  13. The Following 2 Users say Thank You for This Post by PartTimeScrapper:
    Lee County, Iowa
    149
    2000 would probably be fine assuming anything you put on a dolly would have full tires and would be free rolling. you may want to keep a snatch block with you just in case, when i still had a tow dolly it just had a hand winch i am pretty sure was intended for a boat trailer and it always worked fine and it was real heavy we pulled the dead car to somewhere that was slightly downhill. just make sure you dont use the winch to hold the car on the dolly, make sure you have a good set of tie down straps, i have seen more then 1 winch cheap and expensive let go of a heavy load
    Libertytow's Avatar
    Silverton NJ
    562
    64
    to answer your ? you could i wouldn"t 2000 lb winches only have a pull resistance of about 1k lbs combine that with rolling resistance any kind of mired resistance and gradient resisitance and you will find a huge shortcoming with anything short of a geo metro a
    a 3k lbs taurus would destroy it even in neutral
    Liberty Towing & Recycling
    (732)279-8599
    Cleaning up NJ 1 LB at a time!
    Certified Mobile Scales
    Fully Insured Carrier usdot # 1802487
    WWW.LibertyTowing.Webs.Com
    WWW.TRRecycles.Webs.com
    133
    127
    I put a old K5 Blazer on my buddies trailer with a 2000lb winch and it did just fine. Trailer is a 20ft dove tail with a pretty steep ramp. As long as the tires aren't flat or axle locked up, 2k pounds of pulling power is plenty to get a car on a trailer or dolly.
    Id like to see a picture of how you set your winch up on your dolly.
    Libertytow's Avatar
    Silverton NJ
    562
    64
    at 15 degrees average tow dolly ramp gradient resistance is 3000 lbs on a 2000 lb load
    fresno, california
    146
    i use a hand winch. i clip one side to the trucks step bumper and the other to the vehicle im pulling.
  19. #16
    Quote Originally Posted by heeroyue2002 View Post
    Sounds like WORK to me. I tried using a brand new hand winch I bought to load a Bolens garden tractor. Half way on the trailer, it broke.
  20. #17
    Oct 2010
    234
    71
    Quote Originally Posted by Libertytow View Post
    Not sure how that gets figured out, but if you were lifting a 2000 lb. load straight up, it would have a resistance of ... 2000 lbs. If you're pulling/pushing that same load up a 15 degree incline without a lot of rolling resistance from flat tires, or stuck brakes etc., pretty sure it'll have less than 2000 lbs. resistance. I know 4 guys were able to push a Honda Accord on to my car trailer one time (2400-ish lbs. prepped) and I'm pretty sure we each weren't overcoming 800 lbs. or so of resistance?
  21. #18
    fresno, california
    146
    lo9oks like this and its quite fast and easy. they're also called come alongs
  22. #19
  23. #20
    Libertytow's Avatar
    Silverton NJ
    562
    64
    simple at 15 degrees being pulled the high side of the load shifts to the load side when your 4 buddies started pushing innertia over came the gradience
    1. My little red dolly.
      By sollozo45 in forum Tools and Equipment
      Last Post: 02-07-2013, 02:56 PM
    2. Looking for this type of dolly
      By ScrapperNJ26 in forum Tools and Equipment
      Last Post: 05-20-2012, 02:18 AM
    3. What do you do when dolly tires go bad?
      By Bear in forum Tools and Equipment
      Last Post: 03-03-2012, 10:37 AM
    4. Tow Dolly Ratchets?
      By Ptscrapper in forum Vehicle Recycling
      Last Post: 11-24-2011, 08:10 AM
    5. Got a big rusty car pile in the woods, what equip't would you use?
      By murt in forum Scrap Metal Tips and Advice
      Last Post: 04-18-2011, 08:41 AM
