Results 1 to 17 of 17
    TheDude80 started this thread.
    TheDude80's Avatar
    Ohio
    406
    309
    brass or copper valve? AND does anyone know what model this hard drive case is from?
    I originally thought this was a brass valve, but after throwing it in a mix of CLR and water, it looks to be more of a copper color. Do they make these values in copper? Also what should I throw this in with? As for the hard drive case, there is no make/mode number listed anywhere on it, and I have never come across one of these. Any resale value for just the case? Thanks in advance for anyone who is able to help.
    Red brass looks like copper sometimes.
  3. The Following User Says Thank You to KzScrapper for This Post:
    jghilino's Avatar
    KANSAS CITY
    2,672
    1,429
    630mb ide hard drive, vintage ide hard drive
    Seagate Medalist ST3630A 3 5" 630MB IDE Internal HDD | eBay
    jghilino's Avatar
    KANSAS CITY
    2,672
    1,429
    hard drive caddy would be hot swap or external, its hard to tell
  6. The Following User Says Thank You to jghilino for This Post:
    TheDude80's Avatar
    Ohio
    406
    309
    Quote Originally Posted by jghilino View Post
    Yeah I know that the hard drive itself is a seagate medalist, I was looking for info on the case itself. I know some of them from old vintage computers can fetch some decent money, but like I said in my original post, there are no ID marks on the case.
    2,864
    350
    Those valves are brass, the clr might have changed the color of the brass.
  9. The Following User Says Thank You to happyscraper for This Post:
    jghilino's Avatar
    KANSAS CITY
    2,672
    1,429
    hot swap internal out of a server
  11. The Following User Says Thank You to jghilino for This Post:
    high pressure valves are generally not made of copper. they are usually steel or brass.. Also copper usually has a smooth finish. brass usually has a rough mold surface. copper is much softer then brass.
  13. The Following 3 Users say Thank You for This Post by EcoSafe:
    TheDude80's Avatar
    Ohio
    406
    309
    it definitely looked like brass, and I have never seen a copper valve before, but figured I would ask just to make sure. Thanks for the info J. I thought It might be from a server. I'll have to do some checking and see if I can find the server it came from, and if there is any resale value on it
    Phantoms001's Avatar
    556
    167
    Quote Originally Posted by TheDude80 View Post
    +1 on the valve being brass. As posted above, most of those are steel or brass. They do make copper valves (like ball valves) which are very easy to tell they are copper. This is a good example of "red brass" which is brass that has copper in it which gives it a small red glow. It should bring more than regular "yellow brass".
  16. #11
    british's Avatar
    ENGLAND UK
    105
    236
    Quote Originally Posted by Phantoms001 View Post
    I've never seen a copper valve (but hope to one day) most small valves i've had are brass or 'gun metal' . The larger valves can be steel and tend to have a brass ring on the 'gate' (the bit that moves to block the flow) to stop the valve rusting open/shut .
    Most newer or high pressure ones tend to have steel 'handles/wheels' but still easy money
    pcecycle's Avatar
    Rock Creek, Alabama
    21
    The case is a removeable IDE hard drive caddy. The U-shaped bracket fit in a 5 1/4" drive bay and the drive was placed into the drawer. That one has a key lock to prevent accidental removal of the drive while in use or just for security. I used to have a computer shop and sold one just like that for about $10.
  18. #13
    tski72's Avatar
    Crystal Lake, IL
    399
    283
    I agree with pcecycle, it is only for removing your hd after you shut the computer down. I used to have one like that in my p1 I had built back in 95. its not for hot swap like a server drive. I tried to remove a secondary hd while running, just as a test, and it destoyed the boot sector.
    Cleaning up the e-waste one company at a time
  19. #14
    Melbourne Australia
    I have just seen this copper prices have fallen to 6938.50 a ton.
    London Metal Exchange: Copper
    Nooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooo
    just when i though my day couldn't possible get any worse it does.
  20. #15
    The red brass, is that a good example of what I call bronze?
  21. #16
    waredu's Avatar
    309
    95
    According to wikipedia
    Bronze is typically 88% copper and 12% tin. Various other bronzes range from 90% copper down to mid-50s% copper, mixed with tin, lead, phosphorus, zinc, etc.
    Red brass (also known as gunmetal) is 88% copper, 10% tin, and 2% zinc. It is a type of bronze. Again, some of the percentages can be a bit different.
    Yellow brass is an alloy of copper and zinc. Different percentages give different strengths, malleabilities, and other properties.
    All bronze and brass are copper alloys. The other metals alloyed with the copper give it unique names and properties.
    From what I can see in the pictures, it looks like a red brass valve attached to a yellow brass fitting. The lighting could also be playing a factor.
  22. #17
    4,756
    6,036
    My yard pays all brass as yellow brass. Some info on brass here... http://planet-metals.com/brass/
    1. Hard Drive Value
      Last Post: 11-13-2013, 08:45 PM
    2. Hard Drive Erase Software. Requirements For Selling Hard Drives
      Last Post: 08-23-2013, 03:30 AM
    3. brass valve stems
      By levjo in forum Scrap Metal Questions and Answers
      Last Post: 09-08-2012, 08:52 PM
    4. hard drive base ?
      By EcoSafe in forum General Electronics Recycling
      Last Post: 09-07-2012, 10:10 PM
