Results 1 to 16 of 16
approximate value of a scrap refrigerator
    Tcgs started this thread.
    Tcgs's Avatar
    181
    47
    I have been wondering if anyone has an approximate value of a scrap refrigerator. Assuming if you get steel, copper motor, freon, wire, radiator, and anything else? Total average?
    Tcgs's Avatar
    181
    47
    $15 is my guess
    bigdog72 is offline Metal Recycling Entrepreneur
    bigdog72's Avatar
    honey brook PA
    274
    14
    my yard charges to take them, i have yet to find someone to remove Freon for me
    6,996
    15-20 bucks depending on the persons shred price. I'd say most weigh at least 150 pounds so if you are close to the .10# mark you are going to hit $15 before breaking it down further.
    sirex is offline Metal Recycling Entrepreneur
    Mar 2013
    Space Coast of Florida
    34
    Just got 18 dollars for one without the compressor or wire. Was a two door with ice makernand water dispenser in the door.
    boise, ID
    1,603
    464
    When I'm out bidding on refrigerators, I figure 225 pounds of scrap, 20 pound compressor, 1.5 pound aluminum radiator, 1 pound of copper and a pound of insulated wire. I don't factor in refrigerant as is usually is 134A which has basicly no value. Those numbers are based on a mix of side by side and top mount refrigerators.
  7. The Following User Says Thank You to freonjoe for This Post:
    Phantoms001 is offline Metal Recycling Entrepreneur
    Phantoms001's Avatar
    556
    165
    I think it also depends on if you cut open the compressors, the best way to really find out is to scrap a few, but I personally think they are a little more in the 30.00 range on average (but I cut open compressors).
    Russell's Avatar
    Chicago,Il
    815
    495
    depends on the size
    $20 bucks is a nice round number, overall for a unit.
    I do a lot of apartment size units that only weigh about 125 lbs I always pull wiring but cant always pull the compressors. I avg around 15$ on the size that I typically do. I have a nice load this week of around 16 fridges with other stoves dishwashers and built in microwaves.
    Fridges take up a ton of room for what you get out of em. Make sure you stuff them full of smaller stuff. You can get some incredible loads, when you have a bunch of loaded fridges I do like em overall. Id rather handle one thing weighing over a hundred pounds than handling 5 things weighing 20 lbs.
    Tcgs's Avatar
    181
    47
    Well, I have a handfull in my inventor, Ill put them on the scale after doing and breaking down and give you the weights. Then you can determine your own rates.
    ggariepy is offline Metal Recycling Entrepreneur
    ggariepy's Avatar
    Southeast Michigan
    157
    87
    The refrigerant disposal keeps me away from them. I called around and could not find anyone willing to extract the refrigerant from one for less than $65. Since I don't get them regularly enough to justify the expense of becoming licensed and purchasing the equipment to do my own extractions, I leave them alone. LOTS of people in my area apparently just cut the line and let the refrigerant leak out, but that $10K fine does not appeal to me in the least!
    I am always going to be a part time scrapper, doing it as a hobby, having fun and making a few bucks. There is just no way I could replace my employment income and insurance with scrapping unless I went all in, took a huge business loan to buy a facility, equipment and hire people. So when you're in that situation you have to accept that there are some things you just can't do, and dealing with charged refrigerators and A/C units is one of those things.
    Hope this helps.
    --Geoff
    Tcgs's Avatar
    181
    47
    I was able to replace my income with scrap. Have recovery machine. 608 cert .
    GREENTRUCK
    "CHANGING THE WAY YOU LOOK AT RECYCLING"
  13. #12
    Tcgs's Avatar
    181
    47
    I will do a test to determine the weights and values of appliances like refrigerators, stoves, microwaves, dishwashers, and any other item. Lets put my scales to the test.
  14. The Following User Says Thank You to Tcgs for This Post:
    easton, ct
    The copper in the compressor will add another $8-10 or so if you cut the top on that and scrap the copper.
  16. #14
    Russell's Avatar
    Chicago,Il
    815
    495
    You pay for your fridges, Joe?
  17. #15
    boise, ID
    1,603
    464
    Russell, I will as long as it's a steady supply. I have one customer that kicks out 1 to 2 trailer loads a week so I kick them back 4 bucks a unit.
  18. The Following User Says Thank You to freonjoe for This Post:
  19. #16
    Russell's Avatar
    Chicago,Il
    815
    495
    I assumed you did, based on volume, Joe. Just wanted to confirm. I have a nice account that produces a lot of appliances but inconsistently. I don't pay for them. Id like to obtain more accounts. There is a small mom and pop appliance store within walking distance of my house, that I've been eyeballing. I've seen old beat up trucks lugging out old appliances through the back. Just brainstorming ideas on how to approach them. I couldn't see paying more than 5$ a unit and making it worth while.
    1. how to scrap a refrigerator?
      By DropYoTop in forum Scrap Metal Questions and Answers
      Last Post: 06-11-2020, 05:26 AM
    2. Looking for refrigerator / air conditioner scrap compressors Please Help
      By alphauby in forum Best Scrap Metal Spots: Where to Find Scrap Metal for Recycling
      Last Post: 05-27-2011, 06:22 PM
    3. Need help with my refrigerator
      By Motörhead in forum Off Topic Discussions
      Last Post: 05-20-2011, 07:07 PM
Tags for this Thread
