Results 1 to 14 of 14
brass fittings
| Scrap Metal Identification
    dc0613 started this thread.
    hamilton ontario
    brass fittings
    how's it going everyone, been reading a lot on here and taken in a lot of useful information so thank you. pretty much just getting into the scrap industry up here in Canada, done it a little here and there but not in depth ripping stuff apart however i do have one question since i started doing this i came across a bunch of what looks like yellow brass fittings but when i put the porcelain magnet over it, it sticks in spots where it looks like there is steel. if i took these to the scrap yard what price would i get for them cause im trying to maximize all that i can! thanks a bunch
  2. The Following 2 Users say Thank You for This Post by dc0613:
    A magnet should not stick to brass, to double-check hit the fitting with a file. (don't literally hit it, file it)
    Check the color under the coating.
  4. The Following User Says Thank You to Mechanic688 for This Post:
    1,910
    1,682
    If it sticks in spots and not completly magnetic, it would go as dirty brass or brass breakage.
    Aslo like Mech said, file it and check underneth the finish because sometimes its brass colored cast alum
  6. The Following User Says Thank You to greytruck for This Post:
    6,815
    if you'd post a photo you might find it's something easy enough to clean, like if it's just a spring or pin inside it, or a steel shaft of a faucet
  8. The Following User Says Thank You to Bear for This Post:
    Central Illinois
    Thanks for asking the question. Here's another... What if there is excessive teflon tape or tread dope on the fittings? Shoud I take a brush grinder to them or leave them be?
    Quote Originally Posted by SgtWentworth View Post
    Thanks for asking the question. Here's another... What if there is excessive teflon tape or tread dope on the fittings? Should I take a brush grinder to them or leave them be?
    My yard does not care but I don't know about yours.
  11. The Following User Says Thank You to Mechanic688 for This Post:
  12. #7
    Central Illinois
    Yeah I don't know if they do or not. I'll give them a call before I go. Truthfuly, I have never been to any yard... I work for a propane company and we have lots of leftover copper, brass, and regulators that I get half of if I sort it and take it in. This will be my first time going in. I have a pretty decent load (I think) since the material has been piling up for years.
  13. The Following 2 Users say Thank You for This Post by SgtWentworth:
  14. #8
    Russell's Avatar
    Chicago,Il
    815
    495
    You can take in a small amount. You can see how they grade and price it. I did this a few times with various items. organize your samples according to what you think they are. Learn how and why if they grade them differently.
  15. The Following 7 Users say Thank You for This Post by Russell:
  16. #9
    2,864
    350
    Bear; I think he has to have more than 2 post in order to post pics. DC; Sounds like there is some steel in your fittings if a magnet sticks in just certain areas of the fittings, even if they where cast aluminum with a brass finish a magnet would not stick to it. If you can't find the steel in the fittings just take it in as is and take dirt brass price for it. My .02
  17. The Following User Says Thank You to happyscraper for This Post:
  18. #10
    6,815
    I'd recommend at least knocking off the big spots before you take it in, then if you have questions(you'll know if they look at something rather heavily) just ask
    Take your worst stuff first too, that way when you get to the good stuff, they'll think you worked on it all day, and you'll know what's happenin ; )
  19. The Following 2 Users say Thank You for This Post by Bear:
  20. #11
    6,815
    not really great advice(IF he wants it clean), so very often that one lil pull from the magnet is only a few twists away from being removed. It also takes a little experience to know just how many twists you're willing to make while still thinking it could be worthwhile
    My apologies happy, i just realized you noted "if he can't find it" ; )
  21. The Following User Says Thank You to Bear for This Post:
  22. #12
    hamilton ontario
    hey everybody thanks for all the replies, i had to go up north to peterborough to do some work so i wasn't able to reply!, everyone gave me some good advice and i appreciate it! turns on there was just steel pieces on the ends after going through them with magnet, they were air hose connectors so just had to cut them off only took a couple mins
  23. #13
    little726's Avatar
    74
    1,377
    Quote Originally Posted by dc0613 View Post
    What is a "porcelain magnet?"
  24. The Following User Says Thank You to little726 for This Post:
  25. #14
    Mar 2014
    I have a question that relates to Brass. I've been looking for charts on price fluctuation over years, anyone k ow where to find one??
    1. brass ends on powercords, brass connectors on crimped wires in monitors & tvs
      Last Post: 06-17-2013, 10:09 PM
