Originally Posted by
jghilino
most people dont know the difference between radiation and radioactive, they just assume that a radiation emitting device is radioactive
There was a post here not long ago that did have the 'real facts' on microwave radiation.
It turns out there IS radioactive stuff in a microwave. A tiny amount & its similar to the radioactive material in gas light mantles. But it does set off the alarms at the scrapmetal dealers....
It helps the magnatron 'emit' the microwaves, sorta like how the gas mantles 'emit' light.
I think the best way to get the copper from the magnatron is to use a lathe & machine off the weld from each end. That'll give you a 80 gram chunk of copper. I'm saving up to get 100 of them.
I tried grinding the weld off & it took a long time, dirty dusty & messy, oh, & Hot as the metal heats up quickly & coppers a great conductor of heat.
You will also have to lever out the other metal plate thats under the stainless steel end caps & cut/break the little copper wire that holds the Tungsten emitter thing.
