Results 1 to 14 of 14
Now this is a magnet!
| Tools and Equipment
    hobo finds started this thread.
    4,758
    6,039
    $340.00 565 lb pull force!
    K&J Magnetics - Products
    3,436
    The real test is if it can pull that skirt off your avatars tushy
  3. The Following 10 Users say Thank You for This Post by BRASSCATCHER:
    Otto's Avatar
    Ottawa, Ontario
    335
    494
    It would be tough getting it off anything it's stuck to.
    pcscrapper's Avatar
    623 s Lyon st Suite 200 Sioux Falls SD 57104
    657
    576
    good way to keep someone at thier chair for a while.
    Please Add Us On FaceBook, PC SCRAPPER Sioux Falls SD
    also our Prices are listed here http://pcscrapperS.com
    PC Scrappers LLC
    623 S LYON ST SUUTE 200Sioux Falls, SD 57104
    1-605-271-2616
  6. The Following User Says Thank You to pcscrapper for This Post:
    May 2012
    SC - NC State Line
    220
    50
    i keep pinched fingers from dealing with the small HDD magnets, cant imagine having something that big, lol I would probably end up in the ER .. ha ha ha
  8. The Following 4 Users say Thank You for This Post by theelectronrecycler:
    billygoat's Avatar
    630
    99
    I'm trying not to think about trying to pick up one of those while wearing steel toe shoes.
    bcrepurposing's Avatar
    Northern Central MN
    152
    Those could be very useful to those of us that scrap heavy metal items. It gives me an idea how to make a portable magnetic lift to lift things into truck...
    travistemple202020's Avatar
    ames iowa
    1,326
    267
    magnets are awesome but can be very deadly if you do not understand the field strength of the ones your using the cartoon instance were things going flying across the room can be achieved but more likely in our business it would be something close like a screw or nail near by as were playing with it and rips through your hand lol as for your truck brcepurposing that's and electromagnet this one would just stick to your metal and have to use more strength to pull it off but hard drive magnets can achieve this if you use a plate backing and some good glue to attach about 100-150 magnets to which will lift about 250-400lbs depending on if your using the same sized magnets and attach it evenly to the object and lift it that way so when your in the bed of the truck then break the force easily enough by lifting from the corner of the plate. do a few trial and error runs most with glue strong enough to hold when pulled of the object
    waredu's Avatar
    309
    95
    Quote Originally Posted by bcrepurposing View Post
    Or get a couple of them and just lift the back end of the truck...
    6,815
    a plate with a hydraulic cylinder might work easy enough
    Travis, no offense but it's really hard to read your posts without punctuation and spacing. It gives me a headache.
    Guys, maybe this would help, we seem to be a hands on type of people, make our own electromagnet. Just a smaller one like at the yards but for the back of the truck.
    https://www.google.com/#q=homemade+electromagnet
  15. The Following 3 Users say Thank You for This Post by Mechanic688:
    skylinejack's Avatar
    Baton Rouge, La.
    827
    1,194
    [QUOTE=Mechanic688;183375]Travis, no offense but it's really hard to read your posts without punctuation and spacing. It gives me a headache.
    ^^^^ YEP^^^^ *1 ^^^^
  17. The Following User Says Thank You to skylinejack for This Post:
  18. #13
    Northern Central MN
    152
    my original thought had been to use one of the magnets the same company makes that is a ring. if you change polarity on electronically charging them you have lift and drop. an a frame with electonic winch would give you a lifting platform.
    "Reuse, Repurpose, Recycle..." - BC Repurposing Motto
    www.bcrepurposing.weebly.com
    https://www.facebook.com/bc.repurposing
  19. The Following User Says Thank You to bcrepurposing for This Post:
  20. #14
    We use a magnetic table in the machine shop to hold metal when we surface grind something.
    Its a block of metal 8 x 14 x 4 with a handle on its side.
    Its full of magnets & the field projects out the top of the table, grabbing anything metal in its grasp.
    The lever rotates some magnets inside the unit. They either act. Or counteract, breaking the magnetic feild.
    No good for scrappin though.
    1. Chick Magnet :)
      By Jonniebrass in forum Made From Scrap
      Last Post: 06-08-2013, 06:16 PM
    2. Magnet Sweeper Idea
      By cobre collector in forum A Day in the Life of a Scrapper
      Last Post: 03-15-2012, 10:36 PM
    3. AC Magnet / Eddy Magnet
      By Kris Kringle in forum Tools and Equipment
      Last Post: 12-13-2011, 10:04 AM
    4. Magnet Wire?
      By CageK in forum Scrap Metal Questions and Answers
      Last Post: 08-11-2011, 04:38 PM
