Results 1 to 12 of 12
Breaking down SMALL motors - the numbers
    redcrossnj started this thread.
    redcrossnj's Avatar
    central jersey
    465
    28
    was at my local yard doing my thing and this was in the parking lot almost ran it over . My school canceled today cause of snow so I figured I would post this thread .
    the motor weighed in at 3.2 #
    If I turned it in as is I would have got 0.96 cents
    I broke it down .
    heres what I got
    6.3 oz of #2 copper at $2.70#=$1.05
    1 pound 6.8 oz of shred at $0.09 #= $0.12
    15.5 oz of FE aluminum at $0.20#=$0.19
    0.04 oz of insulated wire at $0.90#=$0.0225
    Total value AFTER breakdown= $1.38
    A difference of 0.42 cents
    toke me less then 5 mins, ive done a lot of motors .
    I sometimes Buy what I think are high copper recovery DC motors from the yard I buy at for $0.40cents a #
    sometimes. Might soon experiment with alternators
  2. The Following 5 Users say Thank You for This Post by redcrossnj:
    Otto's Avatar
    Ottawa, Ontario
    335
    494
    If you had bought the above motor for $0.40 per lb, you would have made 10 cents.
  4. The Following 3 Users say Thank You for This Post by Otto:
    redcrossnj's Avatar
    central jersey
    465
    28
    yes I know I wont buy them that small unless the rotor is removed and the casing is off and its just the stator . I usually buy motors I know are 100% copper and have high recovery. I might buy an alternator and see what the return is.
    lousypirate's Avatar
    Marne, MI
    440
    35
    .42 for <5 minutes of work...
    if you were as quick as 4 minutes, you are only netting $6.30/hr extra profit...
    I guess I could see larger motors with higher copper return.
    I have an alternator on my shelf. I can tear it apart and weigh it out (when I buy a scale)
  7. The Following User Says Thank You to lousypirate for This Post:
    jghilino's Avatar
    KANSAS CITY
    2,672
    1,429
    you will do better on alternators at 40 cents than electric motors i think, alternators have heavy aluminum cases
  9. The Following 2 Users say Thank You for This Post by jghilino:
    redcrossnj's Avatar
    central jersey
    465
    28
    thanks . I can remove the rotor and sell it as an alternator at my other yard for .40 #. My plan was to remove the copper from the stator and separate the aluminum too .
    redcrossnj's Avatar
    central jersey
    465
    28
    hopefully alternators will help me grow and my bottom line
    SCRAPCOWBOY's Avatar
    virginia
    59
    51
    If you fined a good core buyer you can get .50 to .60 per lbs for starters and alternators for scrap. Good cores can go as high as 25.00 each.
  13. The Following User Says Thank You to SCRAPCOWBOY for This Post:
    redcrossnj's Avatar
    central jersey
    465
    28
    not trying to sound like a rookie lol But any advice on how to find a core buyer ScrapCowboy?
    MattInTheHat's Avatar
    rock hill, sc
    1,464
    1,142
    Quote Originally Posted by redcrossnj View Post
    make friends with a mechanic, a lot of them go to garages to buy cores.
  16. The Following User Says Thank You to MattInTheHat for This Post:
    redcrossnj's Avatar
    central jersey
    465
    28
    might just do that . because starters are not worth buying to break down. alternators are though from what ive seen , if all else fails shop around to different mechanics
    Usa
    763
    67
    I had a 3 phase motor that weighed n a 37 lbs or $9.60ish in motor weight. I looked inside and maybe pushing 2 lbs copper if you lucky. So the moral of the story is, not all big motors are worth teardown.
  19. The Following User Says Thank You to ozzy214 for This Post:
    1. No more small motors for Me!
      By Gravitar in forum A Day in the Life of a Scrapper
      Last Post: 07-30-2012, 03:51 AM
    2. Breaking down motors
      By Torchy in forum Scrap Metal Questions and Answers
      Last Post: 03-28-2012, 10:03 PM
    3. Small Electric Motors From Printers/etc
      Last Post: 03-22-2012, 12:05 AM
    4. breaking down a small mobile home frame
      By EcoSafe in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 10-03-2011, 02:52 PM
    5. Windings on SMALL motors
      By lvservicesolutions in forum Scrap Metal Questions and Answers
      Last Post: 08-23-2011, 08:49 PM
