Results 1 to 20 of 25
My Scrapping Log (including e-scrap)
    PinkFloydEffect started this thread.
    116
    50
    Arrow My Scrapping Log (including e-scrap)
    So I have been scrapping for several years learning more every year, I started like everyone else throwing everything as light iron. Now I separate everything and am into e-scrap, I decided to start posting some of my process feel free to comment. I fill these truck bed liners with light iron/e-scrap cores after the majority of plastic has been removed:
    After the plastic removal I pull all wires, motors, and circuit boards. Then I pull the aluminum heat sinks, transformers, inductors and visible copper goodies. The cracked up and stripped boards then go into those orange tubs, there is also a non-mag stainless bucket, brass, copper #1 & #2 in the photo:
    For now I throw all the transformers and inductors into one bucket and get $0.20/lb which is not that great not sure if I can get more for the inductors:
    This is an example of some of the things in my transformer bucket, I think the small items up front should yield more then transformers:
    I have this bucket as well that I throw visible copper goodies in that are not wrapped in tape, etc, I think some of them might be inductors as well but I smash and unwind these in front of the TV lol throw the wire in my #2 bucket:
    All the wire will be stripped someday, I could stop now and sell the boards without the aluminum and copper goodies I think they actually prefer you strip the heat sinks and they tolerate the copper wire component removal but I'm not sure if its okay I had to break many of the boards to remove the heat sinks. I am between that and processing them further myself, if I take anything else off I would have to make it worth it and take everything possible or else I think I would break even between selling the boards and just stripping a few things it would be a lot less work to just sell the boards...I know I need to take the ICs and a few other components including gold connector pins, and then I can sell those components by weight and even some such as ICs can be processed myself. I've seen ICs burnt with a torch contained in bricks slowly fed to prevent smoking, after being burnt cleanly thrown in a bucket with some steel balls and I think a paint mixer on a drill so everything is smashed into a dust/powder then mixed with water and "panned" off...not sure where my cutoff line will be but it is a good way to save if you are not good with money haha.
  2. The Following 13 Users say Thank You for This Post by PinkFloydEffect:
    Alabama
    764
    1,062
    Looks like you have a good sorting system going. I like the bed liner shred bin. I didn't see a bucket for your higher grade green boards from the printers. Be sure you're saving those out separate from the low grade.
    Gotta love making money unwinding copper while watching TV.
  4. The Following 2 Users say Thank You for This Post by Pnutfarmer:
    116
    50
    I have 5 of these bedliners, I leave one for people to dump their stuff in too. I do not separate boards by grade since I was going to process them myself anyway but if I do then I might loose the value of the things I am not capable of removing or processing. Haha ya in front of a big screen that was free in my scrap drop off, I use it in the basement.
    2,863
    349
    How about the electric motors from the printers? If your going to take the plastic off and pull the boards you should also take the electric motors. Those little white round things in the bucket in the last pic. are easy to take the copper off of. Slide them on a screw driver, grab the two wires and pull, quick and easy. Did you take the electric motor out of that fan in the first pic? Those moters and the transformers should go together. I wouldn't sell my transformers and electric motors for .20# I get .34-.35#.
    116
    50
    No some of those motors in the printers I leave they are so small and some are bolted with tight angles and weird screw heads I do pull some though. I always strip those in the last picture. Yes I removed the motor from the fan I do not mix motors with my transformers because my yard to date (1/09/14) pays .20 for transformers and only .18 for electric motors I was also told to remove the flyback transformers from my bucket and throw them with light iron.
  8. The Following User Says Thank You to PinkFloydEffect for This Post:
    6,126
    11,842
    Those ones in the bottom bucket, I use a hammer on. lol. Makes short work of them, smash it, an watch it fall off. Probally no the route to go while watching tv tho. I do mine in the shop to music, when things get slow or I need a break from the other stuff.
    Makes the old copper bucket fill up fast. An I also like your buckets, good stuff.
    Sirscrapalot -Truth comes out in wine. - Pliny the elder
  10. The Following User Says Thank You to Sirscrapalot for This Post:
    116
    50
    Yeah I use a hammer for almost everything, smash up the magnets and they fall out in pieces.
    My 5-gals are always a 2lb tare, and I use chlorine buckets for E-components. The truck bed liners were free I got a half dozen for storing light iron and aluminum!
  12. The Following 2 Users say Thank You for This Post by PinkFloydEffect:
    ks
    2,187
    2,513
    I use old stock tanks for collecting and sorting larger items, but whatever is availible and cheap works too.
    Whatever you use to sort and stock pile goodies, there's never enough of them.
  14. The Following User Says Thank You to taterjuice for This Post:
    6,126
    11,842
    Quote Originally Posted by taterjuice View Post
    Ain't that the truth! It seems every time I think I have enough, I need to get/make more! Grrr!
    Ah well, it keeps us on our toes I reckon. While I don't have truck beds/liners..I think my most unusual 'bucket' is the back shell of a large tv. Found it on the side of the road one day, sucker holds a lot!
    Sirscrapalot - It ain't easy being green. - Kermit the frog.
    116
    50
    I'm down to e-scrap right now, still trying to get my system in order there. Basically I have two piles that are sorted into two general categories; low grade and higher grade. I have another pile the size of that large pile that has not been cut yet; all the guts of electronics go into one bin until I have time to remove all the wires and metal trays/heatsinks. That is a 12oz beer for size comparison and I will break these piles into finer grades, I still have a whole shelf full of CD/DVD drives, floppys and HDDs that need to be disassembled...printer cartridges are building up too. I have had time to think and learn the hard way about processing my own boards and I am just saving them to sell as is, I may pop some hand fulls of larger tantalum capacitors and sell them on eBay since their weight on the boards are only worth around a few dollars a pound when nobody will notice a few missing here and there and I will not take enough from any one board to downgrade it as controversial as that may sound...the trick is just don't piss off your buyer.
    466
    1,609
    Check to make sure you are identifying the tantalum capacitors correctly. "Handfuls" are not easy to come by.
    116
    50
    I have done extensive research into tantalums from SMD to dipped to Kermet to silver mica (standard and Russian style) and silver cased I have a chart on my wall where I work.
    Baltimore
    390
    119
    A picture of said chart would be helpful or the information stating the charts name date and publishers. If not a big deal. Thanks. I'd like to see what it displays.
  20. The Following User Says Thank You to blacksteel for This Post:
  21. #14
    TheRecycler's Avatar
    Ithaca, NY
    616
    31
    You've got a good setup. I hope you cut the ends off those radiators.
    Your Trash-My Cash
    Yours Truly, TheRecycler:
    RecycleReuseItAll@Facebook.com
  22. The Following User Says Thank You to TheRecycler for This Post:
  23. #15
    116
    50
    Its a homemade chart I printed, I will upload all the pics on the chart this weekend identifying tantalum so you guys can see them it covers everything.
    I certainly did cut the ends off those radiators brings the value way up if you remove that iron/steel, my system is about to get even better this weekend I will post pictures; I have a new metal rack that holds all my board bins (which I am still figuring out/grouping).
  24. #16
    Baltimore
    390
    119
    Saw a great YouTube video that really explained things with boards. Sorry no link. I don't know how. But the video really made me think. Happy scrapping. 1scrap.
  25. #17
    116
    50
    I have probably seen it, I have seen lot and lots of scrapping videos on Youtube.
    This is the cart I store components to scrap such as capacitors and copper windings, inside are the charts you requested and I forgot to open the cart for a picture! ha I will next weekend...I promise. I also store CD/DVD drives, HDDs, floppy drives and power supplies that all need to be broken down in there. The crate on top holds unsorted boards they are not usually in piles on the floor like the previous photo and there are a few charts to identify useless components on there of things not to confuse with capacitors. To the right there are two stacked trash barrels full of un-stripped copper wire...I have CCTV cameras all over the place as this stuff builds up as its my hard work.
    The unsorted crate is where the boards go before the wires, heat sinks and metal parts are removed. They then get sorted into the rack in the background:
    Taking my allotted sorting space into account I built this rack out of 2 shelves, old recycling bins and coffee containers. I think I can make do with this and when they get full maybe I will band stacks of boards into bundles or something. This is how I am sorting from top to bottom:
    -Telecom/Communication/Cisco/Networking (finer sort at a later point)
    -Complete Finger Boards
    -Dual Socket Server Boards (small socket/DIVIDER/large socket)
    -PC Motherboards (small socket/DIVIDER/large socket)
    -Power Supply Board (DIVIDER) Cable & Satellite/Printer/Modem/Floppy Boards
    With 5 shelves I can fit 30 coffee containers it's tight (6 per shelf; 4 in the front and 2 in the rear centered for extra overflow storage mostly printer cartridges) this is how I am sorting from top to bottom:
    -Cell Phone Boards / Gold Tip Ram
    -HDD Boards / Silver & Tin Ram
    -Rambus / CD & DVD Boards
    -Intel 386 and 486 / Motorola CPU & Pentium Pro Gold Caps / Cyrix-IBM-VIA Gold Caps / Pentium Ceramic
    -AMD Ceramic (without Al. Cap) / Black Fiber CPU / Green & Brown Fiber without Heatsink / Printer Cartridges
  26. The Following 2 Users say Thank You for This Post by PinkFloydEffect:
  27. #18
    116
    50
    I have a lot to update you on and photos of my process to take, I have lots saved up and have been holding out on cashing in. Unfortunately I took a hit from a TV tube that broke in half and came crashing down on me, I turned my head just in time and it ripped through my cheek but I avoided a missing nose or eye...it was extremely sharp and made a very clean cut that I never even had stitched which it should have but it made a quick recovery already but it was very deep but all the way through.
  28. The Following User Says Thank You to PinkFloydEffect for This Post:
  29. #19
    116
    50
    Back to the top if you look at the very first image I started this thread with this is the same pile...that little white bike is under there the pile is VERY dense:
    To the right of that as I said I have multiple liners, I store large light iron shells on the left (that I can stuff with metal as I load it onto truck) and my prepared steel on the right side:
    I have a liner to the right of that which holds my aluminum and other odds, my yard takes all cast/sheet aluminum in one class they also buy batteries and radiators (I have not prepared those in photo the magnetic ends need to be removed from radiators)
    All the way to the right I store my electronic scrap brown board as is takes up a lot of space and is worth practically the same as light iron or steel...I hope the rain and snow does not devalue my brown board?
    All in all the truck bed liners work really great, not including the brown board I pulled little over $500 out of here and it all trickled to me slowly none of it costed me anything and it wasent that bad of an eyesore but I am going to improve on containment:
    I have another liner that I allow people to drop their "junk" off in this is just an assortment of the types of things people drop off it has been working good but I have been limiting the tubes lately since my facial accident:
  30. #20
    All in all the truck bed liners work really great,but I am going to improve on containment:
    I don't have truck bed liners but I do have 3 plastic barrels (50 gal.) and a handful of metal barrels if needed. Check on CraigsList for barrels.
  31. Similar threads on the Scrap Metal Forum
    1. Log splitters?
      By jthetravelingguy in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 07-25-2013, 04:46 AM
    2. Log splitter input needed
      By BurlyGuys in forum Scrap Metal Recycling Tools & Equipment
      Last Post: 04-25-2012, 04:44 PM
    3. CRT Log Document
      By takenbyvultures in forum TV and Monitor Recycling
      Last Post: 11-29-2011, 08:53 AM
    4. Copper thieves are everywhere including 100 feet up!!
      By tekscrapper in forum A Day in the Life of a Scrapper
      Last Post: 09-06-2011, 10:48 AM
    5. Alabama - - North central including Cullman, Blount, and Lawrence county areas
      By papajoe in forum Scrap Metal Removal, Junk Car Removal and Metal Recycling Services
      Last Post: 06-03-2011, 08:24 PM
