Results 1 to 11 of 11
Best wire stripper?
| Tools and Equipment
    Recycled started this thread.
    Jan 2014
    Myrtle Beach
    Best wire stripper?
    I've been looking at wire strippers online for the last few days and I'm looking to buy a good reliable one. Previously I had a homemade one but after stripping a bunch of wire, its falling apart and isn't working out.
    So I found these four, but I'm open to suggestions and absolutely in need of opinions.
    New Cable Stripper Wire Stripper Stripping Machine by Checkpoint Industry | eBay
    Handheld Wire Stripper Using Stock Blade Portable Stripping Machine Pocket Size | eBay
    Wire Stripper Strip Scrap Copper Cable Machine Stripping Tool Portable Manual | eBay
    Drill Operated Powered Cable Wire Stripping Stripper Machine Strip Copper×blades | eBay
    sawmilleng's Avatar
    Central Kootenays, BC, Canada
    861
    713
    We own and have used the last one on your list-- advertised as "drill operated" (but comes with a crank.)
    Not sure if it is the same supplier but the product looks the same. We have used it to strip miles of No. 14 stranded wire (small stuff) and it works "OK". The set screws on the bottom v-rollers are made from swiss cheese and we had to find some decent quality (metric) North American ones to replace them. Couldn't keep the original ones tight once the hex heads stripped out.
    Its a bit of a pain to get it to track the cutting wheel right down the center of the wire but once you learn the technique you can cut the insulation pretty quickly. Zipping the wire out of the insulation is sometimes a pain, at least to get the end of the wire out so you can grab and pull.
    I'd rate it a 6/10--works but there's gotta be a better way!!
    Jon.
  3. The Following 2 Users say Thank You for This Post by sawmilleng:
    Jul 2013
    cajun country, louisiana
    64
    57
    I have a machine closer to the last one (a cheaper one) that works fine. Though I know a few people that have something closer to the 3rd one and they like it, I don't have any experience with it so I cant say anything about it. The one I have you still have to work with smaller wires, but It gets the job done
    1,910
    1,682
    I got one like the 3rd one. Its by TNT Tools not by glide gear. It works great.
    auminer's Avatar
    Allen, TX
    1,233
    579
    15,631
    I also own one very similar to the last on your list. I also agree that the set screws should be replaced. I bought a set of T-handle allen wrenches to tighten the set screws and make adjustments. Its an effect tool when mounted and with a drill to power it. I was able to strip a variety of sizes and types of insulated wire. I don't do any wire stripping these days since I am busy with other scrap. Mike.
    lousypirate's Avatar
    Marne, MI
    440
    Best wire stripper?
    I had a thought on stranded. since it lays straight and not twisted, you could strip a fair length (say 3"). then you could have a small draw shave and just pull. the copper strands should keep it centered if you split it right, and then the two halves would just peel off. Put the stripped end in a vise, or chock the draw in a vise and pull. Could make it with utility blades pinched between some flat stock with a bevel in it.
    http://m.northerntool.com/mt/www.northerntool.com/shop/tools/product_200611443_200611443
    I might play around with something when I am at the welding shop tomorrow...
    218
    130
    Have the last one. Would give it a 5 out of 10. I feel it is hard to keep wheel tracking center of wire. Bigger wire strips easier.
    Jun 2013
    South Dakota
    25
    I have both the 1st on and the 3rd one. I think the 3rd one sucks for smaller diameter wire as it is hard to keep it centered on the cutting wheel. I bought the 1st one after I sold my last bucket of copper and like it much better. It is very simple to operate. The only downside is that you have to pull the wire through it by hand. I use it for the smaller diameter wire and the other stripper for the larger diameter wire.
  11. The Following User Says Thank You to sdakscrapper for This Post:
    redcrossnj's Avatar
    central jersey
    465
    28
    I have a coppermine which is similar to the first one . I also have various 2x4 wire strippers with drywall screws.
    Jan 2014
    Myrtle Beach
    Now I'm conflicted with the stripper from TNT Tools and the first one on the list...
