Results 1 to 17 of 17
Brass....I found Brass!!
    Mudlucky started this thread.
    Mudlucky's Avatar
    May 2013
    Wisconsin
    398
    220
    Tonight I was tearing down hard drives during the (not so) Super Bowl. When I started sorting things after the game, I had four hard drive covers that were unusually heavy. The magnet didn't stick. I pulled out the grinder and low and behold....it was brass! From those four drives alone, it was over a pound of brass.
    Keep a look out for brass hard drive covers when you are breaking down those hard drives!
    Osage,IA
    133
    54
    Thats new to me as I always thought stainless steel or aluminum.
  3. The Following User Says Thank You to IAscrapper for This Post:
    Mudlucky's Avatar
    May 2013
    Wisconsin
    398
    220
    they were in HP Wide Ultra320 SCSI drives.
  5. The Following 3 Users say Thank You for This Post by Mudlucky:
    Wisconsin
    159
    140
    Thanks for this. Just did the exact same thing last week. Thought there was no way they were brass and was going to run them to the yard and get their opinion. Got about 30 of them.
  7. The Following 3 Users say Thank You for This Post by johnuppy:
    Oct 2013
    Indianapolis
    16
    Which model??
  9. The Following User Says Thank You to JKBINDY for This Post:
    Mudlucky's Avatar
    May 2013
    Wisconsin
    398
    220
    Quote Originally Posted by Mudlucky View Post
    I don't know the exact model number. However, I found this on a 146.8, a 73.4 and a 36GB SCSI ultra wide HP. At the same time, I've torn down very similar hp SCSIs, but they have been stainless. It just pays to check them. I am in the habit of checking every hard drive cover as some are stainless and some are aluminum. I'm actually taking some to the yard this week to see what series of stainless they are. I almost think that some are 304 but some may be 316...especially on those SCSIs. We'll see.
  11. The Following 2 Users say Thank You for This Post by Mudlucky:
  12. #7
    6,126
    11,842
    I found Brass to! He's in NY!
    /duck
    Thanks for the heads up will keep eyes open for them.
    Sirscrapalot - BC you were lost but we found you!
  13. The Following 2 Users say Thank You for This Post by Sirscrapalot:
  14. #8
    3,419
    Good info Mud.... I have a box of them I have to put to the bench grinder tomorrow.... Right after I get done with SirS
  15. The Following 3 Users say Thank You for This Post by BRASSCATCHER:
  16. #9
    Wisconsin
    159
    140
    Quote Originally Posted by JKBINDY View Post
    Which model??
    I have one with a sticker left on it. It says IBM model DJNA-351520 E182115 PN AUG-1999
  17. The Following User Says Thank You to johnuppy for This Post:
  18. #10
    pcscrapper's Avatar
    623 s Lyon st Suite 200 Sioux Falls SD 57104
    657
    569
    just a FYI, some nuts that comes off of high voltage NON PCB transformer has brass nuts, and also some servers with the strips of fins are also brass, but some are copper, you've to get them checked out, so if you're breaking down server cpu heatsink, they may look like copper but some are not copper, so, check them break them in half and use a magnifier to see the ends to see if its brass or copper, I've come across a slew of server that has brass for heatsink with copper in the middle ..
    So, happy brass hunting.
    Please Add Us On FaceBook, PC SCRAPPER Sioux Falls SD
    also our Prices are listed here http://pcscrapperS.com
    PC Scrappers LLC
    623 S LYON ST SUUTE 200Sioux Falls, SD 57104
    1-605-271-2616
  19. The Following User Says Thank You to pcscrapper for This Post:
  20. #11
    happyisthealero's Avatar
    michigan
    529
    439
    got any pics?
  21. #12
    Mudlucky's Avatar
    May 2013
    Wisconsin
    398
    220
    Found brass plates twice today.
    IBM 146.8GB 10kRPM SCSI IMB P/N 33P3375
    And
    HP 146.8GB 15kRPM Wide Ultra320 SCSI Model # BF14688-003 (I think...I tore the plastic.)
    Kenny
  22. #13
    United States
    177
    How much does brass go for these days?
  23. #14
    pcscrapper's Avatar
    657
    569
    I can get some pics of brass. for you these came off of NON PCB trasnformer, and the high voltage amp boxes, the post is pure copper and the nuts are brass, as far as cpu heatsinks, from servers, I've found brass platting, with copper on top and bottom, will get again some pictures posted.. congrats to you mud for finding brass.. a very rare item in computer scraps.
  24. #15
    NHscrapman's Avatar
    new hampshire
    1,584
    4,066
    Quote Originally Posted by emeeks View Post
    I got $1.90/lb yesterday
    Your area may vary
  25. #16
    And don't forget the brass standoff's inside the older computers, occasionally their SS
  26. The Following User Says Thank You to Mechanic688 for This Post:
  27. #17
    kidpittsburgh's Avatar
    Nov 2013
    23
    I'm glad I came across this thread! Just started breaking down about 400 hds and found some brass ones.
  28. The Following User Says Thank You to kidpittsburgh for This Post:
    1. brass ends on powercords, brass connectors on crimped wires in monitors & tvs
      Last Post: 06-17-2013, 07:09 PM
    2. Brass
      By tryingtoscrap in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 09-30-2012, 02:26 PM
    3. To Brass or not to Brass ?
      Last Post: 12-01-2011, 06:24 PM
