Page 1 of 3 123 LastLast
Results 1 to 20 of 60
A Scrapper's Dream: electrical and non-ferrous
    Patriot76 started this thread.
    Patriot76's Avatar
    Buffalo Commons
    2,955
    10,578
    This thread was started for those of us that lack knowledge of e-scrapping, but come across some unusual finds on the farm or in building clean outs. It is pure laziness that motivates the creation of this thread. It is known that we should research previous threads for information before posting a question, but time does not allow it in this case. If you want to cuss me for my lack of research efforts in this regard, so be it. If you have knowledge and a willingness to share, that would be appreciated. If you want to add other questions or insights, that is welcomed as well.
    So first question, can anyone tell me what this is? What was it used for and what parts are valuable?
    Sorry for the quality of the picture. We do not have electricity in the building and this picture was taken using two pen lights. Have you ever taken a picture holding the camera with your hands, a flashlight in your mouth, and another flashlight held between your knees?
    6,810
    Are there any panels on it? Any type of screen? Light bank? What about a graph, chart type thing?(either circular or cylindrical) The top looks like an old phone bank but I'm more inclined to believe it's something to do with stats of operations, the wires each running to tattletale switches, gauges too maybe, throughout the plant
    I lightened it up a bit but it's still fuzzy. I believe it's some type of control panel
    imgbox - fast, simple image host
  3. The Following User Says Thank You to Bear for This Post:
    Patriot76's Avatar
    Buffalo Commons
    2,955
    10,578
    Was there no panels on it? Any type of screen? What about a graph, chart type thing?(either circular or cylindrical) The top looks like an old phone bank but I'm more inclined to believe it's something to do with stats of operations, the wires each running to tattletale switches throughout the building
    This is all that is left. No other evidence we can see with flashlights.
    6,810
    Can you get it out in one piece? Is it one large unit or a bunch of pieces? How is it mounted?
    PS you need a camera ; ) I did a thread once titled Photography 101 that might give you some pointers
  6. The Following User Says Thank You to Bear for This Post:
    sawmilleng's Avatar
    Central Kootenays, BC, Canada
    859
    712
    The top things look like resistor coils. The rest of the items with capacitors on them may be older versions of instrument "transmitters" or "receivers" --I'm not sure of the correct terms--but they would either send signals out to remote control valves or receive signals back from temperature probes, pressure sensors or the like. Usually used low voltage, (24V) and a 4-20 milliamp signal for controls.
    I'm buffaloed why the heavy resistor coils would be in the same box with the transmitter stuff. Usually the resistors would be with some power devices, for example, for braking on heavy electric motors.
    Any chance of more photos? Is there any sort of nameplate on the panel doors or inside the cabinet doors that might name the cabinet, giving a clue as to its use?
    Better get you a headlamp to put on your hard hat!! Way better than holding a light in your hand!!
    Jon.
  8. The Following User Says Thank You to sawmilleng for This Post:
    Patriot76's Avatar
    Buffalo Commons
    2,955
    10,578
    Bear, your thread on photography is well remembered. I am always reluctant to post pictures because of that thread, LOL. Maybe when I retire I will concentrate on photography. Until then it is point and shoot with the camera and the gun.
    Saw, a headlamp was available. Just forgot I was wearing it. Anyways a headlamp would not be as fun with three stories of exposure as holding a flashlight with your knees. And FYI I have not worn a hard hat for over thirty years, still wearing my cowboy hat. That will end soon.
  10. The Following 2 Users say Thank You for This Post by Patriot76:
    6,126
    11,842
    Some good decent head lamps out there to go with your cowboy hat....Used to use one when I was working for Amazon(dark in the campground!)LED..was like..10 bucks if that at walmart. Worked awesomely for several years, till I forgot where i put it, an when I found it, it was a in a flooded box.
    Good for just taking photos, if the other is overkill. Sure their even cheaper these days. Or if ya got a smart phone, the flashlight app, strong but will kill a battery.
    Yea, nothing earth shattering..just thoughts. Use at your peril.
    Sirscrapalot - Character is power. - Booker T. Washington
  12. The Following User Says Thank You to Sirscrapalot for This Post:
    spinroch's Avatar
    675
    1,981
    Shooting in the dark, here (heh heh!)
    The white blocks at the top look like 66 Blocks. Those are telephone or data termination blocks.
    The items below that look like individual power supplies. Possibly part of an old telephone system or industrial control.
    If you can get some better pictures.... you know the rest.
    F1 Recycles
    www.f1recycles.com
  14. The Following 3 Users say Thank You for This Post by spinroch:
    Caveman is offline Metal Recycling Entrepreneur
    Minnesota
    128
    44
    I think those top things are telephone equipment like mentioned. I've taken a few apart. Take the back/bottom lid off and hit all the grey tabs out from the front. They'll look like aluminum, but are copper with some kind of coating. Went as #2 copper.
  16. The Following User Says Thank You to Caveman for This Post:
  17. #10
    Memphis, TN
    117
    11
    possibly telephone termination blocks
    Looks to me like some type of old telephone termination equipment.
    Are there 2 wires twisted together making a "jumper" from left to right at the top of the photo? If so, then you have found the "cross connect" of the old telephone switching equipment. Typically, at a telephone company switching equipment location, the "cross connect" is called a Main Distribution Frame (MDF). The outside cables would terminate on the vertical side and the switching equipment would terminate on the horizontal side. Jumpers are run to connect a person's phone cable to the switching equipment.
    If this is an old key system (internal telephone system), the cables running to each desk phone would terminate one place and the switching equipment would terminate on other blocks. Jumpers would be run to "cross connect" the internal cable runs to the switching equipment.
    The bottom of the picture could some old mechanical switching equipment; can't tell from the photo.
  18. The Following 3 Users say Thank You for This Post by daw_green_clean:
  19. #11
    etack's Avatar
    Buying Tantalum capacitors
    United States ohio
    503
    437
    Looks Telephone to me too but way to grainy to tell. If you can take closer pics that would help too.
    Eric
  20. The Following User Says Thank You to etack for This Post:
  21. #12
    Patriot76's Avatar
    Buffalo Commons
    2,955
    10,578
    Everyone has motivated me to be a better photographer with a better camera, light, etc. Never had this problem scrapping farms. So much to learn, so little time. Thank you.
  22. The Following User Says Thank You to Patriot76 for This Post:
  23. #13
    6,810
    Most any point and shoot will be ok Patriot. An Optical zoom is a key ingredient. Using a photo editor can be almost as much help as the camera itself. I'd be happy to answer any questions on any of it, although I'm not a professional photographer, I've picked up a few things along the way
  24. The Following User Says Thank You to Bear for This Post:
  25. #14
    United States
    177
    Try to up the exposure a bit on your camera (if you can). I'm sure that'll help a good bit.
  26. The Following User Says Thank You to emeeks for This Post:
  27. #15
    spinroch's Avatar
    675
    1,981
    I humbly rest on my laurels
  28. The Following 3 Users say Thank You for This Post by spinroch:
  29. #16
    Patriot76's Avatar
    Buffalo Commons
    2,955
    10,578
    Quote Originally Posted by spinroch View Post
    Your laurels equate to insight in my book. Good choice for an avatar. The best I could do is a smashed beer can.
  30. The Following User Says Thank You to Patriot76 for This Post:
  31. #17
    6,126
    11,842
    Hope he remember's his buddy in the purple bag, if he's ever near my sandbar.
    An stop taking photos after drinking Patriot! It' does make them less blurry.
    Sirscrapalot - Has a collection of Crown bags.
  32. The Following User Says Thank You to Sirscrapalot for This Post:
  33. #18
    Patriot76's Avatar
    Buffalo Commons
    2,955
    10,578
    Guilty as charged. The camera is going in for intervention treatment on Monday. Thanks for the heads up. And as far as the purple bags, we use them to store our fishing reels in. It is embarrassing to say my purple bags cannot keep up with my fishing reels. I think I will drink to that.
  34. The Following 3 Users say Thank You for This Post by Patriot76:
  35. #19
    6,126
    11,842
    I'll have one for you also sir.
    Sure Spin is just proud of himself now. He better have two for each of us.
    Sirscrapalot - Can't corrupt those that are already corrupted. - Unknown, but the frowny face is mine.
  36. The Following 2 Users say Thank You for This Post by Sirscrapalot:
  37. #20
    Patriot76's Avatar
    Buffalo Commons
    2,955
    10,578
    Just an update. We have miles and miles of brass pipe and copper wire. We have already removed two transformer stations with three transformers each. Ferrous metal removed equals about 55 tons.
  38. The Following 8 Users say Thank You for This Post by Patriot76:
  39. Similar threads on the Scrap Metal Forum
    1. A Scrapper's Dream
      By Patriot76 in forum A Day in the Life of a Scrapper
      Last Post: 08-04-2015, 03:33 AM
    2. Bartering turns $20 of ferrous into $130 worth of non-ferrous
      By Mick in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 03-23-2014, 02:09 PM
