Results 1 to 19 of 19
Hard Drive Breakdown
    emeeks started this thread.
    United States
    177
    Ok, so! I'm sure this has been asked 100 times and I did search around but I didn't find exactly what I was looking for. Here's what I did.
    I tore down 20 hard drives and came up with these results:
    1. HDD Covers - 4.4LBS (Steel, I think?)
    2. Magnets - 2.12LBS
    3. HDD Boards - 1.3LBS
    4. Aluminum Rings(washers to get to the platters) / HDD Motors - 1LB
    5. HDD Actuator Arms - 12OZ
    6. Misc Connectors (they connect to the actuator arms) 2.4OZ
    7. Platters - 2LBS
    8. HDD Aluminum Casing - 10LBS
    All in all, after a ton of research here and on eBay I totaled around $68.50.
    I'm just looking for clarification in terms of pricing, what goes for what, and if I'm breaking them down properly. Any advice would be greatly appreciated!
  2. The Following 3 Users say Thank You for This Post by emeeks:
    The covers are rarely steel (occasionally a steel insert glued on) mostly SS with some alum. ones thrown in. Once in a great while an alum. one with a SS insert glued on. Don't seem to be any rhyme or reason for it.
  4. The Following User Says Thank You to Mechanic688 for This Post:
    6,126
    11,842
    Older HD boards will weigh more then the newer ones if I recall properly from the last batch I ran. Bigger boards vs the smaller ones, hence more weight.
    Buyer here on the forums for the spacers, but you might be able to get rid of them locally if you have any artist/crafter types you network with. Same with platters. I know you know all this but still.
    Edit : I agree with Mech, usually Stainless for my covers, now an then I'll get an alum one. Silly buggers.
    Nice break down!
    Sirscrapalot - Great moments in science: Einstein discovers that time is actually money. - Gary Larson
    directrecycle's Avatar
    521
    94
    I have ran into an occasional few with brass covers. if I remember correctly they were ibm
  7. The Following 2 Users say Thank You for This Post by directrecycle:
    6,810
    How do you separate the stacks of platters? I tore some down awhile back but never got around to the platter stacks
    Usually pull the T3-T4 screws and wha-la
  10. The Following 3 Users say Thank You for This Post by Mechanic688:
    6,810
    I never saw any torx tips in them
    3,404
    I've been tearing down several hundred this past few months and found platters are held on in several ways. Some are Torx screws. Some are tabs and some seem to be simply pressed on.
  13. The Following 2 Users say Thank You for This Post by Mick:
    Gravitar's Avatar
    Central Texas
    1,086
    1,258
    I would like to mention that a lot of times, the screws inside the drive are stainless steel. They don't weigh much, but it's better then tossing them in the steel pile.
  15. The Following 4 Users say Thank You for This Post by Gravitar:
    United States
    177
    I wish there was a universal bit I could use. I change the bit at least 3 times on some hard drives and it gets aggravating when you're trying to get the most $ per hour.
    There probably is, but I haven't looked yet.
    6,810
    I generally use multiple bit holders, much quicker and easier to swap out than changing the tips, when many times it takes a pair of pliers to pull them out, just drop the holder out and grab another one
    United States
    177
    Ah, good idea. That's kind of a no-brainer.
    brandon's Avatar
    North Carolina
    787
    When I'm doing a lot of HDs I try to group all like ones together. Take all the boards off first, then the covers, then the insides. still have to change the bits but you get more done in less amount of time.
    I did over 700 for one customer, and found out real quick to group them together into like hds.
    My fortune cookie said:
  20. The Following 3 Users say Thank You for This Post by brandon:
  21. #14
    6,810
    likewise Brandon, if you lay them out in rows and do it in steps it greatly reduces time spent swapping tools
  22. The Following User Says Thank You to Bear for This Post:
  23. #15
    6,126
    11,842
    I do the same as Brandon, and Bear. I have two holders for the bits, cause I hate changing the things out, an when I try I end up spending 15 minutes looking for the bit, cause I drop it. lol.
    I also do all of one kind first, remove top, discs, etc.
    Sirscrapalot - EIEIEIEIEEEEEEEEEEEEEEEEE - Me when the cooler goes empty.
  24. #16
    The ones that look like their pressed on I usually turn them over and lean them up against the edge of another and give the motor shaft a good whack and it'll pop right out. Then just take your screwdriver and pry out the copper windings.
  25. The Following 2 Users say Thank You for This Post by Mechanic688:
  26. #17
    2,863
    349
    The best way to get the most $ per hr is to sell the hard drive whole.
  27. #18
    3,703
    3,699
    There are buyers for each of those items even the alu rings and attachment plates that hold the disks. On a stubborn disk i lay it over the round heavy iron piece from a motor that held the armature and one whack with a hammer works like a charm.
    for scrapping It equipment , a masons hammer is the tool.
  28. #19
    Amnelson is offline Metal Recycling Entrepreneur
    Northeast MN
    52
    22
    Quote Originally Posted by emeeks View Post
    7. Platters - 2LBS
    If you got a good enough relationship with your local yard you may be able to sell them as a higher grade aluminum breakage or as aluminum. Sans boards of course
    1. Hard drive breakdown
      By Pnutfarmer in forum General Electronics Recycling
      Last Post: 11-15-2014, 10:48 PM
    2. Worlds most Expensive Hard Drive Breakdown Video
      By Gravitar in forum General Electronics Recycling
      Last Post: 07-06-2013, 07:17 PM
    3. Hard Drive Breakdown
      By adamperak in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 03-20-2013, 04:20 AM
    4. Hard Drive Breakdown Numbers
      By Geiser093 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 02-04-2013, 12:10 AM
    5. another hard drive breakdown question
      By ozzy214 in forum General Electronics Recycling
      Last Post: 10-18-2012, 06:00 PM
