Results 1 to 11 of 11
    NewEarthRecycling started this thread.
    NewEarthRecycling's Avatar
    Oct 2013
    Appleton, WI
    Commercial copiers... worth the breakdown??
    I have 8 commercial copiers to pickup this week. Is it worth it to break them down for the boards? Or should I just pass them on?
    4barrel's Avatar
    Nevada, Iowa
    119
    138
    I usually will pull any easy to access boards, and then pass the rest on to a company that takes my CRT monitors etc. One thing to check if you tell your customers that you protect their data is make sure and pull any hard drives if the copiers have them - they could contain images that have been scanned and address books that should be wiped/destroyed.
    NHscrapman's Avatar
    new hampshire
    1,582
    4,076
  4. The Following User Says Thank You to NHscrapman for This Post:
    Aug 2014
    16
    10
    The best part about copiers are the stepper motors inside of there. I personally think that those sold on ebay or to the robot crowd could do very well for you depending on the motor in there. The copiers use much better stepper motors than laser printers. I know that is a place where people are told to look is old copiers and laser printers for stepper motors to use in their projects. I just don't know which ones are better than others.
  6. The Following User Says Thank You to WannaBeGeekster for This Post:
    4,758
    6,037
    Heavy you don't want to move them 4 times (pick up, remove for break down, re load, add to the steel pile at the scrap yard). Load them so you can break down in your truck bed or trailer. And they have good boards and memory as well.
    webuyselltradestuff's Avatar
    May 2013
    Watkinsville, GA
    950
    131
    easy to get to boards and memory...rest is shred...not worth the IMMENSE effort to get it broken down
  9. The Following User Says Thank You to webuyselltradestuff for This Post:
    2,864
    350
    I agree with hobo. I picked up three one day, loaded them up and took straight to the scrap yard. Made 130.00 in about 1.5 hrs. Make sure your yard will take them first.
    wadarbr549's Avatar
    May 2013
    southern ohio
    412
    175
    i usually do good selling the formatter boards on ebay,,,some are no good of course...any of the cards on the back that say jet direct are also worth looking up...most of the time all the good stuff is in one area...like a metal box..break some plastic and pull a few screws and it usually slides out....i just got a formatter board, with a hard drive,ram and fax card out of a large hp that is going for 200 pluss on ebay...
    i just listed mine tonite wish me luck
    snapperhead's Avatar
    Auckland, NZ
    64
    37
    They are chock full of things needed and wanted by hackers, gadget modifiers and tinkerers. Precision shafts with matched bearings, toothed belt drives and pulleys, stepper motors as mentioned, optical lenses and mirrors, solenoids, and linear drives in some. Anyone wanting to build their own small format CNC device would be into these parts and components.
    With a little experience they can be stripped down in a couple of hours. Just my biased opinion as an amateur hacker, but the guts of copiers are worth more than the scrap value you get after stripping.
    One downside of completely stripping them is the plastics, you get a big stack, not heavy, more bulky.
    If it wasn't for the laws of physics, I would be unstoppable.
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,826
    2,917
    Since my yard will take them as shred, I remove the side cover and pull any hard drives, memory and circuit boards. I scrapped 5 this morning and it took maybe 30 minutes. Got some nice boards and memory and about 200 pounds of shred.
    armygreywolf's Avatar
    Germantown, WI
    1,084
    193
    I always pull boards and toner...those alone are usually 10-20 bucks per machine, the rest with a weight of about 220-280 lbs ends up as shred...another 20 bucks or so. If I bid on these things no matter where they are I will bid on at least 4 at a time or the gas and handling isn't worth it. You can take the time to look up the machines with servicable parts on ebay...like has already been suggested reuse is always the first priority. I got a hold of a Konica Minolta for 21 bucks and sold it after two hours of cleaning an internal toner spill with a vacuum and an air gun for 300. It still left a dot on every four or five pages about the size of a pinhead but the buyer could've cared less.
    My rules for laser printers and copiers:
    Does the machine print at all? IF it does, skip the diag...
    Pull the error codes. Hop on the internet to look for the common issues and fixes (low to no cost). Such as baking formatter boards and so on. Some of the cheaper machines simply get thrown out when it runs out of a 200 dollar toner cartridge after a few months...which leads me to ask:
    Age of machine: If it is pre:Windows 2000 throw it out even if it works...that goes for workgroup printers and copiers too, they use more consumables than newer printers and businesses know this.
    If it is out of toner after fixing it, you can still use it, I have a kit that refills toner. It's a simple process that isn't messy if done right. A hot iron pokes a hole in the reservoir and the waste section, both are sucked out with a small vac extension (I use a shop vac with a hepa filter that is just for this) and refill them all with bulk toner I get on ebay. Never fails to work, sometimes it requires a small chip to be swapped sometimes not...depends on brand.
    Never scrap just to scrap. Copiers on craigslist that work and have toner go for 200 bucks all day long, in my area when I post one that I just serviced it's often gone in a few hours. Don't forget to add "You must provide the manpower and method of transport". I do hope this helps. I'm sitting on some cadidates myself that I haven't been able to clear the mess around them to service yet. Caveat...you can generally print or display the service page that tells you total pages and interval since last service often with a percentage remaining on things like toner, the drum and so on. If any of this stuff is in obvious need of replacing BESIDES toner, such as the drum, scrap the machine.
  15. The Following 5 Users say Thank You for This Post by armygreywolf:
    1. Question on copiers
      By Swampy in forum General Electronics Recycling
      Last Post: 03-13-2014, 09:39 AM
    2. Commercial Copiers/Scanners/Fax Machines - Board Quality?
      By Racer997 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 02-08-2013, 11:40 AM
    3. Hi everyone....breaking down COPIERS
      By Scroungaholic in forum Introduce yourself
      Last Post: 11-25-2012, 09:17 AM
    4. Floor copiers!
      By hallthomas89 in forum Scrap Metal Tips and Advice
      Last Post: 03-19-2012, 09:36 PM
    5. cbm breakdown. worth it?
      By Russell in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 02-27-2012, 09:08 AM
