hey guys can anyone tell me or point me in the right direction in how i could identify extruded aluminum and sheet aluminum? For example, crutches, bigger umbrellas, heater cores, window screens, etc? thanks.
Think of extruded as Play Do being pushed through a form, then sliced.
Sometimes it is machined further after the extrusion. These marks should be visible.
Everything you listed is sheet. Some heavy duty screens might have extruded. Older windows should be framed in extruded.
If you can break it with a hammer, Its cast.
Check out the similar threads down below, there might be further answers there.
Parker,
I would disagree with you. Most of the crutches that I get are extrusions (if cleaned properly). Large umbrellas (yard type), the pole is usually extrusions (have to clean) and the upper parts can also be. Window screens can go either way. Glass windows are almost always extrusions.
Danimal,
You need to keep in mind that for extrusions to go as extrusions, they can have no screws, no putty, no weather stripping, etc.. On the window screens and glass windows, most times there is some cast aluminum holding the 4 pieces together and maybe 2 pieces of cast to remove the screen or glass. The cast parts need to be removed.
The other thing that you need to remember is if the yard can find a reason to buy something at a lower price, they make more money when they upgrade it. Meaning you bring in something that should go as extrusions, but you didn't clean it properly, they will buy it as sheet or worse yet, maybe dirty aluminum. They then spend a few minutes doing what you should have done and then they sell it as extrusions. Your loss, their gain.
Some aluminum tubing is welded, some is rolled sheet and crimped, and some is extruded. Crimped is obvious....example: old style tv and radio antennas. Welded tubing is usually a lot less obvious. Ever look at those old style aluminum patio chairs? There's no sign of welds, but all the ends of the tubes are capped and welded. Pretty safe bet that the tubing is too. Extruded aluminum tubing usually has tiny, hair thin lines, running the length of the tubing. You have to look extremely close to notice this.
all sheet by me as well. Extruded can be window frames, some heavy alum patio chairs and such.
Heat sinks are extruded no matter what your yard tries to tell you. they are 6061 I believe, the heavy ones are aqlu/cu
I've never known crutches to be anything other than old sheet. If its cleaned it *may* go as what I know as ''clip.''
Umbrellas are bought as old sheet and then we upgrade them to painted extrusion or #3 extrusion
Scrapper, Scrap Yard Worker, Horse farm worker, Cooler Puller and just plain ''tired''![]()
many aluminum heat sinks are extruded, for sure not all. Buying at my scale I have seen more than a few heat sinks that are aluminum plate with fins in them like this:
Progressive Stamped Heat Sink Project Highlights
I have also seen a lot of small heat sinks that are injection molded or cast.
Product Description This Aluminum Heat Sink Fin Assembly was
developed for a Projection Television applicationCapabilities Applied/Processes
Development
- Develop a Cost Effective Heat Sink for
Maximum Heat Dissipation
Stamping
Custom Mechanical AssemblyEquipment Used to Manufacture Part
Minster
- 150 Ton
Brown Boggs
- 200 Ton
Tooling
- Progressive Dies
- 8 Stations for Base Plates
- 10 Stations for Fins
Overall Part Dimensions
Base Plate:
Material Thickness: .065"
Length: 6.5"
Width: 3.5"
Height: 1.0"
Unfolded Fin
Length: 18"Folded Fin:
Material Thickness: .020"
Length: 5.75"
Width: 3.25"
Height: 1.50"Tightest Tolerances Base Plate: ±.005"
Folded Fin: ±.00075"Material Used Aluminum Estimated Part Weight .35 lbs Features/Benefits Custom Staking Method of Incompatible Material Thicknesses
- Eliminates Glue Seal & More Expensive Techniques
In Process Testing/Inspection Performed
In-Process Real-time SPC of Critical Dimensions
CMM Measurement
Strength Testing on Stakes
Cleanliness Sediment Testing
Dimensional Results Reporting
Control Plan
Process Flow DiagramFailure Mode and Effects Analysis (FMEA)
Gage Repeatability
Reproducibility Variable Data Report
Raw Material Chemical Composition Results
MSDS - Material Safety & Data Report/Substances
and MaterialsIndustry for Use Consumer Electronics Volume 600,000 Pieces Packaging Special Pack Thermal-Formed Packing Trays
- Anti-Static
Lead Time Tooling: 14 Weeks
Production Parts: 6 WeeksDelivery Location Tenessee
MexicoStandards Met Customer supplied print, 2D CAD Drawing Product Name Heat Sink Fin Assembly
^^My big yard I sell to buys those as old sheet but if I clean them they become extrusion and the fin part goes in old sheet.
I think this thread just shows everyone how different things are from one yard to the next and how important it is to now how each of your yards classify items and what they pay for them in order to maximize profits.
I have 3 yards that get 99% of my material. One large multi location yard only has clean and dirty aluminum (and aluminum rims). My main yard closest to my house has many categories, but not Mixed Low Copper Clip, otherwise know as MLC or Clip. They do have a Solids category that may be the same a MLC. Another yard about 40 minutes away has numerous categories. I'm not up there enough to have a full understanding of how they grade every category. I have sold computer heat sinks there and most times gotten extrusions. I did get MLC once for them.
As New has indicated, yards will purchase as one category and upgrade to another, as her umbrella explanation shows. My advice to everyone is to ask alot of questions at your yards. Learn the way they grade and what you need to do to upgrade these items yourself.
Extrusion is defined as the following.
The process of generating a surface by translating a plane curve parallel to some line is called extrusion, and surfaces that are generated by extrusion are called cylindrical surfaces . A familiar example of the surface of a right circular cylinder which can be generated by translating a circle parallel to the axis of the cylinder. The following theorem provides basic information about graphing equations in two variables in 3-space.
Theorem: An equation that contains only two of the variables x, y, and z, represent a cylindrical surface in an xyz coordinate system. The surface can be obtained by graphing the equation in the coordinate plane of two variables that appear in the equation and then translating that graph parallel to the axis of the missing variable.
I hope this clears things up.
I only get to answer someone like this about every 5 years, so I could not resist
the yards by me take heatsinks as old hard sheet- i know im being ripped off bcos they're def extrusion.
i dont know whats their reason for this.
i wont be surprised of they sell them as extrusion after buying it from us.
If you cannot see the seam inside the tube where it is mended together, it should be considered extrusion. Sometimes you cannot see the mill lines on the outside of aluminum which identifies extrusion without the aid of a magnifying glass. If you share this with the yard they should appreciate your knowledge and might be acceptable to other questionable metal. It really helps when you have a sample of each to demonstrate your keen eye. At least they will be less likely to play games with you.
