So I got my 2wd, 2.5l, manual yr2000 ford ranger at 120,000 from my uncle 5 years ago and rode it and rode it and rode it, at 192,000miles its still going... weak. i used to hit 75mph just fine but now on just an incline, i struggle to get 60.
I still want a small economy truck as my loads usually come in under 1/2ton and most my miles are freeway miles with usually less than 200lbs of stuff in the cab/bed. so yeah, maybe you guys could help me find something.
-Im thinking an older simpler truck would be swell as well that way i could learn to work on it, I have two good buddies who know toyotas inside and out and i hear those are the easiest to work on... I also like the box-ier, retro look of older trucks too
-manual is a must, and id like to be getting at least 25mpg on the freeway (i accelerate and drive slowly, id like to think im light on my engine)
-ideally, id like a little more power than what the 2.5l has to offer, although i still would like to run a 4cyl engine for the fuel savings.
-something I could put a tow hitch on for a little 1/2 to 1ton trailer?.
-I live in the city so a short truck is great although if the bed of my truck got any smaller (4x6.5ft), i feel like thatd be a problem
-also lower is better
-I realllly reallly want a bench seat cuase my girl doesnt like to ride on the raised middle seat cuase it makes her taller than me
currently my truck needs
-new ball joints, front and rear suspension,(any idea how much that will run me for parts and labor?)
replacement of two tires
-my check engine light just turned on for an 02 sensor
-the throttle starts randomly guzzling down gas when my foot is off the pedal since i first got the truck 70k miles ago
and well the engine is weak as hell. if i slam down on the gas my engine starts knocking, its been doing this since about 150k miles but has been slowly getting worse and worse, ill be in 3rd gear on the freeway just cuase my engine cant handle a regular old hill (mass airflow sensor is all wonked out)
-drivers seat blew a spring and sits crooked
-and it needs a full inspection cuase im sure theres a bunch more things wrong with it
Im thinking this may be the ideal time to sell it and get something new!
