Results 1 to 20 of 24
Just a stubborn old goat
    Abuilder is offline Metal Recycling Entrepreneur
    Abuilder started this thread.
    Abuilder's Avatar
    SE Wisconsin
    436
    226
    Ha You thought I was talking about you.
    Well, not this time. LOL
    I have this thing about stripping wire no matter what if it’s heavy enough. Well this time I got a little POed because the insulation was real tough PVC and even a new utility blade wouldn’t touch it.
    Now here is the stubborn old goat part.
    This wire was aluminum elec. Service lines. Not worth the time to strip but this stuff ticked me off . I am not one to be defeated by some ……of scrap.
    So I got serious with it.
    I made a makeshift table.
    Stretched the wire out thinking of a chicken neck,
    Gave it a good wack but went a little to deep.
    Now is this a little overkill for stripping wire or what.
    That’s a 3” dual carbide spiral blade.
  2. The Following 12 Users say Thank You for This Post by Abuilder:
    Paljas's Avatar
    Jul 2014
    Overkill forsure...............efective? Hell yeah!!
  4. The Following 2 Users say Thank You for This Post by Paljas:
    DakotaRog is offline Metal Recycling Entrepreneur
    DakotaRog's Avatar
    Aug 2014
    1,611
    602
    Stubborn can be good (in certain cases)!!! What's the main story (myth?) about Thomas Edison, that it took him a 1,000 tries at the light bulb??
    If you can find an effective and fairly quick way to take off the heavy insulation and remove the steel wire core of ACSR (I think its either 5 or 6 Al strands around the single steel one?), it might be worth it. My non-ferrous guy is giving 56 cents for clean Al wire compared to a quarter a pound for ACSR
    Then again the heavy insulation is about what, 40% of the weight?? If so 100 lbs. of straight ACSR would get ya $25 and 60 pounds of clean wire would yield $33.60. So the exact percentage of the insulation probably becomes fairly significant (and how fast the steel core strand can be removed). Good luck on whatever you do!!
  6. The Following 2 Users say Thank You for This Post by DakotaRog:
    Abuilder's Avatar
    SE Wisconsin
    436
    226
    Quote Originally Posted by DakotaRog View Post
    Dakota
    This wire didn’t have the center steel wire. It was 7 stands of 12 gauge Al only.
    Printed on the insulation: (ALCAN B 2 AWG AL XLPE 600V
    I only stripped about 35 feet to see if my planer would strip that nasty PVC. It worked OK but if I every use it again for stripping heavy insulation it will be for COPPER wire on a longer 2x10x12 board at least.
    From the 35’ of Al wire I stripped I ended up with 2.5 pounds at .55 for clean EC Aluminum.
    The rest of the wire is going in as Insulated!!!!!!
    Copper Head is offline Metal Recycling Entrepreneur
    Copper Head's Avatar
    Up North
    1,883
    579
    Still as much as I've reduced coated wire to just CU or AL , The planer is an excellent idea , little depth gage adjustment and it's the best idea yet , heck you know how many doors I planed in my life & your idea never occurred to me .
    Abuilder Fine Idea , hats off to you . I don't think it's over kill at all . Heck a low cost Harbor freight Planer will do fine .
    the only draw back is keeping mess down as wood chips are biodegradable and casing chips are not .
    As to steel core - once stripped cut at lengths of 2 or 3 foot then it's easy enough to untwist
    I guess you could cut them at 2 or 3 foot first then watch your hands careful as you use planer on the workable sizes
  9. The Following User Says Thank You to Copper Head for This Post:
    Abuilder's Avatar
    SE Wisconsin
    436
    226
    CH
    I called it overkill because of the size & weight of my planer. My planer is a Rockwell 653 versa planer, the Cadillac of door planers in it’s day. A smaller planer would have been a lot easier to handle that’s for sure. But without the horsepower and carbide blade I think a HF planer would self destruct if the blade got bound up in the wire.
  11. The Following User Says Thank You to Abuilder for This Post:
  12. #7
    travistemple202020's Avatar
    ames iowa
    1,326
    266
    ya once I got tired of doing it by hand for most of my life I bought a electric stripper a few years ago now and it paid for itself in just a month or so and it eats it faster than I can supply it lol
  13. The Following User Says Thank You to travistemple202020 for This Post:
  14. #8
    musicman57's Avatar
    OKLA
    62
    95
    ACSR is not usually insulated. It is the bare overhead primary wire. The triplex, etc. secondary or service wire does not need the steel reinforcement wire as the spans involved are generally shorter than primary. (I purchase for an electric cooperative.)
  15. The Following 3 Users say Thank You for This Post by musicman57:
  16. #9
    6,126
    11,842
    couldn't resist...title of a thead like this deserves a goat.
    Sirscrapalot - You gonna eat that? - A goat.
  17. The Following User Says Thank You to Sirscrapalot for This Post:
  18. #10
    Abuilder's Avatar
    SE Wisconsin
    436
    226
    Oh Ya
    You think so
    “The basic difference between an ordinary man and a warrior is that a warrior takes everything as a challenge while an ordinary man takes everything as a blessing or a curse.”
    ― Carlos Castaneda
  19. The Following User Says Thank You to Abuilder for This Post:
  20. #11
    6,126
    11,842
    Sirscrapalot - I got your goat.
  21. The Following 2 Users say Thank You for This Post by Sirscrapalot:
  22. #12
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,804
    2,902
    I had some wire similar to that but was finally able to remove the insulation with a knife but it was still hard to do.
  23. The Following 2 Users say Thank You for This Post by jimicrk:
  24. #13
    Abuilder's Avatar
    SE Wisconsin
    436
    226
    SO
    Besides crossbreeding goats with gawd knows what?????
    What other strange things do you do on that sand bar of yours?????
  25. The Following User Says Thank You to Abuilder for This Post:
  26. #14
    6,126
    11,842
    Fill an then empty my cooler of beverages.
    Sirscrapalot - Keeper of the traveling cooler.
  27. The Following User Says Thank You to Sirscrapalot for This Post:
  28. #15
    Metalbestos's Avatar
    Mar 2014
    Baltimore md.
    985
    3,094
    ninja Goat
  29. The Following 2 Users say Thank You for This Post by Metalbestos:
  30. #16
    6,126
    11,842
    LOL
    I knew you wouldn't be far along.
    Sirscrapalot - You would have seen this derailment coming but I used my Pirate ninja stealth skills.
  31. The Following 2 Users say Thank You for This Post by Sirscrapalot:
  32. #17
    Abuilder's Avatar
    SE Wisconsin
    436
    226
    HEY this is way out of order.
  33. The Following 2 Users say Thank You for This Post by Abuilder:
  34. #18
    Abuilder's Avatar
    SE Wisconsin
    436
    226
    Why does the old Vbulletin Admin in me keep telling me that some of this thread is going POOF. LOL
  35. #19
    6,126
    11,842
    Who knew goats could be so **** funny.
    Sirscrapalot - Love is not love, without a violin playing goat. - Julia Roberts
  36. The Following 2 Users say Thank You for This Post by Sirscrapalot:
  37. #20
    Mar 2014
    Baltimore md.
    985
    3,094
    LOL
  38. The Following 2 Users say Thank You for This Post by Metalbestos:
