Results 1 to 20 of 20
    ScrapStrong started this thread.
    ScrapStrong's Avatar
    May 2014
    21
    18
    All scrappers should have a tool bucket!
    My tool bucket is by far the most handy piece of equipment I've got! (I should have taken a pic for this thread)
    It's WAY better than a tool belt for a scrapper for a couple reasons.
    I use a pouch similar to this one on Amazon
    Amazon.com: Custom Leathercraft 1119 Bucket Caddy Organizer, 48 Pocket: Home Improvement
    Besides your power tools like your drills and saws etc, go right in the tool bucket. I'm assuming you always have a dolly with you to do removals with? Well, since the tool bucket can be much heavier than a tool belt or a toolbox, use the dolly to lug it around with you on the job.
    Almost everything I could possibly need is in this tool bucket... So no matter if I'm taking apart something simple or something complex I can almost guarantee the tool is there...
    Here's a list of everything I can think of right now that's in the bucket, and easily accessible because it's organized via pouches/compartments:
    • Channel locks
    • Open wrenches
    • Adjustable wrenches
    • Screwdrivers (large and small - flat-head and phillips)
    • Hammers (one regular size and one 5 lb)
    • PB Blaster for stubborn nuts and bolts
    • Pliers
    • Markers just in case
    • Tape measure
    • Utility knives and blades
    • Breaker bar
    • Voltage meter
    • Vice grips
    • Safety glasses
    • Tin snips
    • Allen wrenches
    I'm sure there's more.... But you get the idea. All the hand tools you'll ever need neatly organized and compact!
    What's in YOUR tool bucket? (or tool box if you don't have a bucket yet...)
  2. The Following 6 Users say Thank You for This Post by ScrapStrong:
    3,436
    File, 64 pc bit set for drill, charger and extra battery,gloves and dust masks.
  4. The Following 3 Users say Thank You for This Post by BRASSCATCHER:
    3,436
    Magnet.
  6. The Following 4 Users say Thank You for This Post by BRASSCATCHER:
    ChildhoodDream's Avatar
    Mar 2015
    Minnesota
    569
    1,644
    I use pails for many things and hauling tools and such around in them is one of the uses.
    I have many different "tool assortments" for doing different types of jobs. Electrical, plumbing, phone and cable and many other hobby tool selections.
    I also like the padded swivel tops that you can get that fit a pail. I like using those on the 3 gallon size pails as it makes a nice portable seat that is at a comfortable height.
    I also made a few tool bucket setups much like the tool pail in the pictures above. What I used was the heavy black nylon pocket things that were made for putting in a pick up truck behind the seat or across the bottom of the front of the seat for putting small things in. They sort of look like a BIG money belt that people would tie around their waist under their shirts and such.
    I ended up with a bunch of them new from a discount clearance place that was called "Worlds Greatest Deals". They have many pockets of different sizes and have pieces with Velcro material that can be used to keep things in place. I didn't pay much for them and I have used and still use the ones I have left that I made into tool pails and other things where nice pockets in a row are perfect.
    I did encounter a BIG problem with using a 6 gallon pail for my tools and parts while doing some electrical and simple plumbing installing watering units for sheep.
    When I would go through the areas where there were sheep they would come running wanting what was in the pail as they thought FOOD whenever they would see a pail or bucket.
  8. The Following User Says Thank You to ChildhoodDream for This Post:
    6,123
    11,885
    That's what I'm doing wrong.
    I need to use tools!
    Doh!
    Sirscrapalot - Has a tool box, and a really big tool box.
  10. The Following 4 Users say Thank You for This Post by Sirscrapalot:
  11. #6
    auctionscrap's Avatar
    Mar 2015
    near Dallas
    11
    Silver acid guys too
  12. #7
    Russell's Avatar
    Chicago,Il
    815
    495
    I'd like to add in ppe. (personal protective equipment. I cut my hand terribly at the scrap yard years back and had nothing to stop the bleeding.
    Safety glasses.
    Gloves.
    Pepper spray-stashed in truck doors and truck toolbox having one on your belt is optional... I realize most of you don't have to travel through war zones, but.
    I won't get into carry n conceal- but to each their own.
    Gauze, roll of paper towels and tape for emergencies, maxi pads will take the place of gauze as well. Reg ol band aids and antiseptic.
    Flashlights, extra batteries, safety vests, hard hats, steel toe boots/shoes.
    Booty covers, rubber gloves and n95 or n100 masks.
    Fix a flat, variety of tape and fuses.
    Boy, You might need an extra supply truck following behind if I keep going.
  13. The Following 3 Users say Thank You for This Post by Russell:
  14. #8
    travistemple202020's Avatar
    ames iowa
    1,326
    267
    I use a canvas backpack cause it holds everything can carry it easy and also can wash it easy. it sits on the floor on the passenger side of the truck and I have a file cabinet drawer as a middle console I use and that has all my quick grab tools for curbo like screw drivers allan wrenches wire cutters and such
  15. The Following 2 Users say Thank You for This Post by travistemple202020:
  16. #9
    AdmiralAluminum's Avatar
    Jan 2014
    Ontario
    737
    824
    Quote Originally Posted by Russell View Post
    Safety glasses.
    Gloves.
    Why not just have a first aid kit? I've been meaning to add that to the necessary tools thread or start a new one. I'm the Health/Safety guy at work and I'm first aid trained. Especially with what we do and where we do it, I can't tell you how important it is to have just the basics on hand at least until the pros arrive. Do you want to be staunching a wound with that rag you have cleaned dirt/grease/oil up with?
    METAL IS MY MISTRESS...PLEASE DON'T TELL MY WIFE!
  17. The Following User Says Thank You to AdmiralAluminum for This Post:
  18. #10
    Kalvlin's Avatar
    CT
    319
    598
    Thanks for the good list guys. Now I just need to use the tools as intended- I tend to be a bit of a "Primitive Pete" sometimes.
    Does anyone remember those films from shop class in the 70s with Primitive Pete showing the wrong way to use tools ? Those were so funny....
  19. The Following User Says Thank You to Kalvlin for This Post:
  20. #11
    Metalbestos's Avatar
    Mar 2014
    Baltimore md.
    987
    3,114
    I keep ratchet straps , bungee cords and a pair of gloves in mine . The seat is nice . It's firm yet soft.
    This my go too.
    I prefer this one because it has this Velcro pouch which is a excellent place to store your wallet , phone or other pocketed items you don't want laying around . Here is a pic of the pouch with a pair of channel locks to show how big the storage is .
    Most used
  21. The Following 4 Users say Thank You for This Post by Metalbestos:
  22. #12
    bluemeate's Avatar
    489
    16
    i scored one of those bucket caddys at an estate sale for a dollar!
    i throw small non-ferrous bits in there while im working and then sort it out every 10-20 loads or so
    im also pretty sure ive had a number of my tools fall out unnoticed
    collecting san joses scrap
  23. #13
    Kalvlin's Avatar
    CT
    319
    598
    That Kobalt set is sweet. Looks like I need to go shopping !
  24. The Following User Says Thank You to Kalvlin for This Post:
  25. #14
    ScrapGuru's Avatar
    Mar 2015
    21
    I agree those buckets are great for keeping all of the tools organized.
  26. #15
    My tool bucket is a post office mail basket - the white ones mail carriers use to hold their mail.
    I have many tool boxes here and at dads but this box holds a few basic, most used tools that can be picked up and carried where I need it or put in the truck. It has gloves, rags, a small sledge, a large flat screw driver, a drill and a plastic case that holds drill bits and sockets and a small pair of vise grips. Those are my most often used tools but if I need to add anything else for a job I know what to grab and toss in.
    Those baskets are tough, I've had mine for 7 years now and its still going strong!
  27. #16
    This old canister from a shop vac is on wheels and the bucket of hand tools comes out if needed somewhere besides the shop.
  28. The Following 4 Users say Thank You for This Post by KzScrapper:
  29. #17
    charn's Avatar
    Anywhere But Here
    250
    My curbco bike toolkit is a multitool. At home, I use a backpack to leave my hands free for carrying scrap. Pliers, needlenose pliers, wirecutter, 3 screwdrivers, socket/bit set, ratchet, adjustable wrench, and hammer are enough for most outdoor jobs before I bring the bits in.
  30. #18
    Libertytow's Avatar
    Silverton NJ
    562
    64
    I second the backpack
    Liberty Towing & Recycling
    (732)279-8599
    Cleaning up NJ 1 LB at a time!
    Certified Mobile Scales
    Fully Insured Carrier usdot # 1802487
    WWW.LibertyTowing.Webs.Com
    WWW.TRRecycles.Webs.com
  31. #19
    scrapdaddyj's Avatar
    Aug 2014
    Meridian, ID
    53
    As an appliance tech just getting into scrapping i've found my self using my tool bag in not so pleasant conditions.
    dragging my nice tool bag through the dirt is not my ideal way to use it. I haven't thought of using the bucket bag. Thankyou
  32. The Following User Says Thank You to scrapdaddyj for This Post:
  33. #20
    Jan 2014
    Ontario
    737
    824
    I have found a Husky brand open faced tool box and tool bucket on separate occasions at curbco. They never leave my van and have drill, hammer, screwdrivers, bits, chisel, and some other necessities in them. It's funny, the tools that hold my tools are my favourite tools.
    Wish I thought of this while I was still changing diapers!
    1. Bucket List
      By MattInTheHat in forum A Day in the Life of a Scrapper
      Last Post: 03-30-2023, 06:41 AM
    2. Bucket of aluminium cans mixed in with used oil filters1
      By hobo finds in forum Off Topic Discussions
      Last Post: 12-16-2014, 11:56 PM
    3. SMASH bucket!
      By ParkerFlyer4 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 03-01-2014, 12:01 AM
    4. Day 7 of the I don't know bucket.
      By NatBrnCO in forum A Day in the Life of a Scrapper
      Last Post: 10-09-2013, 04:47 PM
    5. Harddrives breakdown.. parts bucket.
      By pcscrapper in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 07-15-2013, 05:05 AM
