Results 1 to 12 of 12
First day scrapping! Howd I do?
    Cwatson325 started this thread.
    19
    So ive been planning on getting into scrap metal for a week or two now and came across this website. After reading a lot and soaking up a lot of info from this website I finally baught a truck last night and got my first truck load of metal. Was hoping you guys could let me know how I did and maybe whats worth what?
    What I got:
    Washer
    Dryer
    Bed frame
    4 or 5 bikes frames with a few bike rims
    A sink, its metal but not sure what metal it is.
    An outdoor fireplace
    A weight bench for bench press
    3 tires with rims (not sure what the rims are have to check)
    I also have a bunch of stuff around my own yard that im guna see if my mom wants me to get rid of for her.
    3,404
    I'd say you did ok. The washer and dryer will be Light Iron. You might want to see if the drums are aluminum and take them out. Cut the cords off. Maybe the motors. Bed frame and bike frames are Light Iron. If the bikes are whole and straight, you might do better selling them on Craig's List. I sell/barter any bikes to a guy who repairs and sells them. Weight bench the same way. Check the rims to see if they're aluminum; otherwise, should go as #1 iron. They probably want the tires dismounted. Remove valve stem and attachments, if aluminum. The sink is likely aluminum or cast iron. If cast iron and porcelain, they may just give you Light Iron price for it. Check for any brass or stainless steel parts.
    Welcome to the Forum.
    BigRyan's Avatar
    206
    134
    Good job man! Feels good to gather up a load, doesn't it?
    19
    Ill find out when i turn it over to the scrap yard. Didnt have enough time today. I still got a lot to learn but im hoping i can make enough money to fill up my tank and maybe pick up some tools.
    rca987's Avatar
    939
    Welcome.
    Check the outdoor fireplace. I found one once that had a copper cover, thing weighed nearly 30 lbs.
    c4f5 is offline Metal Recycling Entrepreneur
    c4f5's Avatar
    northeast CO
    386
    112
    Put a magnet to the bike frames, as a small handful are aluminum. After you have had a couple, you will know them when you see them. Check washer tubs and dryer drums...get a stainless one once in awhile...same with the sink. If the sink still has the drains attatched, they are likely brass or stainless. Get a couple buckets & start saving wheel wieghts (lead) and valve stems (brass)
    And the sink faucets have a strong possibility of comtaining brass and/or stainless.
    wayne1956's Avatar
    Cleburne, TX
    704
    195
    In addition to cutting the power cord remove the wiring harness. Insulated copper is going for over $1 a pound around here. You can hoard it for a while and it does not take up much space, and when you have 30 or 40 pounds, take it in.
    19
    Ok so i went out with the magnet and 1 of the bikes frames are aluminum. So now i have to strip the bike down to just the aluminum right? The sink is also aluminum i believe.
    jerseyscrapper's Avatar
    NJ
    129
    Quote Originally Posted by Cwatson325 View Post
    i would strip the bike down to just the alm, my yard give me clean alum price on stripped bike, double check th sink it might be stainless steel!. GOOD LUCK
    *i have scrap metal running through my blood and i love it*
  10. #10
    c4f5's Avatar
    northeast CO
    386
    112
    Indeed, strip those babies down. The sink is likely stainless.....not saying they don't exist, but I've never seen an aluminum sink. A quick clue on sinks, dryer drums & washer tubs...the stainless ones won't be painted. Always stick a maget to bike frames...some of the aluminum ones will be painted, but most won't. Stick the faucets & drains too. If they are not sticky, put a file to them to see the color inside...shiny silver will be stailess, shiny gold will be brass. Like wayne1956 said, separate the little stuff into buckets & wait for a full bucket to take it in.
  11. #11
    19
    I took in the load today and got $46 for 480lbs of lite iron. I left the aluminum bike to strip and the fireplace cause I think it might be cast iron. Not sure though.
  12. #12
    London Ontario Canada
    Not sure about your area, but I always save my bedframes with my steel pile. Steel here is $280 per tonne, and appliances and mixed tin are about $180
    1. First pay day scrapping
      By CAPTSCRAPER in forum Introduce yourself
      Last Post: 09-17-2012, 07:19 PM
    2. $90 Day Scrapping - This is What my Junk Yards are Like...
      By BiggerHammer in forum Scrap Metal Videos
      Last Post: 04-03-2012, 04:19 PM
    3. Happy Scrapping Valentine's Day and Happy Birthday!
      By scrapdollar in forum Off Topic Discussions
      Last Post: 02-13-2012, 09:01 PM
    4. good day scrapping
      By johnnybeegoods in forum A Day in the Life of a Scrapper
      Last Post: 07-13-2011, 07:20 AM
    5. Not a bad scrapping day, even if I didn't set out to scrap
      By Rowdy in forum Scrap Metal Questions and Answers
      Last Post: 02-04-2011, 12:46 PM
