Results 1 to 14 of 14
Bye, Bye, bobcat trailer
    bullion is offline Metal Recycling Entrepreneur
    bullion started this thread.
    149
    72
    Well, my 2005 diesel pickup truck sprung a coolant leak on Friday.
    Having no spare cash around due to the low price of shred, looks like I have to sell my bobcat trailer to pay for the repair (around 800 bucks if it is the water pump).
    I am hoping it is not the water pump-it could be the thermostat gasket so here's hoping.
    eagle lake mn
    28
    Are you able to fix yourself a waterpump should run around 100$ and a hour or 2 of your time.... If your not very mechanical youtube im sure will have a video of step by step replacement just throwing it out there to mybe help you save some $$
  3. The Following 2 Users say Thank You for This Post by eaglelakesalvage:
    Patriot76's Avatar
    Buffalo Commons
    2,955
    10,578
    Eaglelakesalvage is right on target. Instead of you tube, I just Google the knowledge needed. I am not real patient with video's and prefer pictures and hands on advice. The only good reason to sell equipment in my mind is to upgrade. Good luck.
  5. The Following 4 Users say Thank You for This Post by Patriot76:
    Scrappah's Avatar
    1,056
    318
    How bad is the leak ?
    If it's not too bad, a bottle of cooling system sealer might do the trick.
    ilovejunk's Avatar
    163
    112
    Quote Originally Posted by Scrappah View Post
    not to sound rude, as i have done this on plenty of old beater work trucks to get by until i could do the proper repair; but DO NOT ad any kind of "stop leak" type coolant additive to a newer turbo diesel, especially a power stroke unless you want a guaranteed turbo or head gasket failure in your future.
    powerstrokehelp.com, powerstrokenation.com, oilburners.net, and a few other out there can get your all the info you need to fix it yourself properly.
  8. The Following 3 Users say Thank You for This Post by ilovejunk:
    matador's Avatar
    Nov 2013
    Big Wonderful Wyoming
    2,309
    1,782
    I've never done well with the stop leak, either. I wouldn't depend on it for a diesel system. Depending on skillset, time, and need, repairing yourself may be the way to go. I learned how to replace a radiator on my Buick because I had to. Once you become acquainted (Watch as many videos and read as many forum threads as you can find), it's not too bad- just a giant step-by-step.
    Best of luck!
  10. The Following User Says Thank You to matador for This Post:
    Scrappah's Avatar
    1,056
    318
    Quote Originally Posted by ilovejunk View Post
    It's kool.
    I've always used Bar's Stop Leak. As far as i know, it's safe to use in a diesel.
    Bar's Leaks US site Head Gasket Fix - Bar's Leaks US site
    Afterthought:
    The biggest problem is the radiator cap. They should either be pressure tested -or-replaced on a yearly basis.
    eagle lake mn
    28
    I forgot to mention ebay is a great outlet for buying parts I needed wheel berrings for a 200 blazer Orillys wanted 120 each picked a pair up for 67$ with free shipping. have to wait a few days but the savings are worth it. I fix alot of "junk" cars I buy most of the time its suspension, brakes, or easy stuff. Couple hundred dollars and a few hours turns a 200$ clunker into a 1000$ beater. Example the blazer im working on 175 purchase price, 67 wheel bearings, 12 stabilizer bar bushings, 20 rear brake pads For a total investment of 274 and about 4 hours. Gives my younger sister a first vehicle that she will work off helping me strip wire and clean up brass.
    NatureRecycleFlorida's Avatar
    May 2015
    Florida
    171
    143
    matador's Avatar
    Nov 2013
    2,309
    1,782
    A 2005 will be either the Cummins 5.9, Ford 6.0, or Duramax 6.6 NatureRecycleFlorida has posted a huge wealth of information there- one of those videos should tell you how to do it!
    Usa
    762
    67
    I would never cut a arm off to fix the other. That is just ludicrous...LOL
    Chesaning
    472
    24
    Its probably a 6.0. Your going to need to sell more than your trailer.
    149
    72
    Duramax is what I have.
    Thanks for the advice all-I appreciate it.
    I got a loan to fix the truck.
    The shop started on it yesterday at 3 so it should be done this afternnoon.
    JnJunk's Avatar
    Oct 2014
    188
    34
    Diesel are money pits. When they do run they run great. But when they brake, FORGET it. Especially the late 90's fords. $1500 bucks to have an oil pain replaced. Just a joke
    1. Trailer Brand names. Looking for a Tandem Axle trailer for Scrapping.
      By Kochy in forum Scrap Metal Tips and Advice
      Last Post: 08-25-2014, 09:40 PM
    2. last week trailer stollen this week new trailer for free
      By mrvictor1 in forum A Day in the Life of a Scrapper
      Last Post: 05-16-2013, 12:34 PM
    3. Florida | Items Wanted - nw florida looking for a cheep cheep bobcat or small tractor with loader.
      By EcoSafe in forum Scrappers Classifieds
      Last Post: 05-04-2013, 07:47 PM
    4. Converting an old single axle boat trailer into a utility trailer worth it?
      By JunkmanDan in forum Scrap Metal Recycling Tools & Equipment
      Last Post: 08-23-2012, 09:19 AM
    5. Trailer
      By wescrapmetal in forum A Day in the Life of a Scrapper
      Last Post: 01-29-2012, 10:08 AM
