A lot of those motors will be 'stepping motors'. Its pretty easy to see the difference between them though.
DC motors have two or three wires and often a capacator soldered across where the wires are soldered on the motor. Normally marked with their voltage too.
The stepper motors, when you turn the shaft they 'cog' each time the poles go past their magnets. Each 'cog' is a 'step' in the motor. These steps can be controlled by electronics. You can tell it to turn 130 turns and then go a extra 72 degrees and it will.
They also have 4 or more wires going to them. Or a attached PCB and electronics.
The bigger ones are usefull in robotics and other projects. They normally come off photocopiers and have the driver boards connected to them. The hole spacing for mounting the motors that are by themself is
often the same as the Ali extrusion thats molded into the centre of a FxP smart drive washing machine.
Meaning that there's Ali extrusion that's specially made for mounting these motors that can be brought 'off the shelf'.
I am using these stepper motors to drive the saddle and cross slide on a EMCO mini lathe, the smallest they make.
These stepper motors can be sold for this job, or making 3D printers or suchlike.
While you are at it, there's really nice shafting rod steel in printers.
This could be sold to the same home hobby engineers that would buy the stepper motors.
I have found that some small transformers have the 'stacked iron
core' welded on them. (As opposed to the 'interlaced' sort)
A stack of the 'I' 's are great packing for under the lathe tool so you can put the tool tip on centre with the metal being machined.
