Results 1 to 14 of 14
Unique find
    Copper Head started this thread.
    Copper Head's Avatar
    Up North
    1,883
    579
    Unique find
    20150624_121148_zpscm7ptcwk.jpg Photo by kpic4 | Photobucket
    Is this a militarily bullet tip ?
    6 inches
    1 1/2 at base
    tip is 3/4
    Weighs 5 pounds
    non magnetic
    stainless steel ?
    Zinc ?
    Lead with stainless clad
    For it's size the weight is noticeable to me
    If not bullet tip then what ?
    NHscrapman's Avatar
    new hampshire
    1,582
    4,076
    If it was a "bullet" I would assume it falls under artillery simply because of it's size.
    or one massive plumb-bob
    anything on the bottom or is it solid maybe concave?
    t00nces2's Avatar
    Jul 2014
    Sarasota, FL
    1,707
    1,191
    I would say it is likely. Smack it with a sledge to find out if it is an explosive round. Let us know the result.
  4. The Following 4 Users say Thank You for This Post by t00nces2:
    4,758
    6,037
    Cool find have someone hit it with one of them fancy guns to find out whats it made of...
    What makes you think it comes from a military shell, the shape?? If it has/had explosives the it would have a way to assemble it, it would not be a solid object normally. Mike
  7. The Following 2 Users say Thank You for This Post by miked:
    bigburtchino's Avatar
    California
    1,647
    4,388
    "I'm Bigger than yours"
  9. The Following 3 Users say Thank You for This Post by bigburtchino:
    HT1's Avatar
    Jan 2014
    NE Florida
    249
    24
    it's not a shell, it looks like a machinist trying to make a "dummy" shell for an ornament of some sort
    probably to fit a 40MM saluting cannon which of course have no projectile, but there are lots of the cartridges floating around... the newer ones are steel rather then brass
    V/r HT1
  11. The Following User Says Thank You to HT1 for This Post:
    Up North
    1,883
    579
    It has a flat bottom and yes not to confuse I consider it a tip for a shell . The bottom has a typical shape most bullets have at bottom , the edge is concaved for non obstructive fit .
    The weight is the mistery .....
    this is smaller then a 5 pound steel mallet head
    also solid stainless I believe is not any more heavy then it's ferris steel counter part size for size
    I've held many dense metals in my hand
    this has that weight for size that lead has , but the surface is not lead.
    I have heard for larger artillery -Zinc has been used as it enhances accuracy
    DakotaRog's Avatar
    Aug 2014
    1,611
    602
    1.5 inches x 25.4 mms an inch equals about 38 mms, not far from 40mm. How much does a DU (are they a solid projectile) shot from an A-10 Warthog weigh??
    If it is a DU round, CH I would suggest wash your hands thoroughly and not handle that thing until you find out...
  14. The Following 2 Users say Thank You for This Post by DakotaRog:
    brandon's Avatar
    North Carolina
    787
    That's what I was thinking too dakotarog,
    My fortune cookie said:
  16. #11
    t00nces2's Avatar
    Jul 2014
    Sarasota, FL
    1,707
    1,191
    I posted a pic a while back of a shell I picked up. The projectile has been milled to fit inside the shell and set down on a rim the same circumference as the shell. I noticed that your has no relief to fit inside a shell casing...
    armygreywolf's Avatar
    Germantown, WI
    1,084
    193
    I'm not POSITIVE but I believe that is a stainless steel headspace gauge for a 30mm IFV main gun. If it's not, then it's something random and not necessarily firearm related.
  18. The Following User Says Thank You to armygreywolf for This Post:
    Up North
    1,883
    579
    Quote Originally Posted by armygreywolf View Post
    It could be .... but is non ferris stainless steel - type - size for size heaver then ferris steel like the typical steel we sell as short .
    The weight density to size if anything is what I'm miffed about .
  20. #14
    Germantown, WI
    1,084
    193
    stainless steel is heavier than regular steel by a noticable margin
  21. The Following User Says Thank You to armygreywolf for This Post:
    1. Unique find in a clean out...
      By michaelcali in forum A Day in the Life of a Scrapper
      Last Post: 02-07-2015, 07:44 PM
    2. Unique C-clamp
      By Mick in forum More than Scrap Value
      Last Post: 03-04-2014, 02:54 AM
    3. A unique find
      Last Post: 06-06-2013, 09:10 AM
    4. Replies: 7
      Last Post: 07-31-2012, 11:08 AM
    5. A unique find
      Last Post: 07-03-2012, 09:50 AM
