This info is a little old, but still very relevant.
According to a 1990 report from the U.S. Environmental Protection Agency, the largest segment of municipal solid waste is the Containers/Packaging component. Whether by weight (32 percent) or by volume (30 percent), containers and packaging products are the dominant materials in the waste stream.'
So if you can recycle, reuse it or sell it as scrap (cardboard). Especially with the difference in scrap cardboard and scrap light steel only pennies in pound difference. With literally tons of cardboard available for free and plenty of it clean. Use if you can and it works for your system!
The cost of the packaging as a percentage of total selling price varies greatly. Although this cost can range from 1.4 percent to 40 percent and some food products even higher. The typical average cost of packaging is $1 for every $11 spent. Nine percent of the amount you spend on any product is probably going to be in the packaging. There's a target price to try to achieve, keep your packaging cost below 2% of the cost of the item, if you can. That's how you maximize profits, percentage targeting!
Getting it there is part of packaging cost and the actual transportation cost can fluctuate with unpredictable rates at anytime. Here in California, gasoline went up $.11 just overnight! (again).
