Results 1 to 15 of 15
Hammer Mill vs Granulator
| Tools and Equipment
    Hellbringer started this thread.
    Apr 2015
    Surface of the Sun
    What is the difference between a hammer mill and a granulator. I can find granulators all over the place (ebay) used and at a decent price, but everything that i see scrappers using is a hammer mill (youtube) which are 10k+ and can only be found over seas?
    I am looking to turn pcb into a powder in order to do copper recovery from PCB's
    Mike
  2. The Following User Says Thank You to Hellbringer for This Post:
    matador's Avatar
    Nov 2013
    Big Wonderful Wyoming
    2,310
    1,813
    Hammer mills can be had cheaper. We used one in a grinder mixer (One of these) to make feed. :
    The hammer mill is the front part- the large round barrel is just a storage tank. Unless they're specifically designed for pcbs, watch for dust and particles ejected from the machine. The dust will likely be toxic.
    A hammer mill uses metal "hammers" to grind. They will wear down, but they can be turned. If you're going to do a lot of grinding, you may wear them out. We owned our Gehl grinder for 30 years, and only turned them once. Of course, feed grinding is easier on the machine.
  4. The Following 2 Users say Thank You for This Post by matador:
    sawmilleng's Avatar
    Central Kootenays, BC, Canada
    861
    713
    I think you need to establish exactly what you want to do with the PC boards to decide what you need to use to grind them up. Are you going to "grind" the boards and all the electronic "stuff" on the boards into a powder so you can separate the metals by washing, with the heavies settling out? Kinda like panning gold?
    Or are you just breaking the stuff down so you can get a chemical process going on all the metals in the mix? Which might mean quite a bit coarser grind? (and less costly grinder)
    There will be a tradeoff here, as the finer the material is ground, the quicker the chemical reactions will take place. But the cost of finer grinding may start to interfere with the economics of the process.
    Also, you probably are looking for the higher value metals from the mix, such as gold, silver, etc, that is found in small amounts in e-scrap. It can outweigh the copper in value.
    I am doing a bit of blue sky talking here, as I have not done either type of process but understand some of the physics behind them.
    If you are looking to do the chemical recovery work, you need to pop over to the "gold refining forum" to ask some questions. But be warned: they are a crusty bunch over there and don't take the sillier newbie questions very well!! I'm sure there are lots of people over there who have done or are doing exactly what you describe.
    We have a few people who refine e-scrap who visit this site from time to time...maybe they will chime in.
    Good luck,
    Jon.
  6. The Following 2 Users say Thank You for This Post by sawmilleng:
    Apr 2015
    Surface of the Sun
    Quote Originally Posted by sawmilleng View Post
    Good luck,
    Jon.
    I am looking to get them as fine as possible and use water methods.
    Now i am planning to remove all the chips from the board first, then incinerate those and run them with a water process so i would just be grinding up the bare PCB for the copper the gold and such should be in all the chips.
    Another food for thought, do you know how well the fiberglass of the pcb bonds to the copper? In the video posted below they use a granulator to chop up copper wire, and then separate the shield from the copper based on a shaker table due to the weight difference. This works because the copper has no bond with the shield and when it gets to the shaker table it is 2 pieces. If the fiberglass bonds to the copper, it wont be 2 different pieces and be unable for the table to separate The higher the bond with the fiberglass the smaller finer the pcb needs to be ground to get them to separate.
    Thanks for the responses guys
    Mike
    sawmilleng's Avatar
    861
    713
    Mike,
    I think you may have to do some experimenting. PC boards are made from lots of different things, not just fiberglass, and the bonding of the copper to the PC board has just as many different glues. You might be looking at a couple of processes to get the boards down to a small size: hammermill hogging for the first pass and then putting through a ball mill to get the stuff down to a powder.
    How well the copper will separate is a good question. More reason to do the experimenting. The ball milling copper separation may work better dry, wet, or hot...to break glue bonds---more experimentation.
    If you are looking to do this on any sort of scale, then discussion with the purchaser is in order. A percentage of waste (in this case, circuit board material) in the copper feedstock to, say, a smelter, may not be an issue for the purchaser.
    I've been critical of the wire granulating because of the same questions. Smaller wires don't have any reason to fall free of the insulation that surrounds it. A lot of the granulating vendors don't talk much about copper recovery %'s and contamination of the recovered copper with unwanted wire insulation. Press them a little by trying to write a separation guarantee into the purchase agreement and watch them squeal like pigs!!
    etack's Avatar
    Buying Tantalum capacitors
    United States ohio
    503
    443
    This would be a waste of time to float out Cu from PCBs. It is laminated in the fiberglass with resins. You must free the Cu from the resins first with heat. After that just melt it and form Cu alloy bars.
    The only reason to grind with a HM would be to mix it well to get a good sample to send to a refiner. This seems like spending $100.00 bills to find dimes.
    Eric
  10. The Following 3 Users say Thank You for This Post by etack:
    spinroch's Avatar
    675
    1,983
    I wonder what the EPA & the DEC would have to say about grinding up circuit boards.....
    F1 Recycles
    www.f1recycles.com
    ChildhoodDream's Avatar
    Mar 2015
    Minnesota
    569
    1,644
    Quote Originally Posted by spinroch View Post
    They would say you are good to go as long as you have the required permits and permissions and/or you can afford the fines.
    sawmilleng's Avatar
    861
    713
    Whats the bad actor in grinding up circuit boards? As long as the process is not releasing deleterious products to the air, water or land. Burning the electronics removed from the boards is more likely to cause rectal hemmorages down at the epa.
    All I can see in the process of grinding up boards is maybe dust issues or water disposal issues when separating the copper. But not enough to cause anyone to cut short their donut stops before taking the handcuffs to badass environmental bandits...
    Jon.
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,825
    2,917
    I'm concerned with the "water methods".
    What do you do with all the water when you're finished?
    15,631
    Quote Originally Posted by jimicrk View Post
    I guess each of us look at projects like this in different scales. By this statement I mean IF I were going to personally investigate a process that could be up scaled I would start very small. In the small scale testing there would be little water to deal with since I would imagine me recirculating it and having to ADD water due to evaporation.
    In the end I might be left with some "problem" material but it would not have water in it. I think the positive thing of this discussion is we are having on the forum.
    One thing I have learned from participating on this forum is it's challenging to fully express the point we are making in the written word. Its so much easier to convey a complete thought in person. Mike
  16. The Following 4 Users say Thank You for This Post by miked:
    Apr 2015
    2,177
    633
    Water is a precious commodity, your recirculate and reuse.
    Hamme rmill wins hands down as it can do more than one product. The downside is that they require a lot of horse power.
    http://www.scrapmetalforum.com/off-t...l-cyclone.html
  18. The Following 2 Users say Thank You for This Post by alloy2:
    Apr 2015
    2,177
    633
    Hang gunny sacks into the water to wick it upwards to which natural convection willl evaporate the water leaving the solids behind.
  20. The Following 4 Users say Thank You for This Post by alloy2:
  21. #14
    CapitalRecovery's Avatar
    Aug 2015
    United States
    318
    232
    I think you may be looking for a set up like this?
    with a shaker table.
  22. #15
    15,631
    I like the set up in the this video. One thing I have noticed in most of these type of demonstration videos the machines are being feed one hand full at a time. Also there is no discussion as to adjustments that have to be made to get the fastest and best recover rate. 73, Mike
    1. Ohio steel mill temporarily closing
      By HiTechMike in forum Scrap Metal Prices
      Last Post: 02-10-2015, 07:10 AM
    2. Bridgeport mill
      By DD1700 in forum A Day in the Life of a Scrapper
      Last Post: 07-23-2012, 10:32 PM
    3. Buy a wire stripper or a hammer mill?
      By miked in forum Tools and Equipment
      Last Post: 02-21-2012, 09:28 AM
    4. tread mill motors
      By Ky lady scrapers in forum Scrap Metal Questions and Answers
      Last Post: 11-22-2010, 03:08 PM
