Results 1 to 13 of 13
Safe storage of cr2032 batteries
| Batteries, Capacitors, Heat Sinks
    Mike1286 started this thread.
    Mike1286's Avatar
    Jul 2015
    Chicago burbs
    169
    I had an epiphany today and figured I'd share it with you guys.
    As I take apart more and more computers, the cr2032 batteries off the motherboards have been starting to pile up. Until now, I've been neatly stacking them on one of my shelves to keep them from short circuiting as they would if just thrown in a coffee can or other container. I started searching Google and amazon and whatnot looking for some kind of plastic or cardboard container. Then it hit me...
    I had a bunch of empty coin roll tubes that i held onto a while ago after cashing in the pocket change i used to save and roll. I tried them out and it just so happens the size of the cells is close enough to a penny that they fit perfectly in a coin roll. Nice, cheap, easy storage that will prevent shorting out the cells during storage or shipping. And you don't even have to label them. Just make sure the first battery you drop in has the marking side facing out the open end of the roll tube so you can see what style it is. Li-Ion, etc.
  2. The Following 4 Users say Thank You for This Post by Mike1286:
    HipoGear is offline Metal Recycling Entrepreneur
    HipoGear's Avatar
    May 2015
    735
    2,047
    I've just been throwing them in a coffee can and I have another pile in a large plastic vitamin bottle. What is the danger of them shorting out? Is there a fire hazard?
    I was thinking that it's not a good practice. You have come up with a great solution.
    1,926
    1,688
    Quote Originally Posted by HipoGear View Post
    I believe thats why buyers want the ends taped.
    HipoGear's Avatar
    May 2015
    735
    2,047
    I understand that, but what is the danger? Are there buyers for those button batteries? I know the Li-ion batteries from laptops and cell phones can be sold.
    Oct 2013
    Missouri
    100
    18
    I line the batteries up on a piece of cardboard and tape them down . The reason they want them tape and not touching Is the fire hazard. I have not found a market for them . I give mine away to a battery company. That way I know they are properly handled and recycled. I hope this helps. By the way if them short out and burn. Do not put water on them .
  7. The Following User Says Thank You to missouri for This Post:
    Scrappah's Avatar
    1,056
    318
    Humm ... i was thinking.
    You know how like you put two 1.5 volt D size batteries together in a flashlight to make three volts. ( Positive to negative and the voltage carries through ?)
    I wonder if it's the same with the coin cells.
  9. The Following User Says Thank You to Scrappah for This Post:
    jiffy117 is offline Metal Recycling Entrepreneur
    jiffy117's Avatar
    Central NY
    287
    220
    Quote Originally Posted by Scrappah View Post
    It is, so 3v x ~20 cells would be up to 60V. IF that shorts now you have a much bigger problem. A lot more potential energy ready to be released all at once. I would tape or cap one end for sure.
  11. The Following User Says Thank You to jiffy117 for This Post:
    Mike1286's Avatar
    Jul 2015
    Chicago burbs
    169
    Even in the tube, I'm still careful with them keeping them away from anything metal. I also store them on a wooden shelf. I was more just looking for a safe way to store them til I can find a buyer or just have enough to be worth the trip to best buy. I remember seeing a post where someone had a coffee can full and said when he opened it up, it had quite the chemical smell to it. I wanted to make sure to avoid that.
  13. The Following 2 Users say Thank You for This Post by Mike1286:
    4,756
    6,022
    I tape them and toss them in a coffee can. I wish there was a buyer for lithium button batteries,
    Faceball's Avatar
    Nov 2015
    Fingerlakes, New York
    228
    995
    Check your keyfobs. Most use the 2032. Last I checked, a two pack cost like $6. I have been selling them at my swap meet @ .50c for 3. Taped to card stock (old cereal box) and slid in a 2x3 baggie. Even if they have half the life, still a good deal. Iv only sold a few bags, but it adds to my table and beats just tossing them.
  16. The Following 3 Users say Thank You for This Post by Faceball:
    4,978
    1,244
    appears you can get these new very cheap
    cr2032 battery 10 | eBay
    Scrappah's Avatar
    1,056
    318
    The basic idea of a coin roll for the coin cells was kinda kool.
    Maybe just add an insulator between the cells ?
    This might work.
    Amazon.com: EK Tools Circle Punch, 0.75-Inch, New Package
    travistemple202020's Avatar
    ames iowa
    1,326
    266
    I give all mine to be recycled or away to anyone who wants them but if your looking for an easy separator I used to use plastic bingo chips a bag of 1000 is like $3 online most places even at Walmart you get a 250ct. they use to have a decent market when they were expensive and then again last year with the led light craze.
  20. The Following 2 Users say Thank You for This Post by travistemple202020:
    1. This thead is a question - Thomas Edison storage batteries
      By NatureRecycleFlorida in forum Batteries, Capacitors, Heat Sinks
      Last Post: 06-07-2015, 07:31 PM
    2. Storage Auctions Pay Off and I like Storage Battles!
      By CoachDomCosta in forum Scrap Metal Tips and Advice
      Last Post: 11-28-2014, 09:16 AM
    3. Storage: Outdoor carport gazebo. What do you use or want to use for storage.
      By mrsamsonite in forum Scrap Metal Tips and Advice
      Last Post: 09-26-2014, 11:51 PM
    4. A safe
      Last Post: 02-08-2014, 11:16 AM
    5. Safe to take this?
      By tackleberry in forum A Day in the Life of a Scrapper
      Last Post: 11-06-2011, 08:17 PM
