Results 1 to 12 of 12
new scrapper sad begginer mistake
    frankieg079 started this thread.
    Apr 2016
    26
    So when I say new. Month in. Haven't even brought in first haul. Fig do some stock piling so when do jump in. Have lil stock pile for slow weeks. Well as every Scrapper knows. Magnet. Well I been collecting broken electrons TVs etc. Mostly wire. Stripped lot of wire. Thought I hit beginners score. Lot of tv cable wire. Spent half hour stripping. To realize. Copper plated steel. So threw rest wire in corner. What do I do with it???? Feels like I found fools gold. Lol. But I'm not to bummed. The dumpster I found that In. I also took out other good wire. Tv. Vacuum and a broken extension cord
  2. The Following User Says Thank You to frankieg079 for This Post:
    4,756
    6,022
    Coax cable can be tricky, depends on your yard. One yard here buys it as is for a little bit more than shred steel. Other yards do not take it, or only take it in with the shred steel. As you have stripped it I feel the yard will take it as steel no questions asked...
  4. The Following 3 Users say Thank You for This Post by hobo finds:
    nutpie is offline Metal Recycling Entrepreneur
    nutpie's Avatar
    maine
    441
    379
    The metal ends are almost always brass (dirty or clean, you have to figure that out ((depends on the buyer)). The rest of the cable wire (co-axial) in the shred pile (again, depends on the buyer).
  6. The Following 3 Users say Thank You for This Post by nutpie:
    4,756
    6,022
    Yep, I forgot to mention the ends. By me you get dirty brass or copper content for them, with dirty brass paying more...
  8. The Following User Says Thank You to hobo finds for This Post:
    4,918
    15,581
    Most coax that the cable tv providers use has the copper plated steel center conductor you found. Other coax that is used for radio transmission has solid copper center conductor and often the shield braid is copper. If the shield is silver in color it is either Al or tinned copper. Scrape the shield with a knife and if you see some red then you will know its copper.
    Mike
  10. The Following 4 Users say Thank You for This Post by miked:
  11. #6
    bick23's Avatar
    Oct 2015
    Winnebago, IL
    I usually stick the coax cable into washer or dryer tubs and then move it through as shred. If I run out of things to do I know I have them stashed there and will go after the ends, otherwise I just let it all go as shred and it makes the load look good when the office people see it.
  12. The Following 2 Users say Thank You for This Post by bick23:
  13. #7
    Hurrikane is offline Metal Recycling Entrepreneur
    Hurrikane's Avatar
    South Park,PA
    172
    95
    got a roll of coax that had been stored for thirty years or so. copper color outside tough to tell inside though. not magnetic. no sparks with grinder. solid copper? coated aluminum? fairly stiff so i'm not leaning towards aluminum. thoughts?
  14. The Following User Says Thank You to Hurrikane for This Post:
  15. #8
    30 year old, almost definitely copper.
  16. The Following 4 Users say Thank You for This Post by Mechanic688:
  17. #9
    nutpie's Avatar
    maine
    441
    379
    Quote Originally Posted by Hurrikane View Post
    Can you cut the wire and look at the center of the core metal?
  18. The Following User Says Thank You to nutpie for This Post:
  19. #10
    4,918
    15,581
    Without a doubt if its anywhere near that old then its copper not steal.
    I have yet to see any Al that is plated to look like copper. You can cut off a a piece of metal and feel how it feels in your hand often you can feel the difference. This does that experience and testing is always best. Mike
  20. The Following User Says Thank You to miked for This Post:
  21. #11
    RLS0812's Avatar
    Bucks County Pennsylvania
    896
    155
    Aluminum will become slightly oxidized ( turn whitish ) when it contacts hydrogen peroxide.
    Steel will rust.
    Silver will turn slightly black.
  22. The Following 2 Users say Thank You for This Post by RLS0812:
  23. #12
    wavecrazed is offline Metal Recycling Entrepreneur
    wavecrazed's Avatar
    219
    Use the magnet to test
    1. did i make a mistake -auction win
      By ozzy214 in forum General Electronics Recycling
      Last Post: 11-09-2012, 03:26 PM
    2. scrap yard mistake
      By fordss in forum General - Let's talk business
      Last Post: 04-10-2012, 10:01 PM
    3. Common Mistake?
      By MelRay in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 02-02-2012, 02:18 PM
    4. Scrap Yard Mistake
      By WHIscrapping in forum A Day in the Life of a Scrapper
      Last Post: 04-04-2011, 07:18 PM
    5. ALMOST made a big mistake
      By Mick in forum A Day in the Life of a Scrapper
      Last Post: 02-25-2011, 02:00 PM
