Results 1 to 15 of 15
plastics recycling
| Non Metal Recycling
    smallscaleassembly started this thread.
    Aug 2017
    plastics recycling
    Does anyone know where I can recycle plastic bumpers in South Carolina?
    I have recently taken on a couple of body shops but I have to take everything when I take it which includes the bumpers.
    I would rather not just throw them in the landfill if I can make some $ off of them. I have probably a small trailer load right now but will have more as I pick up from the body shops.
    Chesaning
    472
    24
    Good Luck. Plastics is a hard market right now and bumpers off cars are a very low grade plastic.
    You would be better off landfilling it.
    Once in a while you can find companies that refurbish bumpers and will give you $3-$10ea.
    Mike1286's Avatar
    Jul 2015
    Chicago burbs
    169
    Actually, bumpers off cars pay pretty good around me (Illinois). I currently get 10 cents per lb for pickup truck sized loads. Last year I was getting 15. That's better than steel has been. And they will pay more depending on the volume. I don't know your situation, but if you can stockpile a full truck load it may or may not pay to ship them up this way. If you have the room, even if it's break even, at least they're out of the landfill.
  4. The Following 2 Users say Thank You for This Post by Mike1286:
    Mike1286's Avatar
    Jul 2015
    Chicago burbs
    169
    Oh, and I should add, these are not refurbish prices. They strictly grind them into cullet to be recycled into new bumpers. So for scrap pricing, it's not too bad.
  6. The Following User Says Thank You to Mike1286 for This Post:
    PalmettoRedDog83's Avatar
    Nov 2017
    South Carolina
    Quote Originally Posted by smallscaleassembly View Post
    Im in the same pickle my friend.........I have plastic and glass from scrapping printers and printer-scanners, and can find no where that will take them.
    PRD
    Breakage's Avatar
    Aug 2016
    297
    242
    Quote Originally Posted by PalmettoRedDog83 View Post
    For the glass, you might ask any of your municipal recyclers if they have contact with producers of PGA, processed glass aggregate. It's pretty low value but some landfill operators use it as ADC and road base.
    Plastics are tough. I have found that ABS, the primary electronics plastic, seems to find itself in a pickle, as of late. The grading appears to be getting more and more stringent.
    PRD, have you spoken to these people? You probably have but I thought it might be worth mentioning, at least in case you had a reference or review for them to post.
    ScrapmanIndustries's Avatar
    Feb 2017
    Easton, Pa
    361
    99
    question about plastic. I've heard that ABS is a number 7 plastic. I'm not sure how grading of plastic works unless I clearly see a number on it, but I've also heard that printers and the backs of old tv's are ABS plastic. If your municipal facility takes #1-7 plastics could you just give them all your plastic even if its not marked?
    4,758
    6,037
    ABS is considered a #7 plastic (this is the catch-all category). Most recycling centers can handle ABS plastic, and electronics manufacturers are finding new ways to reuse ABS flakes from production.
    Better than the dump!
    Breakage's Avatar
    Aug 2016
    297
    242
    You should definitely check with your municipal recycling center/curbside collector, first, before throwing e-waste plastics into the mix. Make sure when you ask, you don't just say, "I some #7 plastics," as that doesn't really reflect your material, compared to what they are thinking that you mean. For example, my area recyclers can handle #2 (HPE) and #5 (polypropylene) but exclude anything that is less than two inches wide and thick and/or longer than two feet. That means many of the plastics I pull from appliances can't go in the recycling bin. Also, most municipal plants are producing plastic bales which are food-grade, since that's where most demand is happening, and ABS is decidedly not safe to eat off of, I think. Many publicly-accessible recovery facilities can't process much more than soda bottles and newspaper and end up throwing out anything that doesn't fit the bill. Engineering grades, like ABS and polycarbonate, usually require spec'd bales and larger-scope brokerage, which is something small recyclers and municipalities have trouble doing. I have sent plastics to my e-waste processors and forum buyers and, while not free, it was pretty cheap and easier to do than overloading my recycling dumpster with stuff I can't, in good faith, expect will be recycled.
    If you don't see a #7 triangle, someplace, look on the inside surface of the bezel or plastic form. You should see something like, ">ABS<" embossed on it, someplace.
    Interestingly, I just found a piece of ABS marked with a #9 in the resin code triangle. I wonder if that's going to become the norm.
  12. The Following 2 Users say Thank You for This Post by Breakage:
    RLS0812's Avatar
    Bucks County Pennsylvania
    895
    155
    Please tell that Clearfield, Clarion, Jefferson, Elk, Center, and Indiana counties ... closest place that takes marked ABS is down in West Virginia ( 6+ hour drive ).
    4,758
    6,037
    Quote Originally Posted by RLS0812 View Post
    I feel lucky to have one of these here, ReCommunity Opens MRF in Tucson, Ariz. - Recycling Today
  15. The Following User Says Thank You to hobo finds for This Post:
    Breakage's Avatar
    Aug 2016
    297
    242
    I just checked their site. They specify "food containers" for their plastics (and distinctly forbid "computers") but is this list different from what they take in AZ?
    4,758
    6,037
    https://www.tucsonaz.gov/es/residential-recycling look at the city list of items it shows plastic chairs and coolers as well.
    May 2018
    I have yet to call them up about my carload of medical device hard platics tho...Ive just discovered a place called "blue planet recycling" up here in BC where they seem tot be able to recycle all types of plastic, but they are open to corporations only(it sems).. I have yet to call them up about my boat load of medical device hard plastics with foam linings(eek) and stickers.. This industry has just recently caught my eye since a friend who once worked at a plastics production place informed me that all tey need is a wood chipper and a conveyor type track system to grind it up into pellets and then it gets sold for more than steel (per tonne) And sisnce they are in bead form they could be reused at the consumer level in 3d printers...
    Breakage's Avatar
    Aug 2016
    297
    242
    The chipper/conveyor setup description is kind of a simplification but it isn't too far from reality. Meeting spec for plastics processors usually means going through their partners and only. Except for baled material, no plastic recycler I know of will buy any amount of "pre-processed" stuff from a collector like you or me. The 3D printer filament makers are especially touchy, since the applications are so fine-tuned and their customers are very discerning.
    Can you reach out to Blue Planet as a representative of the corporation which bought the medical equipment and gave it to you? If you present as a "services technician" or "contracted waste specialist," they may be more inclined to deal with you, since you won't technically be on your own.
    1. Pennsylvania | National - XLPE Plastics
      By ddelatorre14 in forum Scrap Buyers & Sellers
      Last Post: 11-02-2016, 03:22 PM
    2. This thead is a question - What do you guys do with your plastics?
      By lousypirate in forum General Electronics Recycling
      Last Post: 02-03-2016, 06:02 PM
    3. Plastics recycling
      By mthomasdev in forum Non Metal Recycling
      Last Post: 12-25-2014, 08:02 PM
    4. Wood chipper for plastics?
      By forwardlookguy in forum Non Metal Recycling
      Last Post: 10-24-2011, 10:19 PM
    5. What to do with plastics?
      By wtwolf13 in forum Scrap Metal Tips and Advice
      Last Post: 08-28-2011, 11:57 PM
There are currently 2 users browsing this thread. (0 members and 2 guests)
