Results 1 to 20 of 21
    Catfish Bob started this thread.
    133
    127
    Post Pictures of Your Auto Hauling Rig
    Hello
    I have been saving my money up for a while for the purpose of purchasing a car trailer or wrecker truck.
    Looking for ideas for the route I want to go.
    I'm interested in seeing how you guys have your winch rigged to your trailer. Is it super difficult to get a auto with four flat tires up on a trailer?
    Is a wrecker truck a must have for squeezing into little backyards where autos often go to die?
    Has a old car stuck in the muck damaged your trailer or winch from trying to pull it out?
    Thanks just looking for idea. Pictures work best for my simple mind
  2. The Following 2 Users say Thank You for This Post by Catfish Bob:
    18 ft trailer with a small dovetail on the back. 12k winch with wireless remote from Harbor Freight has pulled anything onto the trailer so far and cost about $340 with remote (comes w/ wired remote but I recommend the extra $40 for wireless). Winch, battery and all rigging is stashed in the tool box.
  4. The Following 5 Users say Thank You for This Post by KzScrapper:
    JohnC4X4's Avatar
    South East Ma
    986
    162
    Quote Originally Posted by Catfish Bob View Post
    I have a 2 car trailer >> about 25 foot from tongue to back, able to get 2 on as the first lifts up over the 2nd
    I also use the Harbor Freight Bandlands winch and it has pulled anything and EVERYTHING I have ever went to pickup >> I have NEVER had to leave something behind!
    I like the solid deck so when you are dragging on old stuff with parts hanging down , nothing for it to get caught on
    I am able to get into some pretty tight spots >> Practice backing up when you first get your trailer. And go SLOW >> then you have time to correct if needed
    NOPE!!
    Like I said >> I get them all >> If VERY heavy and stuck in the mud >> I use a snatch block >> Doubles the pull capacity but also cuts speed in half
  6. The Following 10 Users say Thank You for This Post by JohnC4X4:
    I have a Take 3. Very first haul was a hay wagon/stacker on the tail end of a farm cleanup. I don't have a pic of it.
  8. The Following 6 Users say Thank You for This Post by IdahoScrapper:
    JohnC4X4's Avatar
    South East Ma
    986
    162
    IdahoScrapper >> WHY is the hood up??
  10. The Following User Says Thank You to JohnC4X4 for This Post:
  11. #6
    Quote Originally Posted by JohnC4X4 View Post
    Checking fluids. Probably could've closed it before getting sidetracked for a photo. Eh, it's what I do.
  12. The Following 4 Users say Thank You for This Post by IdahoScrapper:
  13. #7
    Patriot76's Avatar
    Buffalo Commons
    2,949
    10,591
    The first auto hauling rig I used was a chain through a pipe. This required two drivers, but if the brakes did not work or my sons were driving the tow vehicle it could not hit my truck. Sorry no pictures.
    This is a picture of my second rig which attached to the bumper of the pull vehicle and sat on the ball of the towing vehicle. Tires had to hold air with both of these set ups.
    Evolved into a dove tail gooseneck flatbed. The winch is used on a variety of vehicles so it is mounted to fit a receiver hitch.
    Newest trailer and winch. Loaded are a home made wagon, rock sled, and snow sled for my Persians.
  14. The Following 5 Users say Thank You for This Post by Patriot76:
  15. #8
    sledge's Avatar
    Central Indiana
    2,717
    4,534
    I'm long removed from the car hauling side.. but here are a few pics of my trailer when I was haulin em in! This was a "Jersey Brand" 16' with no dovetail.
  16. The Following 3 Users say Thank You for This Post by sledge:
  17. #9
    sledge's Avatar
    Central Indiana
    2,717
    4,534
    Here are some of the pics of the winch box. Welder did a STELLAR job making this "fit like a glove"
    Tube for ramps to slide wherever they needed and steel winch cable to smoothly roll-up without tearing up the decking of the trailer (You can see how the boards were getting chewed at that point, the tube was set slightly higher now in order to stave that chewing off)
  18. The Following 5 Users say Thank You for This Post by sledge:
  19. #10
    sledge's Avatar
    Central Indiana
    2,717
    4,534
    Before I was done I had upgraded to a Factor 55 ProLink and 3/4" Crosby Screw Pin Anchor Shackle which made it stronger than any other set-up out there on my J-Hooks.
  20. The Following 2 Users say Thank You for This Post by sledge:
  21. #11
    sledge's Avatar
    Central Indiana
    2,717
    4,534
    Last but not least: Re-moveable Fenders. Only hauled like 2 cars with them and then sold the trailer. I miss that hunk of old iron these days!
  22. The Following 5 Users say Thank You for This Post by sledge:
  23. #12
    Patriot76's Avatar
    Buffalo Commons
    2,949
    10,591
    Quote Originally Posted by sledge View Post
    I like your set up and sorry you had to part with it. Hope you don't mind if I borrow a few of your ideas.
  24. The Following User Says Thank You to Patriot76 for This Post:
  25. #13
    sledge's Avatar
    Central Indiana
    2,717
    4,534
    Patriot:
    Borrow away. I actually had fun working to figure some of these things out. As they say "kept me out of the bars." I was lucky I had two guys who did welding for me that were top notch. I wish I could have done the welding myself.. but I'm big on paying for someone's talent and know my own limitations. I had a love/hate relationship with that trailer. I spent a lot of time and $$$ on that sucka.. but I was proud of it. I made it mine. When the steel market took a dump and the uncertainty of recovery, coupled with moving into the e-waste side instead. The old girl had done her job and done it well. These days she is working for a local contractor hauling bobcats around somewhere in Indianapolis!
    When I'm out and about I always look for her.. thus far I have yet to see her again.
  26. The Following 3 Users say Thank You for This Post by sledge:
  27. #14
    DiamondN's Avatar
    912
    2,150
    Nice setup, Sledge...I had never thought about using quick release fenders...If I ever see 'her' around Indy, I'll let you know...
  28. The Following User Says Thank You to DiamondN for This Post:
  29. #15
    Mar 2018
    Alaska
    60
    Wrecker
    For heavier hauling, has anyone considered one of the 5 ton army surplus wreckers? (M816, M936, etc). Medium wrecker, off-road capeable...
  30. The Following User Says Thank You to M923 for This Post:
  31. #16
    Jan 2019
    United states
    Wow, amazing pictures.
  32. #17
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,825
    2,917
    Quote Originally Posted by Patriot76 View Post
    I'm guessing this was used back in the days when cars had real bumpers. Interesting.
  33. The Following User Says Thank You to jimicrk for This Post:
  34. #18
    jmerritt's Avatar
    Waterbury,Ne
    167
    39
    [IMG][/IMG]
    nothing special just an 2012 18 foot electric tilt hull trailer with a warn 10,000 winch on it.
  35. #19
    ScrapmanIndustries's Avatar
    Feb 2017
    Easton, Pa
    361
    99
    don't know if this will work
    but its a 4 banger toyota tacoma with 5x10 trailer. I have to chop cars in two if i want them to fit.
  36. #20
    Feb 2017
    Easton, Pa
    361
    99
    maybe this one will work
  37. Similar threads on the Scrap Metal Forum
    1. How to post pictures to the forum - Video
      By Ballymoss in forum SMF Support Forum
      Last Post: 01-19-2018, 10:36 AM
    2. Impossible to post pictures?
      By MontrealScrapper in forum A Day in the Life of a Scrapper
      Last Post: 12-19-2015, 08:21 PM
    3. Post pictures or links of pictures
      By chzman in forum Off Topic Discussions
      Last Post: 04-21-2014, 11:01 PM
    4. How the F do u post pictures here?
      By badewolf in forum Off Topic Discussions
      Last Post: 01-17-2012, 03:05 AM
    5. Post pictures of your car haulers.
      By Catfish Bob in forum Vehicle Recycling
      Last Post: 11-21-2011, 07:37 PM
