Results 1 to 15 of 15
Anyone know what these things are?
| Scrap Metal Identification
    kss started this thread.
    kss's Avatar
    May 2019
    PA
    839
    465
    Heavy, over 1ft long, have a big magnet in them.... not sure what they are, but I am guessing something telcom/ phone switchboard related maybe?
    They look like they have Silver contacts in there. That would add up to a good amount of Silver.
    If theres magnets then the rests probably got a lot of Steel in it.
    I guess, take one of them apart a bit to see. But I'm thinking 'Silver contacts' at the moment.
  3. The Following 3 Users say Thank You for This Post by eesakiwi:
    kss's Avatar
    May 2019
    PA
    839
    465
    Hmm glad I checked in there then! I was just going to clip the wires and throw the rest in the shred pile! I will take one apart and see if I can grab the contacts out.
    Any way you know of to determine if they are silver or not? I am assuming they will be non-magentic, but other than that not really sure how to differentiate between if its silver or alum/stainless steel.
    But Ill get the contacts out and post some pics just of them.
    Thanks! for the help!
    Maple Ridge, BC, Canada
    254
    103
    Sometimes on older higher end telecom gear, those contacts may contain gold and/or palladium as well. Usually the gold/palladium contacts are very small, rectangular, 1/8" or less in length and very narrow. If you get this material in quantity, it is very good material. I'm sure most buyers on here would be interested. There was a good discussion about this type of material on the gold refining forum a while ago.
  6. The Following 4 Users say Thank You for This Post by aurum:
    kss's Avatar
    May 2019
    PA
    839
    465
    Quote Originally Posted by aurum View Post
    So, not sure If what I took off are what the contacts you guys are referring to..... They were metal, non-magnetic, little nubs that were.... soldered? or glued? not sure, to what looked like little copper transformer spools. I have many various pictures here that may provide more clues.
    https://imgur.com/a/yCAan2t
    Not sure how to tell if they are silver or not. They look kinda like they may be aluminum, but seem like they might be too heavy to be aluminum, but still not sure. I didnt see anything that looked like gold, but stopped after snapping off these little pieces. There is certainly more taking apart to do!
  8. The Following User Says Thank You to kss for This Post:
    15,631
    Quote Originally Posted by kss View Post
    Simple gold/silver test kits are available on ebay and no doubt on amazon for cheap. I have used them in the past. Worth it to know for sure. 73, Mike
  10. The Following 3 Users say Thank You for This Post by miked:
    hills's Avatar
    Sep 2017
    1,554
    829
    Hummm ... it's been a couple of days and i'm still trying to puzzle out what the heck they are. Any clues like a manufacturer's name or model number somewhere ?
    It looks like they were meant to move back and forth because they were set on a spindle. Any pics of any magnets and how they were involved ?
    Silver is said to be weakly magnetic in the presence of a neodymium magnet. A hard drive magnet would do.
    Know anybody with an XRF gun ?
    Any friends that you know of in chem lab ? They could do a weight to volume displacement to figure out it's density.
    A drop of household bleach might give you a clue. One drop on the metal. It could be silver if it turns dark or black.
  12. The Following 3 Users say Thank You for This Post by hills:
    nutpie's Avatar
    maine
    441
    379
    Put a file to the big silver colored piece of metal. Might be copper. I have come across similar pieces that were solid copper with some sort of metal plating.
  14. The Following 3 Users say Thank You for This Post by nutpie:
    kss's Avatar
    May 2019
    PA
    839
    465
    Quote Originally Posted by nutpie View Post
    Great advise! will def try that
    kss's Avatar
    May 2019
    PA
    839
    465
    I do not know anyone with an XRF gun unfortunately....
    No lab friends either lol.
    A couple markings on them but nothing that yeilded any results after googling
    Never heard of the bleach thing but worth a try! I will probably get time this weekend to disassemble these things a bit more completely.
    I dont think those bits in the tray are the contacts.
    On the free end of the thin metal strips with the rounded end on it, theres a tiny dot, on the underside there should be a contact, and there should be another contact under that & connected to something else, thats connected to those bits in the trsy.
    Take some of those pieces off the unit & get a photo of all of the individual bits in one photo, and another photo of their other sides.
  18. The Following User Says Thank You to eesakiwi for This Post:
  19. #12
    kss's Avatar
    May 2019
    PA
    839
    465
    I think you are right. I think the things in the tray are actually alum heat sinks. I am going to try and remove some of the contacts today and grab a few pics
  20. The Following 2 Users say Thank You for This Post by kss:
  21. #13
    kss's Avatar
    May 2019
    PA
    839
    465
    I am trying to get a pallet ready to be sent off currently.... but I am going to get to the bottom of these things from this post hopefully this weekend. There has got to be some value in these things, I can just feel it in my BONES!.... or maybe not and itll all go in the shred pile ....
  22. #14
    4,985
    1,257
    My honest opinion is there is minimal value there and not enough for someone to recover.....but we all know how opinions are
  23. #15
    kss's Avatar
    May 2019
    PA
    839
    465
    Lol that very well may be case.
    1. what things have you found in things you have taken apart and resold?
      By mike1 in forum A Day in the Life of a Scrapper
      Last Post: 01-15-2019, 02:19 PM
    2. Things are looking up!
      By pjost in forum A Day in the Life of a Scrapper
      Last Post: 03-14-2015, 08:42 PM
    3. Anybody ever come across one of these things?
      By bdog6000 in forum Scrap Metal Tips and Advice
      Last Post: 01-04-2013, 02:59 PM
    4. things that P me off
      Last Post: 02-26-2012, 09:34 PM
    5. Looks Like Things Are Looking Up!
      By skylinejack in forum A Day in the Life of a Scrapper
      Last Post: 11-13-2011, 03:19 PM
