Results 1 to 20 of 29
My scale Vs the scrap yard scale??
| Scrap Business Ethics
    mx842 started this thread.
    mx842's Avatar
    Feb 2021
    Richmond Va
    I have been scraping for a long time. Just small scale not like some of you guys. I might pick up a couple tons of iron and tin scrap every couple months or so and pile it up until I run out of room or just need some cash. I don't weigh this material before I carry it in but I do weigh all my copper, brass, alum cans and other things that bring more money. I have taken scrap to pretty much every scrap yard in town at one time or another and after a few years I figured out which ones treated me the best and they were the ones that got my scrap.
    I don't have to tell any of you about how hard you have to work to pick up, sort, store materials then haul them in for what you get out of it in the end. I have a certified electronic scale that will weigh up to 200 lbs that I weigh my copper, brass and other big ticket items on before it goes into 55 gal. drums and sealed once they are full. Sometimes it might take me 6 months to a year to get a full barrel of stripped romex and then I would sit on it until the price went up enough to cash in.
    Over the past 5 years I have been using the same place because they always treated me fair in the past. Well it was about Christmas time and I needed some cash to get my wife some Christmas gifts and I had one barrel of stripped romex that had 255 lbs in it and it was just under 3/4 full. I ran my wire stripper for a day and a half to level off the barrel but I got in a hurry and didn't weigh that extra wire because I just figured it was holding right at 300 lbs like they usually do with the barrel topped off and tightly packed with 14 to 8 ga solid wire. I knew there was 255 lbs already in the barrel before I topped it off and that was enough for what I needed to do and the top off would be some cream on top. I don't usually sell my copper wire when it's under $3.00 but it was Christmas and I needed the cash and at $2.90 lb I figured it was close enough.
    For all those years the same two guys were at the scale when I pulled up but this time there was another guy there working the scale. Normally I would roll the barrel off the tail gate and roll it over to the scale but they insisted I dump it into this large medal container that the fork truck pulled up to the back of the truck. I thought about it for a second but I was busy throwing off some insulated alum wire into another container and before I knew it they had dumped the whole barrel of wire into their steel container and put it on the scale. They have two smaller scales there and one had my insulated alu wire on it and the other had my copper. The weights flashed on the screen but it was the container weights with material total and happened so fast I and before I knew it everything was gone and the guy came over with my ticket and said please move away from the scale so these other people can weigh in. I pulled off and went to the window and the guy handed me a wad of cash and yelled next please. I was out of the building before I even counted the money and when I did I knew I had been had. They paid me for 205 lbs of #1 bright copper and when I went back in to question it all they would say is that they have certified scales and there was nothing they can do. My problem was that I didn't know the exact amount because I didn't weigh what I topped the barrel off with but I knew I had 255 lbs in there before the top off as if that would have made any difference anyway.
    I never have liked to dump my stuff into those containers that they haul up for you to put stuff in. once it's in there you have nothing to go on and are at their mercy. I know there can be small differences in how stuff is weighed I always figure a +/- 10 lbs one way or the other but this was almost 100 lbs. I still ain't got over that one yet. How do you keep those guys honest or is it even possible?
    Apr 2015
    2,177
    633
    Tell the scale guy to load it back onto your truck then go to another yard.
  3. The Following 2 Users say Thank You for This Post by alloy2:
    Apr 2015
    2,177
    633
    Quote Originally Posted by mx842 View Post
    Each of those containers should display theor tare weight, if your in doubt of the accuracy ask the scale man to pr-weigh the bin.
    hills's Avatar
    Sep 2017
    1,554
    829
    I put my copper up in 50 lb boxes.
    Let's say the tare weight is .75 lbs for the box.
    The total weight will be 50.75 lbs on my scale. The outside of the box is labeled 50 lbs copper.
    Anyhow ... this doesn't give them any wiggle room for cheating at the scale.
    I usually use a 12x12x12 box for #2 and a 12x12x6 box for bare bright. It hardly takes up any space in the shop in case i want to sit on it for awhile till the prices go up.
  6. The Following 2 Users say Thank You for This Post by hills:
    mx842's Avatar
    Feb 2021
    Richmond Va
    Like I said this was the first time I ever had a problem with these guys that I know of. Their weights and mine have always been within a few lbs. This time I dropped the ball a little by letting them rush me up. I had a couple hundred lbs of insulated alum wire and a barrel of # 2 copper. I had already dropped the barrel of #2 at the scales and wanted to unload the alum wire and then last the #1 bright. While I was throwing the insulated wire into their bin box a couple of guys jumped up into the truck and rolled the #1 into the metal box and dumped it. It all happened pretty quick an before I knew it the guy handed me a ticket and asked me to move out of the way. I didn't even realize what had happened until I counted my money. Of-course by then it was too late all my stuff was mixed up with theirs and all I heard was how their scales were so certified.
    4,985
    1,257
    I know this may not help or make you feel any better but I try to figure out when the busy times are and avoid those if I can
  9. The Following 3 Users say Thank You for This Post by mikeinreco:
    mx842's Avatar
    Feb 2021
    Richmond Va
    I have the tare wt of my barrel written on the top of the lid. I also write in magic marker on the lid each time I add wire to the container. When it's time to take it in I add up the weights and put the total on top with the weight of wire and also the total weight of everything. I like the barrel thing because I can add wire then reseal the barrel without worrying about it becoming tarnished, been there done that. Also the barrels are so easy to store. I may have to add another stage to my processing and do something like you do with the boxes. Once a barrel is full and the price is right remove it from the barrel and put it into 50lb boxes and put it into the truck. That way if I don't like the weight It would be easier to throw 50 lb boxes back into the truck than try a get a 350lb barrel back into the truck or trailer. thanks for the idea.
    mx842's Avatar
    Feb 2021
    Richmond Va
    I've tried that but it's a pretty hard nut to crack. I've been there all hours of the day and it seems like everybody is just like me and decides to go in at the same time.LOL
  12. The Following User Says Thank You to mx842 for This Post:
    mx842's Avatar
    Feb 2021
    Richmond Va
    Oh...You can get 50 lbs of bare bright in a 12x12x6 box?? How do you manage that?
    mx842's Avatar
    Feb 2021
    Richmond Va
    Good luck with that around here.
    Apr 2015
    2,177
    633
    Is your scale certified " legal for trade"
    It is also important to know where you plan to place the scale. A scale needs a solid, level surface so information on placement location helps the installation process. If a scale is moved to a different location, the scale’s calibration should be checked so a report can be sent to the county stating that the scale is within tolerance.
    If you have a legal for trade scale it is important to have the scale periodically checked for accuracy. Depending on how inaccurate a scale is, upon county inspection, the scale could be tagged and taken out of service.
    In the event of this, the scale must be repaired or recalibrated within a certain period of time. Once the scale is back intolerance a report will be sent to the county and the scale can be used again. Because of situations like this, it is important to have a reliable scale company that will get your scale back in service to avoid the scale being down for a long period of time.
    For more information regarding your weighing needs, contact Quality Scales Unlimited.
    hills's Avatar
    Sep 2017
    1,554
    829
    It comes out of my stripping machine straight. I feed it into an 11 1/2" jig and cut to length. All the individual pieces fit tight together in that little box. Admittedly, it's a bit of extra work, but everything is well organized when you get to the scale.
    Oddly enough ... that 12 x 12 x 6 box fits 50 lbs of brass as well. I ran seven boxes to the yard recently. It was a very smooth n easy process. No hassles about weight or the quality of the brass. The scale guy was happy, i was happy with a quick payout ... it was a good day for everybody.
    mx842's Avatar
    Feb 2021
    Richmond Va
    I don't use my scale to weigh items for public sale. It's a mail/freight type scale that I bought when I was doing a lot of shipping at my work. I started using it a long time ago because there were a couple places around here that were really crooks and were ripping people off left and right. Thankfully enough people complained and they shut then down. Frankly it shouldn't matter what you weigh the material on. I used regular bathroom scales for a long time and they were close enough to get a basic feeling for what you have in a box or barrel. It's easy enough to check a scale by placing a known amount of weight on the scale an seeing what it reads. That should give good enough results for what I now use it for.
    Like I said as long as the weight at their scale is within a reasonable amount I don't usually fuss but 100 lbs is a little much that's 1/3rd of what was in the barrel. For years my weight and theirs were within a couple lbs one way or the other using the same setup. And yes I have checked my scale. I have 5, 5lb stainless steel bars that I use to check the scale it reads dead on 25 lbs every time I check it. I hardly ever add copper to a barrel at more than 25lbs @a time so I figure that should give me a dang good idea to what's in a barrel when it's full.
    Apr 2015
    2,177
    633
    WTF, get it straight. Your using your bathroom scale to compare weight to a scale which is regulated under the weights and measures act.
    hills's Avatar
    Sep 2017
    1,554
    829
    Dude ... chill out. It's not a big deal.
    Lol ... take it from a guy that obsesses over the little unimportant things.
    You know ... like figuring out how to stuff 50 lbs of BB into a 12x12x6 box ???
    (In the grand scheme of G-d and the cosmos it's really not all that important.)
  20. #16
    mx842's Avatar
    Feb 2021
    Richmond Va
    ''Frankly it shouldn't matter what you weigh the material on. I used regular bathroom scales for a long time and they were close enough to get a basic feeling for what you have in a box or barrel''
    Wow......That was a prime example of someone taking a sentence out of context there ol buddy. LOL
  21. #17
    mx842's Avatar
    Feb 2021
    Richmond Va
    Thanks, you are right I'm done with this one.
  22. #18
    Apr 2015
    2,177
    633
    Next time search the archived threads there are hundreds of posts regarding scales.
    https://www.scrapmetalforum.com/gsea...&sa.x=0&sa.y=0
  23. #19
    I find my little hanging scales ( with a spring inside them ) are pretty accurate to give me a good idea if I am over a certain weight.
    Like they weigh up to 12 Kgs. I put my metal into plastic material seed sacks & if the weights over 12 Kgs, I use the scales on one corner of the sack & hang the other corner up using my other hand, and then double what's on the scale.
    I used bathroom scales for my bigger sack fulls & they got filled up to 50Kgs of #2 Copper wire, and once accurately weighed at the scrapmetal buyers yard, they were ~ 55Kgs.
    I try to use as less amount of packing, boxes, sacks, tubs etc as possible.
    Sacks are best for me, they hold as much as I can carry, they are tallish & take up less floor area, they are cheap & they cover everything inside from what's outside, including other peoples eyes.
    Scrapmetal buyers trying to rush you, moving your stuff ( It's not theirs yet !!!! ) & getting into/ onto your vehicle without your permission is not a good sign. Any more than one worker at once is also a warning sign.
    It took me ages to figure out that I was getting ripped off at one scrap buyers, same description of what was happening as the OP did. Consistently their weighs were lower than mine.
    Then in time I started to notice a few consistencys of what was happening.
    So I started going to a well known company's scrapyard & never had any problems since.
    It was sorta strange that I hadn't gone there that often, they were a lot closer, but not locally owned, I was all about "Support the Local company" like a lot of us were.
    In the end I suspect that as their scale was outside, they had somebody inside the building poking a crowbar/lever thru a hole in the wall & lifting up the scale. Weird body language by the scale master coinciding with odd fluctuations in scale weight ( " it's the wind " ) & a odd directive not to be near the buildings open door ( where I could see inside ) while the scale master stood there, was what bought me to this conclusion.
    Going to a internationally owned big company is best. Best prices most of the time & high business standards mean that it's tougher to fudge any numbers in the books. And less of a reason to. It will get found out in time.
    I think the OP did get ' shorted ' in weight. Take it as a learning experience.
    If you lend somebody $20 & you never see them again, it was good investment.
  24. The Following 2 Users say Thank You for This Post by eesakiwi:
  25. #20
    4,758
    6,039
    I had a yard messing with tare weight for 5 gal buckets of scrap. Buckets weigh 2 lb they were saying 4 lb. Next bucket I dumped on to small scale and stated no tare weight, lol...
    Better than the dump!
  26. The Following User Says Thank You to hobo finds for This Post:
    1. Huge Scrap Load, cant get across scale, not mine sadly
      By ozzy214 in forum A Day in the Life of a Scrapper
      Last Post: 01-28-2015, 06:37 PM
    2. Scrap yard scale accuracy
      By sdakscrapper in forum Scrap Metal Questions and Answers
      Last Post: 05-12-2014, 08:35 PM
    3. Scale?
      By roboutlaw in forum Tools and Equipment
      Last Post: 03-26-2014, 03:12 AM
    4. need scrap on a small scale
      By Steampunker in forum General - Let's talk business
      Last Post: 01-04-2013, 10:46 PM
    5. How accurately does your yard's scale weigh?
      Last Post: 10-16-2012, 12:21 PM
