Results 1 to 18 of 18
Extension cords
| Scrap Metal Tips and Advice
    mike1 started this thread.
    mike1's Avatar
    Rochester indiana
    620
    322
    Extension cords
    Hi my yard buys extension cords as #3 if I took the outer jacket off and just had the 3 wires inside would I get #2 or #1 insulated or will it still be #3? I don't wanna start and then have it just be num 3 still. The wires inside will be 16awg to 12awg. I know to keep thhn sperate. Another question does the wires inside extension cords become thhn? Thanks.
    CopperMiner's Avatar
    Jun 2021
    Greater Montreal
    320
    181
    If you remove the outer jacket, it should be insulated wire #2. If they still see it as #3, I would keep it and sell it elsewhere.
    NEW TO SCRAPPING? READ THIS: Build up your horde of magnetic and non-magnetic metals in two piles until you have a better understanding of the business. Magnetic material has low value and is mostly always steel / shred / short iron. Read old threads about non-magnetic metals and ewaste (and how to sort them), but don't forget that they generally have absolutely no tolerance for contamination (screw / iron / foreign material).
  3. The Following 2 Users say Thank You for This Post by CopperMiner:
    mike1's Avatar
    Rochester indiana
    620
    322
    Quote Originally Posted by CopperMiner View Post
    I should make a little more I think num 2 is still going for .70 thanks. I no they count thhn as num 1 insulated so I might get lucky and give me num 1 insulated maybe I'm not sure they do like me so that will help possibly.
    mike1's Avatar
    Rochester indiana
    620
    322
    Oh on another note strip meister does not like stripping thhn they need a smaller hole for it. I'm not even going to try 16awg I tried to do thhn 12awg funny it does solid 12awg from romex just fine it doesn't slip with that I'm not sure why .
    4,758
    6,037
    By me if you cut off the ends it's #2
    Better than the dump!
    Jun 2021
    Greater Montreal
    320
    181
    A rule of thumb given by a scale guy at one of my yards: insulated copper wire #1 is bigger than #2 and it is usually hard to bent. It is mostly made of the industrial / commercial / heavy duty stuff. Pretty much everything else is #2, except for the well known exceptions with too much insulation or foreign material, such as Christmas lights (#3),
    hills's Avatar
    Sep 2017
    1,509
    820
    I think i would run the numbers to see if it's worth doing.
    Weigh up 5 lbs. of extension cords and figure out what you would get for them un-stripped.
    Next .... strip them out and see what the wire inside is worth.
    I'm thinking it might not be worth the extra time & effort. My guess is that they're paying you for the copper that's inside.
    You don't gain any more copper by stripping the outer jacket off an extension cord.
  9. The Following 5 Users say Thank You for This Post by hills:
    1,905
    1,667
    Agreed, i say sell as is and get paid for the jacket weight instead getting nothing for it by tossing it in the trash and focus on finding / breaking down higher quality scrap.
  11. The Following 3 Users say Thank You for This Post by greytruck:
    mike1's Avatar
    Rochester indiana
    620
    322
    I'll try the 5 lb experiment and post results.
    My thought is perhaps cut the plugs and sell as is then use saved time to expand your business. After a certain amount of time you will see its often better to locate more sources of material than spend time squeezing the last penny from what you have. 73, Mike
  14. The Following 4 Users say Thank You for This Post by miked:
    Jun 2021
    Greater Montreal
    320
    181
    By the way, are your extension cords in very bad condition? If they're salvageable, try to resell them. Plausible to get more money that way. Brand new ones costs an arm and a leg.
  16. The Following 4 Users say Thank You for This Post by CopperMiner:
    hills's Avatar
    Sep 2017
    1,509
    820
    The 10 ga. & 12 ga. extension cords do get my attention because they are so expensive to buy new. The cheapo 16 ga. & 18 ga. cords aren't worth bothering with.
    You've got to be really careful though. A cord can look perfectly fine on the outside and have rotten wires inside. I've seen that on more than a few occasions. You can use a ohm meter to check the wires inside for continuity but there's no way to check and see if the cord's amperage carrying capacity is still what it is rated for.
    When in doubt .... scrap it out.
  18. #13
    mike1's Avatar
    Rochester indiana
    620
    322
    I once sold a cast iron pan for 10$ I found in a stove I scrapped haha. Don't know about selling extention cords though.
  19. #14
    pappawheelie's Avatar
    WI
    94
    69
    Quote Originally Posted by mike1 View Post
    You don't need to strip 5 #, you can just strip a foot, use a postal scale that measures in grams to get your recovery percentage.
  20. #15
    mike1's Avatar
    Rochester indiana
    620
    322
    Oh ok. Extension cords now go as num 2 insulated for 1$ a pound I don't strip any wire that's not 14awg and lower by lower I mean 12 ,10 and so on I don't strip 16awg and above.
  21. #16
    t00nces2's Avatar
    Jul 2014
    Sarasota, FL
    1,707
    1,191
    I have sold them. They are a bit of a hard sell. They will sit on the shelf a while, but I still find it hard to throw a 50ft 12 AWG cord into the scrap bin.
  22. #17
    mike1's Avatar
    Rochester indiana
    620
    322
    Quote Originally Posted by t00nces2 View Post
    Most I have seen are what people have called cheap 16 and 18awg cords haha.
  23. #18
    t00nces2's Avatar
    Jul 2014
    Sarasota, FL
    1,707
    1,191
    Take my word, 3 wire 12 AWG 100ft
    https://www.facebook.com/marketplace...81002472165711 ....
  24. The Following User Says Thank You to t00nces2 for This Post:
    1. $0.60 a pound for extension cords ?
      By redcrossnj in forum Scrap Metal Tips and Advice
      Last Post: 09-01-2013, 02:30 PM
    2. Extension cord blues
      By ParkerFlyer4 in forum Scrap Metal Tips and Advice
      Last Post: 09-24-2012, 12:20 PM
    3. Extension Cords
      By TexasDeere in forum Scrap Metal Questions and Answers
      Last Post: 08-02-2012, 10:05 PM
    4. An extension cord can go a long way
      By admin in forum More than Scrap Value
      Last Post: 07-15-2012, 11:12 PM
    5. Should I strip insulation off extension cords
      By firefighter57 in forum Non ferrous metal recycling
      Last Post: 04-04-2011, 09:21 PM
