Results 1 to 19 of 19
Hard drive value: complete vs. commodity
    takenbyvultures started this thread.
    takenbyvultures's Avatar
    Southern California
    21
    Hello all, I have a quick question: Do scrappers typically pay higher prices for complete hard drives or should I disassemble and distribute in commodity bins?
    Thank you very much, this is a great forum!
    If you have quite a few, then break them down for max value, but if you only have a few you might just sell them to an escrapper or buyer of escrap.
    The circuit boards are worth $10-11 per lb, and the tops are usually stainless and the bottoms are cast alum. There is even buyers for the super magnets.
    The going rate is around .85 lb. for whole ones.
  3. The Following User Says Thank You to Mechanic688 for This Post:
    Ballymoss's Avatar
    Leeds, United Kingdom
    71
    11
    My local yard pays 20p per Kilo whole or 70p per Kilo broken apart.
  5. The Following User Says Thank You to Ballymoss for This Post:
    3,392
    993
    IF they are 80GB or more then are worth more if you sell them on ebay.
  7. The Following User Says Thank You to PartTimeScrapper for This Post:
    Southern California
    21
    Thanks for the tips, I actually sell on ebay primarily. Even HD's less than 80GB will sell for good money. 2.5" IDE's are making a huge comeback lately. I have adapters to test each hard drive, if they work then they are listed on ebay, but I have some bad HD's piling up. So say I have 50 laptop hard drives, (weigh approx 5oz each), would it be worth more to sell them complete or pull the logic boards and sell separately, then divide the remaining commodities. Thanks again to everyone.
    3,392
    993
    You always make more the more you seperate. In most cases anyway. best thing to do is tear one down and weigh it out and see for yourself then you will know.
    Southern California
    21
    I actually don't have a buyer for scrap yet, that's why I was wondering how much I should break it down. After the first haul, I should have a better idea.
    There's some ewaste buyer's listed here, a few post regularly, and some have their pricesheets listed. You can go back thru some posts and find some recommendations for some of the buyers.
  12. The Following User Says Thank You to Mechanic688 for This Post:
    Southern California
    21
    Thanks a lot for the link, I'm hoping to do a lot more scrapping soon. I just picked up a Dodge 3500 Cargo Van to load up.
    2,417
    664
    Quote Originally Posted by takenbyvultures View Post
    Question for you if I may. I just snagged a mess of hard drives that I am tearing down. I pulled a few that I would rather sell than break down. What exactly do you have to test these with? I pulled a WD 80 gig, a WD 160 gig and a WD caviar green 500 gig that I want to test. I figure I can just sell them as is, but would rather say that I tested them and erased them or something along those lines.
    Thanks in advance.
  15. The Following User Says Thank You to parrothead for This Post:
  16. #11
    Southern California
    21
    The easiest way is to pick up a USB hard drive adapter from ebay or frys. They will connect to 2.5 SATA, 3.5 SATA. 2.5 IDE, and 3.5 IDE which are basically all of the basic hard drives that come in consumer electronics. You wont be able to use it with SCSI, Fibre Channel, or SAS from servers and such. You basically hook the hard drive up to the adapter then plug the usb into the computer you're using, if the hard drive spools up thats a good sign, then your computer should recognize the hardware connected and it'll pop up in "my computer" as a storage device. You can right click and select format and reformat the drive so it can be reused. This will wipe just fine, not to DOD standards or anything. If the hard drive makes a buzzing noise, you hear the arm clicking on the platter or it doesn't spool up, then chances are the drive is bad and should be scrapped. Just search "usb hard drive adapter" on ebay and find a kit. Hope this helps.
  17. The Following 4 Users say Thank You for This Post by takenbyvultures:
    2,417
    664
    It helps a bunch! Thanks!. I just bought this.
    http://www.ebay.com/itm/300582905564...84.m1497.l2649
    966
    615
    Keep in mind there is a chance the hard drive could be failing and still read via that device. Only for sure method is to run a full hard drive diagnostic. There may be some free software available online, never really looked.
    Specializing in Maximum value for mixed precious metal printed circuit boards and electronics
    Check out our pricing and read some of our RAVING reviews: http://www.scrapmetalforum.com/scrap...tal-scrap.html
    QUESTIONS? Email us: info@CashForComputerScrap.com
    or Chat with us: www.CashForComputerScrap.com
  20. The Following 2 Users say Thank You for This Post by Ewasted:
  21. #14
    2,417
    664
    Yeah, I want to do that as well. I plan on offering a gaurantee of some sort like I have seen on some of the hard drive auctions I saw.
  22. #15
    Southern California
    21
    Also, I've come across a lot that won't pop up when connected to adapter so they appear to be bad, but I went through disk management and they had lots of partitions and volumes on the drive so for some reason they won't be recognized. On windows 7 just go to start and in the search bar type disk management and it will open, then you can right click and delete volumes/partitions, the create new volume and click through the steps and I've fixed lots of HD's that way that appear bad at first glance.
  23. #16
    3,392
    993
    Quote Originally Posted by parrothead View Post
    Thats the one I use. as far as checking the drives I download the drive tools from manufactures website and run the system test for the drives.
  24. #17
    3,392
    993
    I always use disk management first to do exactly that as well. Delete all partitions make a new single one do a format then a diognostic.
  25. The Following User Says Thank You to PartTimeScrapper for This Post:
  26. #18
    2,417
    664
    Great information here guys! Thanks!
  27. #19
    http://www.scrapmetalforum.com/showt...ar-suggestions Have you read this yet, I'd like to know a little more before I start selling.
    1. Hard Drive Value
      Last Post: 11-13-2013, 06:45 PM
    2. Hard Drive Erase Software. Requirements For Selling Hard Drives
      Last Post: 08-23-2013, 01:30 AM
    3. Hard Drive Destruction
      By MvPElectronicRecycling in forum Computer Recycling
      Last Post: 07-02-2013, 11:09 AM
    4. Breaking down a Hard Drive
      By drozenski in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 06-22-2012, 09:36 AM
    5. Hard Drive Details Please...
      By wayne in forum General Electronics Recycling
      Last Post: 01-08-2012, 04:30 AM
