Results 1 to 9 of 9
Breaking down a Hard Drive
    drozenski started this thread.
    Rochester NY
    615
    19
    Step by step guide on how to break down a hard drive and maximize your profits.
    Time per drive - 5 - 10 minutes. Faster once you have done a few.
    This is what we will be taking apart a western digital 40GB hard drive.
    First take off the board from the bottom of the drive. Throw this into your hard drive board box. They are typically 2-3 times more than mother board grade.
    Next Find all the screws on the top of the drive. Notice how two were hidden under the label. Some drives will have none others will have up to 5. If the top will not easily come off look for additional screws.
    Test the top of the drive. I am usually 50/50 for the tops. Some are steel and others are alum. Check with your magnet to make sure. This particular top ended up being alum.
    Next remove all screws from the inside of the drive.
    Place the various parts into their respective piles.
    Each part can be broken down further into more refined piles.
    The copper can be removed from the arm, the wire removed, and the connector to the board removed, and the arm itself can be added to your alum pile.
    Sell the platters on Ebay.
    Next test the piece of metal holding down the platter. They are often alum but can be steel. This case the piece was steel.
    Once done your drive will look like this. My yard tells me to leave the motors in as they take them as Alum. Once this is done i throw them in my Alum pile and onto the next drive.
  2. The Following 9 Users say Thank You for This Post by drozenski:
    3,400
    1,004
    You should spark test the top. They are most of the time stainless not alluminum. Graet post overall though keep up the good work.
    May 2012
    central florida
    139
    How do you do a spark test? I searched but didn't see anything relevant.
    BroJer's Avatar
    Phoenix-West Valley
    1,004
    3,210
    Quote Originally Posted by jaydee1445 View Post
    hit it with a grinder. if sparks fly...it is SS
    waredu's Avatar
    309
    95
    Top is generally stainless, not aluminum. If a magnet picks it up, there is a steel piece glued to a stainless backing - grab two pairs of pliers, wear your gloves and PUUULLLLL.
  7. The Following User Says Thank You to waredu for This Post:
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    Well least now I know how to remove it all and what to expect since I have one just like this.
    May 2012
    Sebring, FL
    62
    Not sure how much your yard pays for aluminum, but if you took out the motor wouldn't you get a higher price for the electric motor?
    Also, the magnets inside the drives can be dangerous - hard to pull apart and will pinch your fingers real bad if you're not careful. But they can be sold on ebay as well in lots.
    Quote Originally Posted by drozenski
    Sell the platters on ebay
    Be sure if there is data on the drive that wasn't wiped, that you scratch or break the platters first before selling them. Data can still be recovered from an individual platter from those who really want the data for identity theft or fraud. Plus people will buy them on ebay because they think they are loaded with a platinum coating, but it would take thousands of them to make it worthwhile with the amount of chemicals and such you need to recover the platinum.
    Quote Originally Posted by AJR View Post
    Electric motors usually only get around .25-.28 a lb. might as well leave it in if they'll buy it that way, makes more weight. Also the little "washers" on top and in between the platters, the top one is usually stainless and the thicker ones are alum. It all adds up if your breaking them down this far.
  11. The Following 2 Users say Thank You for This Post by Mechanic688:
    waredu's Avatar
    309
    95
    If the platters are just scratched or broken, data can still be read off the platter - it's just far more difficult.
    I throw the magnets and the platters in a single tub. About once a week I shake them around. After a month or so of that, not even a lab tech in a white coat and a cleanroom would be able to get anything off the platter. They're completely degaussed.
  13. The Following 5 Users say Thank You for This Post by waredu:
    1. Breaking Down a 5" Hard Drive
      By Mechanic688 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 03-01-2014, 11:36 PM
    2. Hard Drive Value
      Last Post: 11-13-2013, 09:45 PM
    3. Hard Drive Erase Software. Requirements For Selling Hard Drives
      Last Post: 08-23-2013, 04:30 AM
    4. Hard drive platters??
      By Bryank930 in forum General Electronics Recycling
      Last Post: 09-07-2012, 11:05 PM
    5. Hard Drive Part Help
      By CMI in forum General Electronics Recycling
      Last Post: 05-18-2012, 03:12 AM
