Results 1 to 15 of 15
Electric Motor Copper Windings
    Pronto Hauling started this thread.
    Pronto Hauling's Avatar
    Northern California
    17
    21
    Question Electric Motor Copper Windings
    I just finished removing all the copper from a mess of refer compressors I had laying around. All the copper is nice and clean looking but has varnish on it. My question is will I get at least #2 copper price for it with the varnish intact? I broke all the pieces up real good so they're not all clumped together. I also made sure no plastic, paper, string or other waste got mixed in. I've heard some people say I can get bright and shiny price for it, others say #2, i,ve also heard its priced the same as insulated wire. Is there a way to remove the varnish w/o burning. I don't like the idea of burning it and letting off a bunch of smoke and fumes. :confused:
    You should get #2 for it. No on the bare bright. If it's clear varnish it might go for #1 but I doubt it.
    sjones99's Avatar
    iowa
    266
    26
    Motor windings are #2
    jonnyjeb's Avatar
    Long Island NY
    167
    90
    How about copper dagausser and copper from the tv yokes?
    wavecrazed's Avatar
    219
    Tv wires copper pure is number 2. I think number 1 would have to be thicker than a pencil lead.
  6. The Following 2 Users say Thank You for This Post by wavecrazed:
    boise, ID
    1,605
    469
    Here they grade motor windings as field copper because of the varnish. I get about 10 cents less than #2 price for it.
    little726's Avatar
    74
    1,377
    It's considered #2 at my yard.
    If you burn it, it just might become brittle and turn to dust.
  9. The Following User Says Thank You to little726 for This Post:
    15,631
    If they offer you less than the full #2 price consider finding a new place to sell to. I mean take your copper off the scale and walk away. Mike.
  11. The Following 2 Users say Thank You for This Post by miked:
    boise, ID
    1,605
    469
    I wonder if it would be worth the extra time to clean it up enough to make #2.
    sjones99's Avatar
    iowa
    266
    26
    Its the varnish that makes it #2...no matter what diameter
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    I wonder if sitting the wire in a container of nail polish remover would help take off the varnish.
  15. The Following User Says Thank You to Scrapette for This Post:
    15,631
    "I wonder if sitting in a container of nail polish remover would help take off the varnish." Yes, nail polish remover is acetone and will remove the varnish. It will only satisfy your couriosity, it will not get you paid any more for your copper. Mike.
  17. The Following 3 Users say Thank You for This Post by miked:
  18. #13
    Northern California
    17
    21
    I just got back from the yard and I screwed myself. There were a few motors in the lot that were aluminum copper coated windings. I haven't dealt with alot of copper and I thought it was white copper on the inside coated with normal copper. So I got #3 instead of #2, which it would have been if I had separated the two...guess I learned that one the hard way....won't be doing that again.
  19. The Following User Says Thank You to Pronto Hauling for This Post:
  20. #14
    15,631
    Many of us have done the same thing. Even when you know about the copper plated Al wire you can make mistakes. As an example I was working without a good light and mixed some Al windings in with my #2 copper. The guy at my yard helped me pick it out. I'm not kidding, he helped me. I really like the yard I sell to, Mike.
  21. #15
    [QUOTE=Pronto Hauling;35911] There were a few motors in the lot that were aluminum copper coated windings. I haven't dealt with alot of copper and I thought it was white copper on the inside coated with normal copper. So I got #3 instead of #2,
    Bugger.. When I take them apart I pick all the plastic & string off, but I try & pull out the big loops whole & then get a strand in that loop (' U ' shape) & tie that around it so it stays whole.
    Looks like a 'Frank Zappa' mo'.
    I get #2 price for it. If I stripped of the varnish off I'd get another 50cents per Kg.
    That'd need solvents & I would not recommend anyone else doing it at all. Please don't do it.
    Ok, I would.... Just to do the math on it & figure out whats needed & how.
    Then maybe I'd post everything here. I have a few other things I'd do first though. Such as destructive distillation of plastic coated copper wire.
    I have only found Ali wire once or twice.
    Unfortunately it was early on in my scrapping experience & from then on I thought it was common & dismissed it as not worth the time. Probably lost hundreds of $$, maybe over $1000...
    It was mixed Copper/Ali too, probably a Aircon pump.
    Since then I have not seen Ali windings at all. Weird. Its easy to notice once you find it a few times.
    I have washed the oil coated fridge copper wire with the used dishwasher waste water once. It made it nicer to touch.
  22. The Following User Says Thank You to eesakiwi for This Post:
    1. Breaking down an electric motor for copper
      By PartTimeScrapper in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 02-19-2019, 01:23 PM
    2. Electric motor
      By Mick in forum A Day in the Life of a Scrapper
      Last Post: 10-27-2012, 06:06 PM
    3. Aluminum windings versus copper windings
      By kbob in forum Scrap Metal Tips and Advice
      Last Post: 04-28-2012, 11:25 PM
    4. electric motor copper
      By devo in forum Scrap Metal Questions and Answers
      Last Post: 02-11-2012, 12:46 AM
    5. Motor windings
      By ozzy214 in forum Scrap Metal Tips and Advice
      Last Post: 10-24-2011, 07:28 PM
