Results 1 to 20 of 28
Uninterruptible power supply
    Scrapette started this thread.
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    Got an uninterruptible power supply from a dumpster dive. Does anyone know if this thing stores a charge and is it safe to break down? Thanks in advance for replies.
    Should be just some tiny lawn mower type(sealed) batteries inside, plus other electronics, circuit board. Lots of different types, should not be any charge to it, the batteries probably went dead/shorted. You could use a volt meter and test them, but that's the most common cause.
  3. The Following User Says Thank You to Mechanic688 for This Post:
    South africa
    28
    ups is great for breakdown, open it up and disconnect the batteries. its all safe from there.
    if the unit still switches on but dosent run with a load it could just be the battery's.
    scrap the old ones , replace the battery's and sell the unit if you want.
    otherwise is breaks down to battery, aluminium, nice transformer, low grade PCB and some PVC wire.
  5. The Following User Says Thank You to goldfinger for This Post:
    15,631
    The ones I broke down had a fair amount of brass. Mike
  7. The Following 2 Users say Thank You for This Post by miked:
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    Thanks, Mechanic, goldfinger and Miked - it is so good to have people you can turn to with questions - particularly when they are related to safety. You guys rock!
  9. The Following User Says Thank You to Scrapette for This Post:
    You guys rock!
    Are you talking like this,,
    Or like this,,
  11. The Following 3 Users say Thank You for This Post by Mechanic688:
  12. #7
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    Number one.
    But if you are a very careful scrapper and take good care of yourself, you may make it to your retirement rocking chair someday! Lol.
  13. The Following 3 Users say Thank You for This Post by Scrapette:
  14. #8
    ScrapperNJ26's Avatar
    Clementon NJ
    512
    537
    Just keep in mind to have something close by in case the batteries are leaking so it doesn't destroy the floor.
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    Quote Originally Posted by ScrapperNJ26 View Post
    Thanks for that. I just put down that peel and stick beauty of a floor and I would hate to have to repair it already!
  16. The Following User Says Thank You to Scrapette for This Post:
  17. #10
    Quote Originally Posted by Scrapette View Post
    Number one.
    With winter setting in I no longer rock, at this point I just creak.
  18. The Following 2 Users say Thank You for This Post by injunjoe:
  19. #11
    Clementon NJ
    512
    537
    A piece of plywood works well as long as it's a piece you don't need.
  20. #12
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    That's a great idea, as it happens, I have some spare plywood. Thanks again.
  21. #13
    I think you can use the 12V DC to 110? -240? volt part as a inverter.
  22. The Following User Says Thank You to eesakiwi for This Post:
  23. #14
    Ecycle Atlanta's Avatar
    Outside Atlanta
    734
    291
    Just got in couple dozen of these. They are sweet to break down. Battery about 5 lbs @ $0.30 lb, plus board that has some alum that pops off and a small transformer. I think mid-grade after i remove those but not sure yet. Add in cords and snippets of wire, should get a nice little return on them. Still stockpiling my transformers and havent taken them in yet, so not sure what they are bringing at the yard. All the units were tested and not working so i'm not gonna bother with the repair and try to resell option.
  24. The Following User Says Thank You to Ecycle Atlanta for This Post:
  25. #15
    CT
    Just to toss in my 2 cents as an IT person, just about any working UPS is worth more resold with a fresh set of batteries than as scrap. You can find OEM and third-party batteries for just about any UPS ever made. If you have a few identical units, some small local business will probably love to take them off your hands. If a battery doesn't slide out easily, grab some gloves, goggles, and something to protect the floor because it's bulging any may blow up when you remove it (I'm sure most people here know to be careful with lead-acid batteries, but it can't hurt to mention it.)
  26. The Following 2 Users say Thank You for This Post by IanH84:
  27. #16
    goulais river ontario CANADA
    usually there is a battery set internally in the unit ,which like all things ,stopps holding a charge ,which costs (most of the time )more than the unit itself
  28. The Following User Says Thank You to kartowing for This Post:
  29. #17
    ks
    2,187
    2,513
    Quote Originally Posted by shendog View Post
    You break the transformer down or what ? Yards buy transformers as is, and if so what's the going rate ?
  30. The Following User Says Thank You to taterjuice for This Post:
  31. #18
    Outside Atlanta
    734
    291
    I dont break down the transformer. The ones i get have the EI inserts, so i cant easily break them open like jackschmuc shows in his videos. It would also waste a $1.99 cutoff disk if i tried to cut them, and i dont have a band saw. I took a few in to the local yards and i think one wanted to give me $0.20 for them as motor. Another yard first said they wouldnt take them with the steel, but then offered 0.12 lb. anyway. I laughed and said no thanks. Wished i had a local yard that knows a bit more than how to crush a car, but i'm working on educating the ones i do have. All good guys, just not outside the box thinkers (yet). My biggest problem now is finding a buyer for my power supplies. Have a guy 1.5 hours north that will pay .25-.31 per pound for them with wires attached. I dont feel like driving that far, but seems i have to as my local guys look at them funny and want to pay me shred price. I have almost a pickup truck load so maybe i need to make the drive.
  32. The Following User Says Thank You to Ecycle Atlanta for This Post:
  33. #19
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    I took in a battery pack from one of these last week. I got $36! $12 a pound. It was a pleasant surprise since the yard usually only pays $8 for regular car batteries.
  34. #20
    15,631
    How many batteries were in the pack? The normal numer I find is 2 or 4 of those small sealed batteries. I wonder why so much more for what you brought in. Mike.
  35. Similar threads on the Scrap Metal Forum
    1. power supply cords
      By metaljacket in forum General Electronics Recycling
      Last Post: 07-01-2019, 07:27 PM
    2. Uninterruptible Power Supply (UPS)
      By smajor in forum Scrap Metal Tips and Advice
      Last Post: 05-12-2015, 04:25 PM
    3. What Are You Doing With Your Uninterruptible Power Supply (UPS) Batteries?
      By Jeremiah in forum Batteries, Capacitors, Heat Sinks
      Last Post: 12-23-2013, 05:56 PM
    4. Power supply boards?
      By cencaltech in forum E-Waste Grading and Identification
      Last Post: 08-10-2012, 08:49 AM
