Who can recommend a good, cost effective portable power generator. I am looking to get one for when I am on a job, and need electric for power tools, but no where near a outlet.
I got a Generac 5000 watt off of craigslist and it's been good so far. The 240v comes in handy for running the air compressor and plasma cutter.
I saw some type of cutter (don't remember what kind) in an add for harbor freight. Another tool I need to acquire.
I do admit, I use craigslist for a lot of things, but for this, I would want to buy it brand new, but thanks for the tip. Will keep it in mind.
http://www.amazon.com/b?ie=UTF8&node=583328
Might also check here, mine's a little small but it runs my old sawzall ok, It won't run Snodleys new sawzall, must be more amps. It is nice cause I can plug in a 50 ft. cord and reach most cutting jobs. Like I told Filthy, get a bigger inverter for just a few dollars more that way your not working it to death. If your not running up against the amp limit all the time it will run cooler and last a lot longer. I think he used some heavy stereo power cable and added clamps to hook to his battery, that way it's easy on easy off. I can run my saw for about an hour before I have to start it to charge up.http://www.harborfreight.com/automot...inverters.html
That 5000 looks like a real bad-ass inverter, mine's closer to a 1500 that's why it's a little light. All depends on what all you want to run at a time.
Just a little input on what I have and use:
1,000 watt (continuous, can't remember what the surge or peak power is) inverter mounted in truck. Will run power tools like sawzall, grinder, drill, 500W halogen flood lights, etc.
400 watt inverter mounted inside the truck (runs laptop computer phone chargers etc)
1500 watt generator- small but very portable, can't handle much more than the inverter but is cheaper to use than idling the truck and more portable. Can carry it into the woods to cut something up if need be.
I also have a slew of cordless power tools that I think are great, the mobility and freedom they allow is spectactular and the longevity of use is limited by the battery life, but I can charge them on the go as well. They save a lot of time and hassle of dragging out extension cords and tripping over them, dealing with the tangles they get inevitably, and the grab n go convenience is great!
I mean't to also ask everyone, but what are your generators powered by? I mean, you just flip a switch and they are on, or they run on gas, or what?
I know there is some (the real big ones, that do run on gas) but the smaller ones you guys been showing me, what do they run on?
The small ones run on rabbit pellets.
George...your gonna have to start sharing that s hit...pass it around. Small ones run on gas, larger ones for back up power at home can be rigged to run on propane or natural gas.
Regarding to Georges question "What do they run on?" The Inverters connect to your auto aux. or Battery, the Inverters convert your Auto DC -to- AC current. I'm not sure if thats what you were refering to George.
Yeah, I was trying to find out what they use to run. I know the bigger ones that you would use say at a job site that has no electricity to it, would use gasoline.
However, I didn't know what the smaller ones would be used for...that you would just used for your corded power tools.
I just know it will be nice to get one that i can have in my truck and not have to worry about electricity being on the job site if I need to pull a tool out for any situation.
Yes, and like MDG said often times larger ones run on Diesel, like the ones at construction sites. Now an inverter is just converting 12v power from your car/truck battery to 110 ac so you have to be careful not to drain the battery too much that it won't start your truck.
I subscribe to Family Handyman. This article came up recently. It should answer everything about how to set up an inverter.
http://www.familyhandyman.com/DIY-Pr...to-a-generator
Just glanced thru the article. I recall the magazine having more instructions/detail. Maybe it didn't.
Here's a source for inverters.
http://www.donrowe.com/
He comes recommended by a few from another forum. Never dealt with him so I can't say if he is any good.
There is a small item can be added to your battery system that monitors the condition of your battery and when it gets down to a dangerous level, it will shut off the appliance and sound a warning whistle. It'll leave just enough juice in the battery to start the vehicle. Or buy one of those small jumpstarters to haul around just in case. I think their called a battery monitor, and they used to sell them at camper dealerships; probably get a better deal on the 'net now. I could run 2 florescent lights and a drill or sawzall for around an hour before I'd have to start the car.Now an inverter is just converting 12v power from your car/truck battery to 110 ac so you have to be careful not to drain the battery too much that it won't start your truck.
