Page 1 of 3 123 LastLast
Results 1 to 20 of 57
My money maker
| Tools and Equipment
    Bigblue12v started this thread.
    Columbus, IN
    204
    18
    My money maker
    This is a thread for me to show off what my hard work has earned me.... This rig has been fine tuned all year long to make it productive for me.
    Truck:
    96 Dodge Ram 3500 Cummins turbo diesel 4x4 5 speed manual, (power/economy/reliability) many power modifications/upgrades we don't need to go into.....
    19.5" wheels and tires upgrade- heavier payload capacity, safer, and much less cost per mile than with 16" tires. These are commercial grade tires and have a reputation for lasting 3x longer than 16's on a light duty truck like this, and the price is mostly comparable with 16" tires.
    Power tow mirrors- necessary for towing a trailer especially with a dually, the stock mirrors I couldn't see the trailer all i could see was the truck fenders since they were up against the doors.
    Aftermarket headlights & added factory fog lights for better night time vision
    Rear flood lights on 3 way switch- off/on/on when in reverse
    Reese Pilot digital trailer brake controller
    1000 Watt inverter under hood
    400 Watt inverter inside (laptop, cordless tool chargers)
    Laptop mount
    Kenwood double din CD/DVD/Navigation/iPhone/ etc. head unit
    Leer 100XL fiberglass cap
    2 gauge power wire to the rear with HD power plug- can plug winch directly into truck or can use to charge/assist trailer winch batteries.
    Trailer:
    22' 7,000 lb. gravity tilt deck, brakes on both axles, LED taillights
    10,000 lb. Smittybilt electric winch on a receiver mount, remove a pin and unplug it and can be mounted to back of truck in 1 minute.
    2 truck batteries to run winch (can be plugged into truck)
    Assortment of chains, load binders, ratchet straps, tow straps, wrecker J hook set, snatchblock, and a mini hoist I built just today for lifting cars up for easy access to catalytic converter.
    Portable tire changer can be quickly mounted to the rear of the trailer
    Other tools in bed of truck (long list):
    Toolboxes of hand tools, air tools, etc.
    1/2" drive cordless impact wrench
    cordless ultra compact sawzall
    cordless 3/8" drill driver
    1500 watt generator
    Small air compressor
    Portable air tank
    Drain pan (sometimes the yard wants fluids removed before they accept a piece of equipment)
    Floor jack & jack stands
    50' of air hose
    100' extension cord
    10' extension cord
    Spare fluids for the truck
    Wooden blocks used for chocking tires, "bunking" a large heavy item (stablizing it)
    Safety cones
    Flood light
    Digital scales (for purchasing non-ferrous)
    Jumper cables
    Roll of paper towels, hand cleaner
    Another tow strap
    Reflective safety vest
    Rain poncho
    Fuel can
    Chainsaw (hey sometimes I need one to get to stuff lol)
    Fire extinguisher
    Probably more stuff I'm forgetting. The mini hoist on the trailer attaches with one pin to a receiver type hitch under the winch and can be stored in the bed of the truck when not in use.
    If it all seems like overkill, it probably is, but I'll tell you what these are all things I wish I had with me at one point or another in my line of work (mainly junk cars). This setup allows me to be as prepared as possible and deal with almost any circumstance I may find myself in. I get calls for recovery work, roadside assistance (jumps/flats/broken down), private towing jobs, picking up junk cars, the occasional unwanted piece of farm equipment etc.
    I have family a couple hours away from where I live and sometimes when visiting them I will pickup some work over there, or sometimes I pickup a vehicle close to the yard I sell to, and bringing it back here for processing is way out of the way. With this setup I can manage about anything on the go which saves money or makes more money at the end of the day, however you want to look at it.
    I guess I am bragging a little but also I thought maybe it would be helpful as a model for others to get ideas from. Not everyone needs a setup like this but it WORKS REALLY WELL FOR ME! Yes there's still plenty of things I'd do different if money was no object but I work on a budget. I do all my own install and repair work as well as custom fabrication (and I'm very creative), if not for that then I'd have an S10 with a 12' utility trailer LOL
    Laptop mount swings out of way of shifter or for passenger use:
    Portable file box- a must have to keep documents organized (lots of paperwork for scrapping autos):
    Columbus, IN
    204
    18
    Only so many pictures allowed per post so here is the rest, in one of these pictures you can see part of my big engine hoist, it's a bit large, will lift one end of a vehicle no problem, powered by a 20 ton air over hydraulic bottle jack, this unit comes in handy a lot...
    And another toy, lifts small cars or one end of a bigger vehicle, pallets and crates, etc.:
  3. The Following 4 Users say Thank You for This Post by Bigblue12v:
    Pretty sweet setup!
    That L frame/pulley in front of winch. Did you add that? I know last time you talked about your trailer you wanted to modify it since it was pulling up on the cars instead of pulling it straight/tight. Were you able to figure out something there?
  5. The Following User Says Thank You to IdahoScrapper for This Post:
    Columbus, IN
    204
    18
    Idaho, the mini hoist attaches with one pin to a receiver hitch on the trailer. It's to lift a car up using the winch primarily to gain access to catalytic converters. I just built the hoist attachment today.
    The winch only pulls slightly upward on a car once the car is loaded and the deck is tilted back level. It still pulls mostly forward so it's not a problem on junk cars and hasn't been a problem on nicer cars either really because at that point you can push the car forward by hand if needed.
    1,209
    It's -13°C outside this morning my 96 Dodge with Cummins turbo diesel started up with out being plugged in, try that with a Ford or GM
  8. The Following User Says Thank You to gustavus for This Post:
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    What did you use to make your laptop stand, and your power inverter under your truck seat?
    skylinejack's Avatar
    Baton Rouge, La.
    827
    1,194
    Hey gus... I LOVE my Ford! Cranks every time and never lets me down.
    very nice Big Blue. (btw, I'm a pepper, too.)
  12. The Following User Says Thank You to Dumpster-Dee for This Post:
    Baton Rouge, La.
    827
    1,194
    Quote Originally Posted by Dumpster-Dee View Post
    I'm a country boy!
    Just messin around. That is one nice setup you got yourself Bigblue! Very nice.
  14. The Following User Says Thank You to skylinejack for This Post:
    That is a saweet rig...very well thought out.
  16. The Following User Says Thank You to KzScrapper for This Post:
    Columbus, IN
    204
    18
    Thanks everyone! Gotta love my Dodge and not just because of the Cummins although that's the best part about it I have had them all and prefer the Dodge overall.
    George, I made the laptop mount using random parts from plumbing department of lowes and a piece of plexiglass and some Velcro to secure the computer. It and the inverter are screwed to the floor with self tapping screws. I like to hard wire accessories instead of having a sloppy clutter of wires and cigarette outlet plugs. So everything is wired direct with a fuse. Certain accessories are on relays (like the lights) and automatically turn off when key is off so they don't drain the truck batteries.
    Dee, what's a pepper? I think I missed something here.
    Quote Originally Posted by Bigblue12v View Post
    Me too.
    My brother had a '95 Dodge Cummins. Over 300k on the clock and it kept on. Was a good truck.
    My other brother has a '94 Ford crew with a 7.3. It's constantly broken down.
    I like Dodge and some years of the Ford. It's my understanding Ford built them with Cummins, but not in the US. In my opin they lost a lot of business there.
    MN
    35
    48
    lol I think Dee is referring to the Dr. Pepper in your cup holder. And very nice rig! I hope to have one that nice one day.
  20. The Following User Says Thank You to David for This Post:
  21. #14
    Nice setup Blue!
    I am surprised not one, "Shake your money maker" comment.
    Well now there is!
  22. The Following User Says Thank You to injunjoe for This Post:
  23. #15
    Quote Originally Posted by GeorgeB View Post
    Scrap! That there sure looks like some good old fashion scrap pipe fit'ens to me
  24. #16
    ScrapHunter's Avatar
    35
    14
    Nice setup. Hope I can get a trailer like that soon. Is that laptop table mounted with copper pipe?
  25. The Following User Says Thank You to ScrapHunter for This Post:
  26. #17
    Steel water pipe and what looks like a pier post fitting on the floor, I'm guessing. Good looking rig tho. When Dodge first came out with the Cummins motor they were using the International line then later started building their own. My understanding is the earlier engines were the better ones.
  27. #18
    Florence,Co
    240
    93
    Rockin' set up!! I love the chains in the milk jugs, that is happening tomorrow at the yard!!
  28. The Following User Says Thank You to Area67 for This Post:
  29. #19
    submarinepainter's Avatar
    1,025
    1,230
    I was wondering where the sink and refrig were!!lol nice truck dude!
  30. The Following User Says Thank You to submarinepainter for This Post:
  31. #20
    Columbus, IN
    204
    18
    Thanks guys, again!
    Oh ya Dr. Pepper, right LOL ya i love that stuff!!!
    Joe, as soon as I posted it that song was stuck in my head all day LOL then of course i put 2 + 2 together, the saying "Dodge makes it, Cummins shakes it" with the song and when i'm bored i like to remix stuff in my head so it came out "Cummins shakes my money maker" ROFL!!!
    A few more details on the laptop mount-
    Years ago I wanted one and was looking at them on Ebay. One of the cheaper universal jobbies was very similar to what I have except the table top was slightly fancier. The rest of the kit was a bunch of plumbing parts like I have, with some split wire loom to cover it and make it look fancy. Upon realizing what they were selling I went to Lowes, this is the basic breakdown of the parts, you'll use 3/8" black iron pipe, its plenty strong and anything bigger is just bulky and ridiculous overkill.
    Get 2 flange surface mounts (like I have on the floor and the plexiglass) they have a quick coupler union I don't remember the exact name, you attach it at the bottom of the pipe and on the flange (think you need to use a stubby male union to attach it here) this lets you attach the stand to the base, just finger tighten the nut it holds it in position. You can loosen the nut and swing the laptop away from you and re-tighten it. Then whatever straight pieces and elbows you need to get the platform in the general area of where you want. I got very thick plexiglass I think 1/4". Have them cut it to the size of your laptop.
    Fasten one flange to your plexiglass as follows:
    center the flange on the plexiglass and put masking tape on the plexiglass where you'll be drilling the holes (they say this helps keep it from shattering or cracking). Place the flange back on the plexiglass and mark the holes. Remove flange. I used some real small screws for this, with a tapered shank or head like a wood screw (but regular machine screw threads) with a flat blade screwdriver slot in them. Drill the holes for that screw size, use high speed and do not put any pressure on it whatsoever or consider your plexiglass trash. Once these holes were drilled I took a drill bit the diameter of the screw head and drilled down just enough to make a countersunk hole opening so the screw head would be flush with the plexiglass. Put washers on before the nuts on the flange side and snug them down. A drip of lock tite would probably be good but I don't think I used them. I did not use pipe thread tape on any of it, and I would not think it'd be a good idea. You will need to loosen and/or readjust them quite a bit here and there and that would ruin the tape, besides your not trying to seal off anything anyway. I grabbed some velcro strap while at Lowe's as well (sticks to itself, hook on one side, loop on the other) and I think I put sticky back velcro on the bottom side of the plexi to hold the strap in place. The very back of the bottom of my laptop (against the screen) is all just open speaker/vent space and it worked well to strap it there, I can still close the screen but it's snug while strapped to base. My previous laptop instead of using the strap I put a couple sticky back pieces of velcro on the bottom of the laptop and on the plexiglass as you can see its still there, and that held it fine too.
    Hope that helps, this is a cheap fairly easy DIY project that will save a ton of money over buying one. IF i recall correctly, the kit I copied the idea from was under $60 (perhaps 30-40) and came with a nicer mount top and a variety of pipes and fittings to pick what you needed. If you don't feel like piecing it together as I did then that's a good route to go. You'll need number 8 (i think) self tapping screws probably 1" long or so, enough to go through the base flange, the carpet, padding and sheet metal of the floor of your truck. I like the ones with a 5/16" hex head on them, a socket gets a positive grip on the head VS. a phillips screwdriver head that strips out easily. Make sure there's no wires or hoses or anything underneath where truck where the screws will protrude. The shorter lengths of pipe you use especially horizontally, the more stable the mount will be.
    1. The Story of Money: From a Barter System to a Money System.
      By mrsamsonite in forum Off Topic Discussions
      Last Post: 01-10-2021, 10:09 PM
    2. money EVERYWHERE!
      By GeorgeB in forum A Day in the Life of a Scrapper
      Last Post: 02-27-2014, 10:16 PM
    3. Is think I got a on going money maker
      By kcscrapper in forum A Day in the Life of a Scrapper
      Last Post: 04-11-2012, 10:53 PM
    4. I remember when cardboard was the money maker
      By kcscrapper in forum Off Topic Discussions
      Last Post: 02-16-2012, 04:57 PM
