Results 1 to 15 of 15
Cutting torch Recommendations?
| Tools and Equipment
    Meadowview started this thread.
    Oct 2010
    24
    Question Cutting torch Recommendations?
    I am shopping for a cutting torch set up and wonder if anyone has any recommendations as to what to buy. The equipment seems to be quite expensive and I don't want to spend more than necessary. Here is my situation:
    • I have a Ford F350 with a utility body and want to put the torch and tanks inside a cabinet which has a door opening height of 36" and 42" height inside.
    • I need to buy a cutting torch to scrap some farm equipment and a forklift.
    • I would also like to have the flexibility to do different kinds of small jobs for myself such as welding and heating as the need arises but cutting is the primary concern today.
    Here are my questions:
    • How much should I plan to spend to get a decent setup?
    • Is buying used equipment a bad idea or do the torches hold up well?
    • Since I have nothing at this point, should I buy a starter kit?
    • Is buying a well known name brand such as Victor important?
    • Which fuel, acetylene or propane?
    • If propane is the way to go, should I buy an acetylene starter kit and then swap out the regulator?
    • What size cutting tips should I have in my tool box?
    • Torches seem to come in light, medium and heavy duty. Do I need to buy the heavy duty equipment?
    • I am concerned about starting fires in dry farm fields. Any thoughts?
    • Any other recommendations?
    Thanks so much for your help!
  2. The Following User Says Thank You to Meadowview for This Post:
    708bigbuck's Avatar
    53
    I know I always find decent setups at the flea market by my house. You can check Harbor Freight or Northern tool. They have fairly decent sets for resonable prices.( alot better price than you will find at a welding house.) Just remember if you are going to be doing alot of cutting, you will burn through oxygen very quickly and that can eat up your profits pretty fast. Hope this helps a little. Good luck.
    I don't know if this would work for you, but I considered buying a cutting torch and decided to use a heavy duty angle grinder instead. I've found I can cut through almost anything with a bonus - telling stainless steel from aluminum. Aluminum doesn't throw sparks - stainless steel does. I don't worry about cutting through something and setting what's inside on fire (like wiring or oil in compressors).
  5. The Following User Says Thank You to Mick for This Post:
    Oct 2010
    24
    I thought I would follow up on this. I bought a torch setup and wish I hadn't. It takes too long to setup, I spend way too much on gas and oxygen, I don't feel comfortable using it, it is slower than I envisioned, it takes a lot of time to go to the supply house for fresh tanks, the tanks take up valuable space on my truck, and there are not very many situations away from home where I feel I can use it safely. Also as I feared, I am constantly stamping out fires when I do use it.
    I know a lot of the problems stem from my lack of experience but all in all I wish I had put the money into something else.
    Thanks to Mick and Bigbuck for your earlier input. I appreciate it!
    1,159
    Man just use them you will get them down.I take it you didnt buy propane?
    There is some bad ass torches on the internet i would love to buy but they are 1500+ They run off of gasoline.
    S.E. Missouri
    21
    I've seen the gasoline torch's on web videos they are fast but I don't have the stones to mix gas and fire.
    Focker do you use propane and if you do is it enough of a saving to buy a $70 regulator?
    1,159
    propane will save you a ton.you can get a propane tank filled for 30 and ace would be 80 plus so propane is the way to go.
    May 2013
    41219
    a harris torch and #6 tips bout the best way to go small light and cutting would be fast to make your money out of a tank that what i would use most people use a #4 but i know that only slows you down but it up to you if you want to play whit the metal or cut it to make money
    jghilino's Avatar
    KANSAS CITY
    2,672
    1,429
    a no 1 tip is about the largest you should need based on what your talking about, i dont know what your talking about with the no 6 and no 4 tips, you scrapping out a m1a1? With the proper tip size and regulator settings you can get alot out of a bottle of oxygen.
    I would use the #0 tip. The kerf on your cut will be much smaller. On my Victor regulators I run my Acetylene at 7lbs. and my Oxygen at 20lbs.
    Harris is the only way to go. you can buy a full set w/tanks often on CL. for around $150 they are a handy tool to have around if you have the extra bucks. get the small 100 lb oxygen tank and propaine not only is cheeper but I think it cuts better once you learn how to use it, just my .02
    Re-cycler is offline Metal Recycling Entrepreneur
    Re-cycler's Avatar
    Southwest MN
    167
    126
    I've been using my little Smith torch for 35+ years with no real problems for a few years I was cutting at least 50 tons of steel a year.
    My regulators (brooklyn I think) are so old I had to buy an adapter for the gas one to adapt to modern female gas/propane/acetylene tanks.
    They still have the original beveled glass lenses in them.
    You do not need a special regulator for different gasses just the cutting tips are different.
    Propane tips for my Smith are only about $15.oo I just picked up another complete Smith rig for twenty bucks from a friend who had 3 sets and it is like new guages and all.
    I pay $50. to fill a 100 lb tank of propane and that will probably last through 10 to twenty full size tanks of oxygen at about $26 per tank......I own my tanks even though I just exchange them.
    My paper work is worth the current cost of new tanks.
    Re-cycler's Avatar
    Southwest MN
    167
    126
    This is my newest friend $375. and 100 mile one way drive to pick it up just have to get my 3-phase plugin wired out and I'll be havin some fun with stainless aluminum and anything else I want to play with I have 2 tons of 1/4 in plates to play with.
  15. The Following 2 Users say Thank You for This Post by Re-cycler:
    Jul 2013
    Torches are great for heavy steel not for cars or light gauge. I use a demo saw or grinder for that stuff. Also I'm not so sure you can put the tanks in an enclosed space. I'm pretty sure they have to be secured in an open area.
    ks
    2,187
    2,513
    Quote Originally Posted by Focker View Post
    Propane can't weld properly! Accetylene is the only fuel that you can weld with it. And yes propane is cheaper, but not two ways about it propane requires a bunch more oxygen than Acctyelene, so where exactly is the savings ?
    And per brand, You won't see me Strike up a torch that doesn't say victor on it! Not a Chinese made knock off "victor style" but an actual victor brand torch
    ks
    2,187
    2,513
    Quote Originally Posted by Meadowview View Post
    Formal training helps a ton, pun intended. And also a class a fire extinsher is a must too. I bought my used for 100$, and all it needs to be recharged is tap water and 100 psi of compressed air.
    Water Fire Extinguishers by KIDDE - Fire Extinguishers by Zoro Tools Industrial Supplies
  19. The Following User Says Thank You to taterjuice for This Post:
    1. cutting torch
      By decjr2006 in forum Tools and Equipment
      Last Post: 11-26-2011, 02:15 AM
    2. Cutting tool that isn"t a torch
      By sdw in forum Tools and Equipment
      Last Post: 07-13-2011, 03:54 PM
    3. Looking for recommendations for a cutting wheel
      By Mick in forum Tools and Equipment
      Last Post: 12-05-2010, 11:46 PM
Tags for this Thread
