Originally Posted by
Kris Kringle
Nope don't sound correct to me. when using the Propane set up you can't use it like a Acetylene set up. the Propane Hot spot in the flame is futher away from the metal if you use it like a Acetylene set up you will be in the cold section of the flame and you will use more Propane/Oxy trying to cut the metal.
Just my .02
When did they start selling o2 by the pound, how many cubic feet are therein your o2 bottle. if you don't know how many inches tall is the bottle.
You should be able to back off on the propane ,I would go around 6 lbs get a larger bottle your 20 pounder is going to freeze up. in cold weather.
For that light farm scrap on the oxygen back off to 25/30 lbs
The last it cost I was aware of to cut a ton of scrap it took $8.00 to cover the gas. Piston Scrap would have a better idea of what it cost per ton these days.
I'm gong to take a guesstimate and say $15.00
