Results 1 to 13 of 13
IDE Cables
    devo started this thread.
    Eastern Ontario
    294
    139
    IDE Cables
    Hey all. Wanted to ask for some advice here. As most of you know I scored a pretty large load of escrap, and with your help and support got a lot of broken down and resorted to a more manageable heap.
    A lot of it I have a pretty good idea what my plans are for it, but the IDE cables I have no idea. I have thousands of them and need to make a plan for those. They are brand new in the plastic bags, and to my way of thinking they should have more than scrap value, but they are also pretty obsolete now. I suppose I could try and ebay them in small lots, but I don't think the return on the time of doing that would really be worth it in the end.
    The connectors I think are gold bearing so they might be worth cutting off and taking in the ribbon for insulated. Pretty daunting task there too I think.
    Anyone have any thoughts on this??
    TIA
    Devo
  2. The Following User Says Thank You to devo for This Post:
    15,631
    The pay on the ends depends on the buyer. The cutting off has been discussed a lot. I use pruning shears, the ones that look like sissors. With your load you may want to consider buying an old fashioned paper cutter like teachers used to use. The kind with a the long blade. Here's an example of one on ebay, Mike
    http://www.ebay.com/itm/Vintage-15-I...item5d325c7229
  4. The Following 2 Users say Thank You for This Post by miked:
    Eastern Ontario
    294
    139
    Thanks Mike. I hadn't thought of a paper cutter like that. The towers I took apart I processed the ide cables on the spot and found a good pair of scissors was the easiest for me. I'm not so sure if that will be the best for the kind of quantities I have though. I can already feel the blisters.
    The more I think about that paper cutter the more I like it. Since the cables are all identical, I could lay out a bunch, chop, repeat.
    Thanks!
  6. The Following 2 Users say Thank You for This Post by devo:
    the connectors are definately worth cutting off. the ribbons are something else again, some yards wont take them, most won't pay what t hey are really worth copper wise. I have herd :0 burning them is very efficient and quick. not that I would do such a thing.
    p.s. be careful with the paper cutter they are notorious for lopping off the tips of fingers.
  8. The Following 2 Users say Thank You for This Post by EcoSafe:
    South Central Minnesota
    232
    123
    The IDE connectors are not difficult to cut apart to get the connector pins out. Just tedious work. A 3 connector IDE cable will net about 3 grams or .10 oz pins. About 160 IDE cables nets about a pound of pins give or take and depending on number of pins per connector. There are buyers on the forum who may purchase the gold plated pins, other option is to sell on ebay. Check some completed auctions on gold plated pins, might get your attention.
  10. The Following User Says Thank You to bejak for This Post:
  11. #6
    Eastern Ontario
    294
    139
    Thanks. I have seen some of those pin auctions and am giving some thought. I've been thinking about maybe building some sort of crude ball mill to try and automate the process. Theoretically it should work.
  12. #7
    thortek's Avatar
    Scrap biz in OHIO, but I live in south Florida!
    513
    153
    Quote Originally Posted by devo View Post
    Let me know how that works for you..
    “Most people miss opportunity because it wears overalls and looks like work .” ― Thomas A. Edison
    www.thortekrecycling.com
    Eastern Ontario
    294
    139
    Probably like most of my theories, an ill conceived piece of machinery barely worth scrap value, with an epic mess of unsaleable half stripped pins and connectors underneath it on the floor!
    Actually I had another thought on this. I have one of those old style paint can shakers here. Maybe I could fill a can up 1/3 with the clean connectors, and a bunch of nuts of various sizes and give it a good shake. Might give that a try this afternoon.
  14. The Following User Says Thank You to devo for This Post:
    Otto's Avatar
    Ottawa, Ontario
    335
    494
    Don't be discouraged. Most progress comes from grinding trial and error.
    1,209
    Quote Originally Posted by bejak View Post
    I recently shredded a big pail full of IDE connectors and I can tell you there was no 3 grams of gold recovered.
    In the manufacture of electronics a gram of gold goes a long way, takes a mountain to scrap to recover that gram.
    Best gains are from flat packs, fingers and cpu's
  17. The Following User Says Thank You to gustavus for This Post:
  18. #11
    Quote Originally Posted by biscuit View Post
    I read it as the amount of pins recovered, not the amount of gold. Maybe the OP can clarify.
  19. #12
    585
    76
    That's what I use the paper cutter teachers use.
  20. #13
    232
    123
    The 3 grams I mentioned was the net weight of the extracted pins, not weight of recovered gold.
  21. The Following 2 Users say Thank You for This Post by bejak:
    1. Idea for Degaussing Cables
      By BRASSCATCHER in forum Scrap Metal Tips and Advice
      Last Post: 03-05-2013, 05:55 AM
    2. Computer cables
      By starbits in forum Scrap Metal Tips and Advice
      Last Post: 01-19-2012, 10:42 PM
    3. SCSI vs IDE HDD breakdowns
      By faulguy in forum General Electronics Recycling
      Last Post: 10-01-2011, 11:35 AM
    4. Computer Cables
      By Hurrikane in forum Scrap Metal Questions and Answers
      Last Post: 07-01-2011, 09:28 PM
    5. BX Cables/Wire
      By scraparama in forum Scrap Metal Questions and Answers
      Last Post: 05-04-2011, 09:21 PM
