Results 1 to 19 of 19
Warning about Compressor Scrap
    MDJSalvage started this thread.
    Stroudsburg PA
    25
    Hi everybody. I'm new to this forum but have been running my own salvage gig for around 10 years. Part of my business is in compressor scrap. For years I've been using an angle grinder to cut open my compressor cases.
    I recently saw a post on here about somebody using torches to do the same thing. I can't find that post now but I wanted to give you a warning about torching compressors.
    When the oil inside a compressor is heated, it gives off fozine gas. This isn't exactly healthy for you. Be careful everybody
  2. The Following 14 Users say Thank You for This Post by MDJSalvage:
    Ocala fl
    100
    73
    Not to be a jerk but if you want to research it more its spelled phosgene gas it is heavier than air and will displace oxygen in your lungs and kill you.
  4. The Following 2 Users say Thank You for This Post by fordsix:
    2,416
    667
    Not to mention that cutting them open with a grinder will heat them up as well. Just saying.
    Stroudsburg PA
    25
    Lol I wasnt sure how to spell it, I typed how I thought it would be spelled on google and that popped up, must be something else lol.
    Using a grinder will also heat them up, but not enough to create heat to generate that gas. I usually try to grind at the highest weld at the top. There's still going to be some residue there but not enough to realy matter.
  7. The Following User Says Thank You to MDJSalvage for This Post:
    boise, ID
    1,605
    469
    If you do a google search you'll find that phosgene gas was the deadliest gas used in WWI. The downfall of it was that it could take up to 24 hours to kill you. That's why it's so important when cutting compressors to make sure you're doing it in a well ventilated area. Preferably outside on a windy day.
    c4f5's Avatar
    northeast CO
    387
    112
    Phosgene gas is created when any type of freon is burned. Bear it in mind when cutting on any type of a/c or refrigeration unit, or near a/c components on a car. Assuming that you have evacuated the freon, there will only be trace amounts. Most of what is burning is compressor oil, but traces are in there none the less. When cutting on these items, I always do it outside and stand upwind, with my head higher than the cutting area.
  10. The Following User Says Thank You to c4f5 for This Post:
    Stroudsburg PA
    25
    Quote Originally Posted by c4f5 View Post
    Do you scrap compressors? If so do you use a torch or grinder?
    boise, ID
    1,605
    469
    I use a plasma cutter but I think a lot of people on here are using grinders.
  13. The Following User Says Thank You to freonjoe for This Post:
    Stroudsburg PA
    25
    Yeah I mainly use a grinder myself, but plasma cutter, great idea. Gotta even quicker than a torch
    boise, ID
    1,605
    469
    Quicker and no oil fires!
  16. The Following User Says Thank You to freonjoe for This Post:
    Stroudsburg PA
    25
    Freonjoe, Thanks buddy you have just made my day!!
    1,878
    1,642
    Will it still create the gas after draining the oil out? Just wondering...
    billygoat's Avatar
    630
    99
    As a former maintenance worker, I know fully well that playing with freon gernerally requires either certification or a licence. I've been reading a few posts here and there about folks scrapping A/C units and it makes me cringe. I think that anyone who wishes to play around with these things should take the classes and learn the proper way to deal with freon, especially the different types of freon, the recovery process, and how to dispose of it.
  20. The Following User Says Thank You to billygoat for This Post:
  21. #14
    c4f5's Avatar
    northeast CO
    387
    112
    Quote Originally Posted by MDJSalvage View Post
    Yes I do. 10 minutes and half a disc for the grinder. 30 seconds with a torch. I lean toward the torch. I also let them drip for a few days into a pan empty before cutting.
  22. The Following User Says Thank You to c4f5 for This Post:
  23. #15
    Stroudsburg PA
    25
    Thanks! That was going to be my next question, wheather you drained them out first or just zipped right into them with the torches. What is the general consensus here as far as draining them first or just torching them with the oils inside?
    I agree with billygoat too. I am an HVAC licensed tech and have the full recovery machine setup. Never ever ever let freon loose in the environment. Its harmful it and expensive to you if you get caught.
  24. #16
    boise, ID
    1,605
    469
    I am a licensed HVAC tech. I set the compressors on my cutting table (outside) and cut the tops off. Then pull the windings and tip the compressor upsidedown to drain the oil. After I'm done cutting compressors for the day, I empty the drain pan into a 250 gallon storage tank.
  25. #17
    c4f5's Avatar
    northeast CO
    387
    112
    First time I cut one, I did not drain it first. Firey mess.
  26. #18
    boise, ID
    1,605
    469
    c4f5, are you using a torch to cut them with?
  27. #19
    Outer Space
    18
    What kind of oil is used in the compressors?
    1. How to scrap an ac compressor
      By jackshmuc in forum Scrap Metal Videos
      Last Post: 09-08-2012, 03:16 PM
    2. Compressor scrap prices >
      By any18 in forum General - Let's talk business
      Last Post: 02-25-2011, 08:33 PM
