Results 1 to 20 of 20
Driver set for (cordless) drill
| Tools and Equipment
    Mick started this thread.
    I just got this Ryobi driver set from Home Depot yesterday and looks like it has about everything I'll ever need as far as screwdrivers, Hex, Torks, Square head and Slotted. There are adapters to use 1/4", 3/8 and 1/2" sockets. There are separate drivers for 3/16", 1/4", 5/16" 3/8" 7/16" and 1/2" nuts.
    Cost $20.
    I suppose it'd work with a corded drill, too. Just that I use a corded drill just for drilling.
    http://i1209.photobucket.com/albums/...t-Ryobi006.jpg
    http://i1209.photobucket.com/albums/...t-Ryobi007.jpg
    The part on the bottom left flips up. There are six more under there.
  2. The Following 2 Users say Thank You for This Post by Mick:
    6,815
    one other thing you might run in to with small appliances is those security screws, does it have any tips for that ?
    corycouch's Avatar
    jonesboro ar
    1,405
    3,766
    i buy a new set probably every month always losing something, the last one i got was a huge dewalt kit home depot had on clearance for $15 i dont know why i didnt buy all of them
    Not sure. What kind of shape are they?
    wayne's Avatar
    UK
    319
    117
    Mostly like the ones on the right of the page here:
    http://en.wikipedia.org/wiki/Torx
    I know lying is wrong, but if the elephant man came in now in a blouse with some make up on, and said, "How do I look?" Would you say, bearing in mind he's depressed and has respiratory problems, would you say, "Go and take that blusher off you mis-shapened elephant tranny?" No. You'd say, "You look nice... John""
  7. The Following User Says Thank You to wayne for This Post:
    [QUOTE=wayne;62899]Mostly like the ones on the right of the page here:
    Yes, there is a set of common Torx (I misspelled as Torks) bits.
    ParkerFlyer4's Avatar
    north west
    407
    423
    I hate buying "whole sets" of bits, cause I keep breaking/stripping the same ones. I have a ton of random bits that I never use. I need to go to costco and buy a pallet of the ones I use up every day...
    Eastern Ontario
    294
    139
    Quote Originally Posted by ParkerFlyer4 View Post
    Was just about to post along those lines.
    Does anyone have a good source for buying individual torx bits? I can buy every other bit I need, but can only ever find those in sets.
    South Central Minnesota
    232
    123
    Quote Originally Posted by devo View Post
    Devo I got some individual torx bits not to long ago at the local Ace Hardware Store
    As a driver I'm always sober, but my truck is always ready to get loaded
  12. The Following User Says Thank You to bejak for This Post:
    232
    123
    Mick I got a security bit set just like this from HFhttp://www.harborfreight.com/33-piec...set-93388.html
    Victor's Avatar
    Vegas via Canton Ohio
    169
    http://www.fastenal.com/web/home.ex
    Type in torx bit in the search bar. Should have everything down to T4.
    6,815
    it's like a torx with a hole in the middle, and a pin in the middle of the hole, if i recall correctly, i haven't bought any of them yet, but found an appliance once that i needed them on
    6,815
    Quote Originally Posted by bejak View Post
    i like that long reach set at the bottom right
    Those are the security torx. You might also find them singly at Menards, might be cheaper than Ace.
    I think he is referring to the speciality bits farther down on the page. I have some scrap that's waiting to be broken down that has something similar to the tri-wing.
  19. #16
    How is that set holding up so far? I have had good and bad luck with HF tools. Haven't tried any bits yet.
  20. #17
    The set I bought has the tri wing and most of the different security screws.
  21. #18
    I see bulk packs of bits on ebay. Search for 'bulk torx' or whatever bit you're looking for.
  22. #19
    232
    123
    So far they have been holding up. Have used mostly just the torx bits from the set. I turn the torque setting down on my drill, rather have it ratchet against the torque stop than twist off bits or strip screws. Sometimes a few quick smacks with a hammer on a bolt or screw head is all it takes to get the really tight ones loosen up.
  23. The Following User Says Thank You to bejak for This Post:
  24. #20
    18
    My local menards does sell individual torx, hex, and most other common bits. I keep my Gearwrench ratcheting set with me at all times, just the ones I used to strip all the time I have swapped out for titanium bits of the same style. At a little under $2 for a 2-pack of a certain type, it seems like alot for 2 bits. But considering ive been using the same #2 phillips bit for well over a year now (and I do alot of projects) I really dont think you can beat it
    1. Looking For A New Cordless Screwdriver?
      By Mechanic688 in forum Tools and Equipment
      Last Post: 07-20-2014, 12:15 PM
    2. Recommendation for new cordless drill?
      By Mick in forum Tools and Equipment
      Last Post: 06-18-2013, 02:18 PM
    3. looking for a screw driver.
      By EcoSafe in forum Tools and Equipment
      Last Post: 03-18-2013, 11:22 PM
    4. Box of golf club driver heads
      Last Post: 09-10-2012, 08:27 AM
    5. cordless tools
      By mikedmissouri in forum Scrap Metal Tips and Advice
      Last Post: 02-09-2012, 10:07 PM
